    Facial Recognition - customize your mirror for every user!
    216 Posts 56 Posters 556.3k Views 58 Watching
    • piedanielP Offline
      piedaniel
      yes, I configure in true useUSBCam.
      • cowboysdudeC Offline
        cowboysdude Module Developer
        I’m holding off on the facial recognition until I can figure out how to use in conjunction with pir sensor to turn mirror on and off…
          sarthak18593
          Can anyone show me an example of how the classes should sit in the config.js file? I’m confused
          • K Offline
            KirAsh4 Moderator
            Take a look at the stock ~/MagicMiror/config/config.js.sample file. That should give you a good start.
              sarthak18593
              im stuck at this part of the facial recognition tools - “Write down the [‘name’, ‘name2’,‘name3’] part because you will later need it for setting up your mirror’s face recognition.” , Where do i find those names ? i see a folder has been created in the training data , but training.xml doesnt have any names
                sarthak18593
                Nevermind , got it , stupid mistake
                • L Offline
                  lepetitnicolas
                  Hello,
                  I just discovered this project and i want to try this module before to build my MagicMirror !!!
                  i’ve got a problem with the facial recognition tools…
                  i use a usbcam, i try with fswebcam without problem, i enable the webcam in raspi-config but when i try capture.py, i’ve got a error
                  Capturing positive training images.
                  Type c (and press enter) to capture an image.
                  Press Ctrl-C to quit.
                  c
                  Capturing image...
                  mmal: mmal_vc_component_create: failed to create component 'vc.ril.camera' (1:ENOMEM)
                  mmal: mmal_component_create_core: could not create component 'vc.ril.camera' (1)
                  Traceback (most recent call last):
                    File "capture.py", line 35, in <module>
                      capture.capture()
                    File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/facetrainer/lib/capture.py", line 55, in capture
                      image = camera.read()
                    File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/facetrainer/lib/picam.py", line 23, in read
                      with picamera.PiCamera() as camera:
                    File "/usr/lib/python2.7/dist-packages/picamera/camera.py", line 488, in __init__
                      self.STEREO_MODES[stereo_mode], stereo_decimate)
                    File "/usr/lib/python2.7/dist-packages/picamera/camera.py", line 526, in _init_camera
                      "Camera is not enabled. Try running 'sudo raspi-config' "
                  picamera.exc.PiCameraError: Camera is not enabled. Try running 'sudo raspi-config' and ensure that the camera has been enabled.
                  Can you help me ?
                  Thank
                  Note from admin: Please use Markdown on shell snippets!
                    sarthak18593 @lepetitnicolas
                    @lepetitnicolas To my knowledge , capture .py only works with the built in webcam , that is , the pi camera module . Plus , if you are already taking images via fswebcam , why not just select option 2 in capture.py, the one with using already existing .jpg files ? Why capture again ?
                    • L Offline
                      lepetitnicolas
                      thank. it works !
                      • L Offline
                        lepetitnicolas @sarthak18593
                        @sarthak18593
                        hello, where do you find those names ???
                        sorry but i don’t know where i need to change the “nane” …
                        i try the facial recognition tester …
                          File "facerecognition.py", line 18, in <module>
                            import lib.face as face
                          File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/facerecognition_tester/lib/face.py", line 10, in <module>
                            import config
                          File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/facerecognition_tester/lib/config.py", line 18, in <module>
                            personen = [Gael]
                        NameError: name 'Gael' is not defined
                        thank
                        P S 2 Replies Last reply Reply Quote 0
                        • P Offline
                          paviro @lepetitnicolas
                          @lepetitnicolas the array personen(really need to translate that into english :D ) should be personen = ["Gael"] else it will look for a variable called Gael which does not exist.
                          – The Doctor
                            @lepetitnicolas you will see the names as an output to running the train.py file , in the terminal window itself , copy paste from " [ " to "] " and save it. Place this text in personen as mentioned by @paviro and also place it in the config.js file . Hope this clears things up
                            • L Offline
                              lepetitnicolas
                              Hello,
                              Thank, the training module works fine and he recognizes me…
                              but now i try the module and i put all the detail in the config.js and when i launch the MagicMirror, i’v got this
                              Error opening app
                              The app provided is not a valid Electron app, please read the docs on how to write one:
                              https://github.com/electron/electron/tree/v1.1.0/docs
                              Error: Cannot find module 'python-shell'
                              npm ERR! Linux 4.4.9-v7+
                              npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "start"
                              npm ERR! node v6.2.0
                              npm ERR! npm  v3.8.9
                              npm ERR! code ELIFECYCLE
                              npm ERR! magicmirror@2.0.0 start: `electron js/electron.js`
                              npm ERR! Exit status 1
                              npm ERR!
                              npm ERR! Failed at the magicmirror@2.0.0 start script 'electron js/electron.js'.
                              npm ERR! If you do, this is most likely a problem with the magicmirror package,
                              npm ERR! not with npm itself.
                              npm ERR!     electron js/electron.js
                              npm ERR!     npm bugs magicmirror
                              npm ERR! Or if that isn't available, you can get their info via:
                              npm ERR!     npm owner ls magicmirror
                              • P Offline
                                @lepetitnicolas what does /home/pi/MagicMirror/npm-debug.log say? Also please use Markdown on shell snippets!
                                – The Doctor
                                • L Offline
                                  lepetitnicolas
                                  thank you for your help.
                                  my npm-debug.log
                                  1 verbose cli [ '/usr/local/bin/node', '/usr/local/bin/npm', 'start' ]
                                  2 info using npm@3.8.9
                                  3 info using node@v6.2.0
                                  5 info lifecycle magicmirror@2.0.0~prestart: magicmirror@2.0.0
                                  6 silly lifecycle magicmirror@2.0.0~prestart: no script for prestart, continuing
                                  7 info lifecycle magicmirror@2.0.0~start: magicmirror@2.0.0
                                  8 verbose lifecycle magicmirror@2.0.0~start: unsafe-perm in lifecycle true
                                  9 verbose lifecycle magicmirror@2.0.0~start: PATH: /usr/local/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                                  10 verbose lifecycle magicmirror@2.0.0~start: CWD: /home/pi/MagicMirror
                                  11 silly lifecycle magicmirror@2.0.0~start: Args: [ '-c', 'electron js/electron.js' ]
                                  12 silly lifecycle magicmirror@2.0.0~start: Returned: code: 1  signal: null
                                  13 info lifecycle magicmirror@2.0.0~start: Failed to exec start script
                                  14 verbose stack Error: magicmirror@2.0.0 start: `electron js/electron.js`
                                  14 verbose stack Exit status 1
                                  14 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/lib/utils/lifecycle.js:245:16)
                                  14 verbose stack     at emitTwo (events.js:106:13)
                                  14 verbose stack     at EventEmitter.emit (events.js:191:7)
                                  14 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/lib/utils/spawn.js:24:14)
                                  14 verbose stack     at ChildProcess.emit (events.js:191:7)
                                  14 verbose stack     at maybeClose (internal/child_process.js:850:16)
                                  14 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:215:5)
                                  15 verbose pkgid magicmirror@2.0.0
                                  16 verbose cwd /home/pi/MagicMirror
                                  17 error Linux 4.4.9-v7+
                                  18 error argv "/usr/local/bin/node" "/usr/local/bin/npm" "start"
                                  19 error node v6.2.0
                                  20 error npm  v3.8.9
                                  21 error code ELIFECYCLE
                                  22 error magicmirror@2.0.0 start: `electron js/electron.js`
                                  22 error Exit status 1
                                  23 error Failed at the magicmirror@2.0.0 start script 'electron js/electron.js'.
                                  23 error Make sure you have the latest version of node.js and npm installed.
                                  23 error If you do, this is most likely a problem with the magicmirror package,
                                  23 error not with npm itself.
                                  23 error Tell the author that this fails on your system:
                                  23 error     electron js/electron.js
                                  23 error You can get information on how to open an issue for this project with:
                                  23 error     npm bugs magicmirror
                                  23 error Or if that isn't available, you can get their info via:
                                  23 error     npm owner ls magicmirror
                                  23 error There is likely additional logging output above.
                                  24 verbose exit [ 1, true ]
                                  • P Offline
                                    paviro
                                    Make sure to install all dependencies as stated in the README file! Use npm install for that. As you can see in you error log python-shell is missing.
                                    – The Doctor
                                    • L Offline
                                      lepetitnicolas
                                      Sorry.
                                      Now, it’s work fine.
                                      Thank you.
                                      • P Offline
                                        paviro
                                        @lepetitnicolas glad it does :)
                                        – The Doctor
                                        • W Offline
                                          Wilco89
                                          Is it also possible to use with the cameramodule of raspberry?
                                            sarthak18593 @Wilco89
                                            @Wilco89 yup , just set ‘useUSBcam’ to false in the config.js file and also make sure your pi has camera module enabled via the configuration of your pi
                                            • 10
                                            • 11
                                            • 2 / 11
