    Wunderlist - your todos on the mirror
    113 Posts 27 Posters 210.3k Views 22 Watching
      mikmonken
      OK strike that it does work, there seemed to be an issue with the browser version of wanderlist not syncing, which meant that despite it appearing to have content on it wasn’t sending it to the mirror.
      All good now.
      • P Offline
        paviro
        Glad you figured out how to fix it :)
        – The Doctor
        • K Offline
          Kukielka58
          Greetings,
          first of all, thanks for making the module!
          Sadly I can’t really appreciate your work, because it doesn’t work for me. :(
          I’m running magicMirror on a Contos7 VM on my Homeserver.
          The code in the Line 42 always returns me “undefined”.
          this.tasks[this.config.lists[i]]
          However retrieving the tasks via curl seems fine.
          Here is my Config:
          			module: 'MMM-Wunderlist',
          			position: 'top_right',
          			header: 'To-Do Liste',
          				accessToken: '*********************************',
          				clientId: '*********************',
          				lists: ['inbox'],
          				interval: 5,
          				maximumEntries: 5,
          				fade: true
          I’m really looking forward to hear from you. :)
          • P Offline
            paviro
            Are you sure this has nothing to do with your setup? Centos 7 is not officially supported.
            – The Doctor
            • K Offline
              Kukielka58 @paviro
              @paviro I know that it’s not officially supported but everything else seems fine.
              Maybe any dependencies I’m not awayre of? I already installed npm request manually.
              • P Offline
                paviro
                Not sure this error seems off to me since I check if the variable is undefined… Well I am on holiday right now so I can’t really check anything, sorry :/
                – The Doctor
                K 2 Replies Last reply Reply Quote 0
                • K Offline
                  Kukielka58 @paviro
                  @paviro No Problem at all, hope you enjoy you holidays! :)
                  • K Offline
                    Kukielka58 @paviro
                    @paviro After further inspection it seems like the array this.tasks = []; is always empty. which is why if (typeof this.tasks[this.config.lists[i]] != “undefined”) is always false. Any Ideas? :(
                    • P Offline
                      paviro
                      Please try using the fetcher_debug_client.js. You have to fill in your data in createFetcher("id", "Inbox", 1000, accessToken, clientID); at the bottom :) You can then run it with node fetcher_debug_client.js from the module directory.
                      – The Doctor
                      • K Offline
                        Kukielka58 @paviro
                        @paviro Did exactly what you said. I ran node fetcher_debug_client.js from the /opt/MagicMirror/modules/MMM-Wunderlist/ directory and it seems to have worked.
                        Create new todo fetcher for list: Inbox - Interval: 1000
                        • K Offline
                          Kukielka58 @paviro
                          @paviro said in Wunderlist - your todos on the mirror:
                          Any progress so far?
                            Sunburned
                            Hey all,
                            Love this module, just got it working and i think it is going to be really helpful staying organized. I am having one issue i was hoping to get some assistance with. New todo’s show up fine, however when one is marked as done, it does not disappear from the mirror, it will disappear from the phone app if i do it on the computer and vice versa. If i remove an item (or multiple items) and add something new then the completed items are removed. Any thoughts?
                              Sunburned
                              Has anyone encountered an issue where Wunderlist freezes? I am getting the module to show with my todo’s but they do not update after the magicmirror application has been running for more than about 18 hours. If i restart the magic mirror application it does update. As a side note, other modules on the mirror do update as well, so i am thinking it is possibly some freezing issue rather than a communication one.
                                Sunburned
                                So I could not figure out why Wunderlist is freezing so just did a workaround by setting up a cron job to reset the pi twice a day and start up the mirror. So far that is working for me.
                                • P Offline
                                  pugsly @Sunburned
                                  @Sunburned I was having this problem where I would mark an item on my phone complete and it didn’t update on the mirror. I just did a git pull on the module (seems like it was updated) and its now working again.
                                  • SexyTroggS Offline
                                    SexyTrogg
                                    Was anyone able to come up with a solution to the blank todo list? I am also having that problem where it displays the Header but no actual tasks. I get the same curl error as @mikmonken but I didn’t find what his solution was. I also tried running the fetcher.js files listed below but truth be told, I am a linux noob and I don’t know how to install requireJS. Any suggestions?
                                    • C Offline
                                      carteblanche
                                      This module is working perfectly for me. As others mentioned it doesn’t work for the filters like Today, Week, etc. you can only assign it to specific lists that you create like “Work” for example.
                                      SexyTroggS 1 Reply Last reply Reply Quote 0
                                        SexyTrogg @carteblanche
                                        @carteblanche I’ve moved all my tasks to the inbox and tried using that. Still cant get a list to show. Other todo modules have worked immediately though so I may have to just switch over to one of them.
                                        • C Offline
                                          carteblanche @SexyTrogg
                                          @SexyTrogg You don’t need any of the tasks to be in the Inbox folder. You just need to create a new custom list of your todos separate from the auto generated folders that Wunderlist creates and call that list name out in the module config file.
                                          See a screenshot of my lists here…I can have either Work or Family show up on my mirror if I choose those names in the config file. But be careful it is case sensitive.
                                            SexyTrogg
                                            @carteblanche
                                            My set up is as follows:
        position: 'top_left',
        header: 'Get this ish done',
        accesToken: '----',
        clientID: '----',
        lists: ["Sports","Work"],
        interval: 60,
        fade: true
                                            Everything looks like it should work for me but again still just the black screen. Raspberry Pi 3 with the newest Wunderlist repo and updates.
                                            • 6
                                            • 4 / 6
