    Wunderlist - your todos on the mirror
    113 Posts 27 Posters 213.8k Views 22 Watching
    • paviroP
      paviro
      Are you sure this has nothing to do with your setup? Centos 7 is not officially supported.
      – The Doctor
      K 1 Reply Last reply
      • K
        Kukielka58 @paviro
        @paviro I know that it’s not officially supported but everything else seems fine.
        Maybe any dependencies I’m not awayre of? I already installed npm request manually.
        • paviroP
          paviro
          Not sure this error seems off to me since I check if the variable is undefined… Well I am on holiday right now so I can’t really check anything, sorry :/
          – The Doctor
          K 2 Replies Last reply
          • K
            Kukielka58 @paviro
            @paviro No Problem at all, hope you enjoy you holidays! :)
            • K
              Kukielka58 @paviro
              @paviro After further inspection it seems like the array this.tasks = []; is always empty. which is why if (typeof this.tasks[this.config.lists[i]] != “undefined”) is always false. Any Ideas? :(
              • paviroP
                paviro
                Please try using the fetcher_debug_client.js. You have to fill in your data in createFetcher("id", "Inbox", 1000, accessToken, clientID); at the bottom :) You can then run it with node fetcher_debug_client.js from the module directory.
                – The Doctor
                • K
                  Kukielka58 @paviro
                  @paviro Did exactly what you said. I ran node fetcher_debug_client.js from the /opt/MagicMirror/modules/MMM-Wunderlist/ directory and it seems to have worked.
                  Create new todo fetcher for list: Inbox - Interval: 1000
                  • K
                    Kukielka58 @paviro
                    @paviro said in Wunderlist - your todos on the mirror:
                    Any progress so far?
                      Sunburned
                      Hey all,
                      Love this module, just got it working and i think it is going to be really helpful staying organized. I am having one issue i was hoping to get some assistance with. New todo’s show up fine, however when one is marked as done, it does not disappear from the mirror, it will disappear from the phone app if i do it on the computer and vice versa. If i remove an item (or multiple items) and add something new then the completed items are removed. Any thoughts?
                        Sunburned
                        Has anyone encountered an issue where Wunderlist freezes? I am getting the module to show with my todo’s but they do not update after the magicmirror application has been running for more than about 18 hours. If i restart the magic mirror application it does update. As a side note, other modules on the mirror do update as well, so i am thinking it is possibly some freezing issue rather than a communication one.
                          Sunburned
                          So I could not figure out why Wunderlist is freezing so just did a workaround by setting up a cron job to reset the pi twice a day and start up the mirror. So far that is working for me.
                          pugslyP 1 Reply Last reply
                          • pugslyP
                            pugsly @Sunburned
                            @Sunburned I was having this problem where I would mark an item on my phone complete and it didn’t update on the mirror. I just did a git pull on the module (seems like it was updated) and its now working again.
                            • SexyTroggS
                              SexyTrogg
                              Was anyone able to come up with a solution to the blank todo list? I am also having that problem where it displays the Header but no actual tasks. I get the same curl error as @mikmonken but I didn’t find what his solution was. I also tried running the fetcher.js files listed below but truth be told, I am a linux noob and I don’t know how to install requireJS. Any suggestions?
                                carteblanche
                                This module is working perfectly for me. As others mentioned it doesn’t work for the filters like Today, Week, etc. you can only assign it to specific lists that you create like “Work” for example.
                                SexyTroggS 1 Reply Last reply
                                • SexyTroggS
                                  SexyTrogg @carteblanche
                                  @carteblanche I’ve moved all my tasks to the inbox and tried using that. Still cant get a list to show. Other todo modules have worked immediately though so I may have to just switch over to one of them.
                                  C 1 Reply Last reply
                                    carteblanche @SexyTrogg
                                    @SexyTrogg You don’t need any of the tasks to be in the Inbox folder. You just need to create a new custom list of your todos separate from the auto generated folders that Wunderlist creates and call that list name out in the module config file.
                                    See a screenshot of my lists here…I can have either Work or Family show up on my mirror if I choose those names in the config file. But be careful it is case sensitive.
                                    • SexyTroggS
                                      SexyTrogg
                                      @carteblanche
                                      My set up is as follows:
                                      module: 'MMM-Wunderlist',
                                                             position: 'top_left',
                                                             header: 'Get this ish done',
                                                             accesToken: '----',
                                                             clientID: '----',
                                                             lists: ["Sports","Work"],
                                                             interval: 60,
                                                             fade: true
                                      Everything looks like it should work for me but again still just the black screen. Raspberry Pi 3 with the newest Wunderlist repo and updates.
                                        @SexyTrogg you have a typo on “accessToken:” in the config file.
                                        • SexyTroggS
                                          @carteblanche bah sorry that was a typo in the post not in my config :S
                                            @SexyTrogg damn…ok i assume you double checked your access token and client ID in the config match up perfectly with what you received from Wunderlist? Other than that I can’t think of any other reason why it wouldn’t show the lists.
                                            • 4 / 6
