    Wunderlist - your todos on the mirror
    113 Posts 27 Posters 208.4k Views 22 Watching
      Sunburned
      So I could not figure out why Wunderlist is freezing so just did a workaround by setting up a cron job to reset the pi twice a day and start up the mirror. So far that is working for me.
        pugsly @Sunburned
        @Sunburned I was having this problem where I would mark an item on my phone complete and it didn’t update on the mirror. I just did a git pull on the module (seems like it was updated) and its now working again.
        • SexyTroggS Offline
          SexyTrogg
          Was anyone able to come up with a solution to the blank todo list? I am also having that problem where it displays the Header but no actual tasks. I get the same curl error as @mikmonken but I didn’t find what his solution was. I also tried running the fetcher.js files listed below but truth be told, I am a linux noob and I don’t know how to install requireJS. Any suggestions?
            carteblanche
            This module is working perfectly for me. As others mentioned it doesn’t work for the filters like Today, Week, etc. you can only assign it to specific lists that you create like “Work” for example.
            SexyTroggS 1 Reply Last reply Reply Quote 0
              SexyTrogg @carteblanche
              @carteblanche I’ve moved all my tasks to the inbox and tried using that. Still cant get a list to show. Other todo modules have worked immediately though so I may have to just switch over to one of them.
                carteblanche @SexyTrogg
                @SexyTrogg You don’t need any of the tasks to be in the Inbox folder. You just need to create a new custom list of your todos separate from the auto generated folders that Wunderlist creates and call that list name out in the module config file.
                See a screenshot of my lists here…I can have either Work or Family show up on my mirror if I choose those names in the config file. But be careful it is case sensitive.
                  SexyTrogg
                  @carteblanche
                  My set up is as follows:
                  module: 'MMM-Wunderlist',
                                         position: 'top_left',
                                         header: 'Get this ish done',
                                         accesToken: '----',
                                         clientID: '----',
                                         lists: ["Sports","Work"],
                                         interval: 60,
                                         fade: true
                  Everything looks like it should work for me but again still just the black screen. Raspberry Pi 3 with the newest Wunderlist repo and updates.
                    @SexyTrogg you have a typo on “accessToken:” in the config file.
                      @carteblanche bah sorry that was a typo in the post not in my config :S
                        @SexyTrogg damn…ok i assume you double checked your access token and client ID in the config match up perfectly with what you received from Wunderlist? Other than that I can’t think of any other reason why it wouldn’t show the lists.
                          Sunburned
                          @pugsly Thanks for the suggestion. I gave repulling the app a shot and am still having the same issue, after a certain amount of time wunderlist decides to stop updating. It does seem to be lasting longer so i changed my cron job to restart the pi once a day and increased the wunderlist update interval to 120. We shall see how that works.
                            pugsly @Sunburned
                            @Sunburned Yeah i spoke too soon, the app is still not updating again after a few hours. I really don’t want to make a cron job and restart the mm. I think im going to give this one a try:
                            https://github.com/cbrooker/MMM-Todoist
                              Sunburned
                              Knock on wood… the wunderlist has been updating without issue. I have the pi and MM applicaiton restarting once a day at 2am and the interval is set at 120.
                              • H Offline
                                Headcrush
                                Hey guys,
                                i have the following problem:
                                • header will be shown
                                • list is empty
                                • The code in line 42 always returns “undefined”
                                it looks to be the same problem Kukielka58 had.
                                Did someone find out where the problem could be?
                                if i use:
                                curl -H “X-Access-Token: TOKEN” -H “X-Client-ID: ID” https://a.wunderlist.com/api/v1/lists
                                the console returns: “{“unauthorized”: true}” but i have no idea why.
                                this are my configs:
                                i hope someone can help me.
                                With best regards.
                                Headcrush
                                  Sunburned
                                  @Headcrush
                                  I would try increasing your interval. 1 may be too short. Try 100, or at least 60
                                  • H Offline
                                    Headcrush
                                    I got a hint via private message.
                                    The problem i had was something with the website of wunderlist.
                                    I deleted all cookies and the cache.
                                    Following i need to generate a new access token.
                                    Now its working.
                                    Special thanks to SexyTrogg.
                                    • cowboysdudeC Offline
                                      Been playing with this for 2 hours… same issues… blank lists… no real answers. NO errors in the console, throwin in the towel on this one… too much work for something simple. NEVER thought I’d say this but going to stick with Google Calendar… it just works.
                                        pugsly
                                        I kept having this same problem where it would stop pulling the To-Do’s so I switched to ToDoist and thought the problem was solver but low and behold it started doing it with ToDoist as well.
                                        Although I do like the interface of ToDoist much better so I think i am going to stick with this one my only resort is to set a cron job to restart the pi nightly before it goes to sleep and blanks out the monitor.
                                        anyone know how I can get PM2 to automatically restart at midnight rather then reboot the entire pi?
                                          Sunburned @pugsly
                                          @pugsly
                                          This is the page that I used to set up my cron job. I set it up to reset at 2am and start the mirror at 2:03.
                                            pugsly @Sunburned
                                            @Sunburned
                                            I don’t want to reboot, I just want to restart pm2 and I have added it to my crontab but it doesn’t seem to work.
                                            i see in the logs that cron has executed the command but the node process never restarts.
                                            • 5 / 6
