    Wunderlist - your todos on the mirror
    113 Posts 27 Posters 213.8k Views 22 Watching
      carteblanche
      This module is working perfectly for me. As others mentioned it doesn’t work for the filters like Today, Week, etc. you can only assign it to specific lists that you create like “Work” for example.
      SexyTroggS 1 Reply Last reply
      • SexyTroggS
        SexyTrogg @carteblanche
        @carteblanche I’ve moved all my tasks to the inbox and tried using that. Still cant get a list to show. Other todo modules have worked immediately though so I may have to just switch over to one of them.
        C 1 Reply Last reply
          carteblanche @SexyTrogg
          @SexyTrogg You don’t need any of the tasks to be in the Inbox folder. You just need to create a new custom list of your todos separate from the auto generated folders that Wunderlist creates and call that list name out in the module config file.
          See a screenshot of my lists here…I can have either Work or Family show up on my mirror if I choose those names in the config file. But be careful it is case sensitive.
          • SexyTroggS
            SexyTrogg
            @carteblanche
            My set up is as follows:
            module: 'MMM-Wunderlist',
                                   position: 'top_left',
                                   header: 'Get this ish done',
                                   accesToken: '----',
                                   clientID: '----',
                                   lists: ["Sports","Work"],
                                   interval: 60,
                                   fade: true
            Everything looks like it should work for me but again still just the black screen. Raspberry Pi 3 with the newest Wunderlist repo and updates.
              @SexyTrogg you have a typo on “accessToken:” in the config file.
              • SexyTroggS
                @carteblanche bah sorry that was a typo in the post not in my config :S
                  @SexyTrogg damn…ok i assume you double checked your access token and client ID in the config match up perfectly with what you received from Wunderlist? Other than that I can’t think of any other reason why it wouldn’t show the lists.
                    Sunburned
                    @pugsly Thanks for the suggestion. I gave repulling the app a shot and am still having the same issue, after a certain amount of time wunderlist decides to stop updating. It does seem to be lasting longer so i changed my cron job to restart the pi once a day and increased the wunderlist update interval to 120. We shall see how that works.
                    pugslyP 1 Reply Last reply
                    • pugslyP
                      pugsly @Sunburned
                      @Sunburned Yeah i spoke too soon, the app is still not updating again after a few hours. I really don’t want to make a cron job and restart the mm. I think im going to give this one a try:
                      https://github.com/cbrooker/MMM-Todoist
                        Sunburned
                        Knock on wood… the wunderlist has been updating without issue. I have the pi and MM applicaiton restarting once a day at 2am and the interval is set at 120.
                        • H
                          Headcrush
                          Hey guys,
                          i have the following problem:
                          • header will be shown
                          • list is empty
                          • The code in line 42 always returns “undefined”
                          it looks to be the same problem Kukielka58 had.
                          Did someone find out where the problem could be?
                          if i use:
                          curl -H “X-Access-Token: TOKEN” -H “X-Client-ID: ID” https://a.wunderlist.com/api/v1/lists
                          the console returns: “{“unauthorized”: true}” but i have no idea why.
                          this are my configs:
                          i hope someone can help me.
                          With best regards.
                          Headcrush
                            Sunburned
                            @Headcrush
                            I would try increasing your interval. 1 may be too short. Try 100, or at least 60
                            • H
                              Headcrush
                              I got a hint via private message.
                              The problem i had was something with the website of wunderlist.
                              I deleted all cookies and the cache.
                              Following i need to generate a new access token.
                              Now its working.
                              Special thanks to SexyTrogg.
                              • cowboysdudeC
                                Been playing with this for 2 hours… same issues… blank lists… no real answers. NO errors in the console, throwin in the towel on this one… too much work for something simple. NEVER thought I’d say this but going to stick with Google Calendar… it just works.
                                • pugslyP
                                  pugsly
                                  I kept having this same problem where it would stop pulling the To-Do’s so I switched to ToDoist and thought the problem was solver but low and behold it started doing it with ToDoist as well.
                                  Although I do like the interface of ToDoist much better so I think i am going to stick with this one my only resort is to set a cron job to restart the pi nightly before it goes to sleep and blanks out the monitor.
                                  anyone know how I can get PM2 to automatically restart at midnight rather then reboot the entire pi?
                                    Sunburned @pugsly
                                    @pugsly
                                    This is the page that I used to set up my cron job. I set it up to reset at 2am and start the mirror at 2:03.
                                    • pugslyP
                                      pugsly @Sunburned
                                      @Sunburned
                                      I don’t want to reboot, I just want to restart pm2 and I have added it to my crontab but it doesn’t seem to work.
                                      i see in the logs that cron has executed the command but the node process never restarts.
                                        Mar
                                        Im managed to get this up and running, great job!!
                                        The one thing I’m trying to do is create two of these modules one for to-do and one for another list to keep them separate as we cant tell what is on each list. but putting two modules throws an error? Has anyone managed to get two lists up (from the same wunderlist account) in two separate modules or lists (not as one big list on the mirror).
                                        O 1 Reply Last reply
                                        • O
                                          onetwankyfive @Mar
                                          @Mar mine worked fine
                                                  module: 'MMM-Todoist',
                                                  position: 'top_left',  // This can be any of the regions. Best results in left or right regions.
                                                  header: 'Alexa TO-DO List', // This is optional
                                                  config: { // See 'Configuration options' for more information.
                                                      accessToken: 'accesstokenaXXXXCXCC687',
                                                      maximumEntries: 60,
                                                      interval: 60,
                                                      lists: [ 12345 ],
                                                      fade: false
                                                  header: 'Alexa Shopping List', // This is optional
                                                      accessToken: 'XXXX',
                                                      maximumEntries: 60,
                                                      interval: 60,
                                                      lists: [ 1234 ],
                                                      fade: false
                                          M 1 Reply Last reply
                                          • Hein-JanH
                                            Hein-Jan
                                            I also have 2 Wunderlist/lists running one underneath the other.
                                            I also implemented this by having the module twice in the config.
                                            • 5 / 6
