    Wunderlist - your todos on the mirror
    113 Posts 27 Posters 213.8k Views 22 Watching
      Sunburned
      Knock on wood… the wunderlist has been updating without issue. I have the pi and MM applicaiton restarting once a day at 2am and the interval is set at 120.
      • H
        Headcrush
        Hey guys,
        i have the following problem:
        • header will be shown
        • list is empty
        • The code in line 42 always returns “undefined”
        it looks to be the same problem Kukielka58 had.
        Did someone find out where the problem could be?
        if i use:
        curl -H “X-Access-Token: TOKEN” -H “X-Client-ID: ID” https://a.wunderlist.com/api/v1/lists
        the console returns: “{“unauthorized”: true}” but i have no idea why.
        this are my configs:
        i hope someone can help me.
        With best regards.
        Headcrush
          Sunburned
          @Headcrush
          I would try increasing your interval. 1 may be too short. Try 100, or at least 60
          • H
            Headcrush
            I got a hint via private message.
            The problem i had was something with the website of wunderlist.
            I deleted all cookies and the cache.
            Following i need to generate a new access token.
            Now its working.
            Special thanks to SexyTrogg.
            • cowboysdudeC
              Been playing with this for 2 hours… same issues… blank lists… no real answers. NO errors in the console, throwin in the towel on this one… too much work for something simple. NEVER thought I’d say this but going to stick with Google Calendar… it just works.
              • pugslyP
                pugsly
                I kept having this same problem where it would stop pulling the To-Do’s so I switched to ToDoist and thought the problem was solver but low and behold it started doing it with ToDoist as well.
                Although I do like the interface of ToDoist much better so I think i am going to stick with this one my only resort is to set a cron job to restart the pi nightly before it goes to sleep and blanks out the monitor.
                anyone know how I can get PM2 to automatically restart at midnight rather then reboot the entire pi?
                  Sunburned @pugsly
                  @pugsly
                  This is the page that I used to set up my cron job. I set it up to reset at 2am and start the mirror at 2:03.
                  pugslyP 1 Reply Last reply
                  • pugslyP
                    pugsly @Sunburned
                    @Sunburned
                    I don’t want to reboot, I just want to restart pm2 and I have added it to my crontab but it doesn’t seem to work.
                    i see in the logs that cron has executed the command but the node process never restarts.
                      Mar
                      Im managed to get this up and running, great job!!
                      The one thing I’m trying to do is create two of these modules one for to-do and one for another list to keep them separate as we cant tell what is on each list. but putting two modules throws an error? Has anyone managed to get two lists up (from the same wunderlist account) in two separate modules or lists (not as one big list on the mirror).
                      O 1 Reply Last reply
                      • O
                        onetwankyfive @Mar
                        @Mar mine worked fine
                                module: 'MMM-Todoist',
                                position: 'top_left',  // This can be any of the regions. Best results in left or right regions.
                                header: 'Alexa TO-DO List', // This is optional
                                config: { // See 'Configuration options' for more information.
                                    accessToken: 'accesstokenaXXXXCXCC687',
                                    maximumEntries: 60,
                                    interval: 60,
                                    lists: [ 12345 ],
                                    fade: false
                                header: 'Alexa Shopping List', // This is optional
                                    accessToken: 'XXXX',
                                    maximumEntries: 60,
                                    interval: 60,
                                    lists: [ 1234 ],
                                    fade: false
                        M 1 Reply Last reply
                        • Hein-JanH
                          Hein-Jan
                          I also have 2 Wunderlist/lists running one underneath the other.
                          I also implemented this by having the module twice in the config.
                            Mar @onetwankyfive
                            @onetwankyfive Thanks, i couldnt figure out if it was not supported or something I did wrong. Appreciate you posting how you did it. Looks like it was my error. Thanks for the help! Glad that this works.
                              Mar
                              I’ve had two wunderlist lists running under each other for just under month now without issues, but now it seems like the lists are not updating at all?
                              I requested a new accesstoken and it worked again for a couple refreshes but ive come back and checked on it later in the day and the lists werent updating. I’ve restarted the MM and the lists dont seem to be loading at all.
                              It sort of seems like its rejecting the token, or the token is being locked out after some time. Has anyone else had this issue before?
                              edit: Also there are no errors at startup via pm2 logs.
                              Hein-JanH 1 Reply Last reply
                                bminer1
                                I have been running with 2 lists since the beginning of Jan. No issues with loading or the lists not updating. This may be an isolated incident. My wife and i are on the lists and either of us can add or delete. When we make a change, it changes on the mirror. Here is my config:
                                			"module": "MMM-Wunderlist",
                                			"position": "top_right",
                                			"header": "To Do",
                                			"config": {
                                				"accessToken": "Your Token Here",
                                				"clientID": "Your clientID here",
                                				"maximumEntries": 5,
                                				"order": "normal",
                                				"lists": [
                                					"To Do"
                                				"interval": 60,
                                				"fade": false,
                                				"fadePoint": 0.25
                                			"header": "Groceries",
                                			"config": {
                                				"maximumEntries": 15,
                                				"order": "normal",
                                				"lists": [
                                					"Groceries"
                                				"interval": 60,
                                				"fade": false,
                                				"fadePoint": 0.25
                                • Hein-JanH
                                  Hein-Jan @Mar
                                  @Mar
                                  I had similar problems. A search on the forum revealed that a daily reboot acts as a work-around. I am using the MMM-Remote-Control in combination with the MMM-ModuleScheduler for the nightly reboots.
                                  It works like a dream ever since.
                                    Mar @Hein-Jan
                                    @Hein-Jan Thanks for the workaround, i suppose rebooting nightly isnt ideal but if it fixes things I’ll give it a shot. I just don’t understand as it was working perfectly for so long, as I’m sure it is for others also. There must be something in either the wunderlist config or in the MM config that it doesnt like.
                                      cyberphox
                                      Is there actually a walkthrough on how to install this now that it asks for app URL and callback URL and what is supposed to be entered there?
                                        Mar
                                        Just used git pull to update to the latest wunderlist and all of a sudden it stopped working and MM wont load. Getting this in my pm2 logs:
                                        0|mm       | { Error: Cannot find module 'wunderlist'
                                        0|mm       |     at Function.Module._resolveFilename (module.js:470:15)
                                        0|mm       |     at Function.Module._load (module.js:418:25)
                                        0|mm       |     at Module.require (module.js:498:17)
                                        0|mm       |     at require (internal/module.js:20:19)
                                        0|mm       |     at Object. (/home/pi/MagicMirror/modules/MMM-Wunderlist/fetcher.js:10:21)
                                        0|mm       |     at Module._compile (module.js:571:32)
                                        0|mm       |     at Object.Module._extensions..js (module.js:580:10)
                                        0|mm       |     at Module.load (module.js:488:32)
                                        0|mm       |     at tryModuleLoad (module.js:447:12)
                                        0|mm       |     at Function.Module._load (module.js:439:3) code: 'MODULE_NOT_FOUND' }
                                        0|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                        0|mm       | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                        • strawberry 3.141S
                                          strawberry 3.141 Project Sponsor Module Developer @Mar
                                          @Mar there is a new dependency, so you have to run npm install in the MMM-Wunderlist directory
                                            Mar @strawberry 3.141
                                            @strawberry-3.141 Gotcha. thank you!
                                            • 5 / 6
