    Wunderlist - your todos on the mirror
    113 Posts 27 Posters 213.7k Views 22 Watching
    • O
      onetwankyfive @Mar
      @Mar mine worked fine
              module: 'MMM-Todoist',
              position: 'top_left',  // This can be any of the regions. Best results in left or right regions.
              header: 'Alexa TO-DO List', // This is optional
              config: { // See 'Configuration options' for more information.
                  accessToken: 'accesstokenaXXXXCXCC687',
                  maximumEntries: 60,
                  interval: 60,
                  lists: [ 12345 ],
                  fade: false
              header: 'Alexa Shopping List', // This is optional
                  accessToken: 'XXXX',
                  maximumEntries: 60,
                  interval: 60,
                  lists: [ 1234 ],
                  fade: false
      M 1 Reply Last reply
      • Hein-JanH
        Hein-Jan
        I also have 2 Wunderlist/lists running one underneath the other.
        I also implemented this by having the module twice in the config.
          Mar @onetwankyfive
          @onetwankyfive Thanks, i couldnt figure out if it was not supported or something I did wrong. Appreciate you posting how you did it. Looks like it was my error. Thanks for the help! Glad that this works.
            Mar
            I’ve had two wunderlist lists running under each other for just under month now without issues, but now it seems like the lists are not updating at all?
            I requested a new accesstoken and it worked again for a couple refreshes but ive come back and checked on it later in the day and the lists werent updating. I’ve restarted the MM and the lists dont seem to be loading at all.
            It sort of seems like its rejecting the token, or the token is being locked out after some time. Has anyone else had this issue before?
            edit: Also there are no errors at startup via pm2 logs.
            Hein-JanH 1 Reply Last reply
              bminer1
              I have been running with 2 lists since the beginning of Jan. No issues with loading or the lists not updating. This may be an isolated incident. My wife and i are on the lists and either of us can add or delete. When we make a change, it changes on the mirror. Here is my config:
              			"module": "MMM-Wunderlist",
              			"position": "top_right",
              			"header": "To Do",
              			"config": {
              				"accessToken": "Your Token Here",
              				"clientID": "Your clientID here",
              				"maximumEntries": 5,
              				"order": "normal",
              				"lists": [
              					"To Do"
              				"interval": 60,
              				"fade": false,
              				"fadePoint": 0.25
              			"header": "Groceries",
              			"config": {
              				"maximumEntries": 15,
              				"order": "normal",
              				"lists": [
              					"Groceries"
              				"interval": 60,
              				"fade": false,
              				"fadePoint": 0.25
              • Hein-JanH
                Hein-Jan @Mar
                @Mar
                I had similar problems. A search on the forum revealed that a daily reboot acts as a work-around. I am using the MMM-Remote-Control in combination with the MMM-ModuleScheduler for the nightly reboots.
                It works like a dream ever since.
                  Mar @Hein-Jan
                  @Hein-Jan Thanks for the workaround, i suppose rebooting nightly isnt ideal but if it fixes things I’ll give it a shot. I just don’t understand as it was working perfectly for so long, as I’m sure it is for others also. There must be something in either the wunderlist config or in the MM config that it doesnt like.
                    cyberphox
                    Is there actually a walkthrough on how to install this now that it asks for app URL and callback URL and what is supposed to be entered there?
                      Mar
                      Just used git pull to update to the latest wunderlist and all of a sudden it stopped working and MM wont load. Getting this in my pm2 logs:
                      0|mm       | { Error: Cannot find module 'wunderlist'
                      0|mm       |     at Function.Module._resolveFilename (module.js:470:15)
                      0|mm       |     at Function.Module._load (module.js:418:25)
                      0|mm       |     at Module.require (module.js:498:17)
                      0|mm       |     at require (internal/module.js:20:19)
                      0|mm       |     at Object. (/home/pi/MagicMirror/modules/MMM-Wunderlist/fetcher.js:10:21)
                      0|mm       |     at Module._compile (module.js:571:32)
                      0|mm       |     at Object.Module._extensions..js (module.js:580:10)
                      0|mm       |     at Module.load (module.js:488:32)
                      0|mm       |     at tryModuleLoad (module.js:447:12)
                      0|mm       |     at Function.Module._load (module.js:439:3) code: 'MODULE_NOT_FOUND' }
                      0|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                      0|mm       | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                      • strawberry 3.141S
                        strawberry 3.141 Project Sponsor Module Developer @Mar
                        @Mar there is a new dependency, so you have to run npm install in the MMM-Wunderlist directory
                          Mar @strawberry 3.141
                          @strawberry-3.141 Gotcha. thank you!
                            Mar @Mar
                            @strawberry-3-141 thanks again i got it (sort of) working.
                            Now it looks like only one of the wunderlist modules work. I have 2 modules in my config (that worked before the MM and WL update i just did) showing two different lists. Now only one of the lists works. Only list 2 worked the last day, and after doing another npm install only the first widget works… is anyone else having an issue using 2 lists (same account)?
                            • hartattackH
                              hartattack
                              Having some difficulties installing this one. I went to the Wunderlist page in the install guide, but it is asking for a Callback URL and App URL. What do I put here?
                                Mar @Mar
                                @Mar did a full reinstall of the module and still using 2 wunderlist widgets it will only ever show the list on one of them. Is there a way to go back to test the previous version of the module?
                                • strawberry 3.141S
                                  @Mar git checkout 2cdae25e1904835fbcaaee7c7cafe5adeb5907e6 to get the version before the changes on 2nd of april
                                    @strawberry-3.141 Awesome thanks. Then an npm install i assume?
                                    • F
                                      Flagun
                                      hi guys
                                      i had to reinstall my mirror today and when i was installing this module there was an error saying that one of the dependicies is obsolete.
                                      Now the list doesnt fade at some point :(
                                      Can someone check it please?
                                      • foxF
                                        fox @paviro
                                        @paviro said in Wunderlist - your todos on the mirror:
                                        @CGabo glad you find it useful :)
                                        works like a charm ! thx @paviro
                                        see https://forum.magicmirror.builders/post/23647
                                        Issues With MMM-WatchDog known?
                                        https://forum.magicmirror.builders/post/29827
                                        Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                                          pepemujica
                                          Hi @paviro !
                                          Great module.
                                          I was wondering if it is possible to add the bullet simbol to each task.
                                          Kind regards
                                          • 6 / 6
