    Wunderlist - your todos on the mirror
    113 Posts 27 Posters 213.8k Views 22 Watching
    • laknermiL
      laknermi @paviro
      @paviro In that case, your updated version works great! (Which by the way is incredibly cool!!! :dark_sunglasses: )
      paviroP 1 Reply Last reply
      • paviroP
        paviro @laknermi
        @laknermi glad you like it :slight_smile:
        – The Doctor
          jagerpower
          @paviro I reinstalled my MM and it works now. Thank you for this module
          Reply Quote 2
          • Wilco89W
            Wilco89
            Looks like i’ve got same issue,
            tried the Curl line you said before, that gives me the info tht is is all correct.
            but nothing shows up.
            • Wilco89W
              Wilco89
              Seems to work after a second npm install.
                mikmonken
                Hi, i’m having some problems with this too.
                tokens and client ID are generated, and wanderlist appears on my mirror but non of this list content.
                and when i run the curl command i get this.
                {“error”:{“type”:“server_error”,“translation_key”:“api_error_unknown”,“message”:“An unknown server error occurred”,“authentication”:[“missing”]}}
                i am a complete novice and just trying to follow instructions, but i’ve clearly messed up somewhere.
                Access token and client id are taken as the values that are labelled just that.
                heres what i have in my config.js ££££ have replaced numbers
                                        module: 'MMM-Wunderlist',
                                        position: 'left',  // This can be any of the regions. Best results in left or right regions.
                                        header: 'To Do', // This is optional
                                                accessToken:    '07ad3c20bb0500b£££££££££££££££££a759b6a7e07da2',
                                                clientID:       'f1££££££££££££££££££1eb',
                                                lists:          ["Inbox"],
                                                maximumEntries: '60',
                                                interval:       '1',
                                                fade:           'true',
                any help would be really appreciated.
                Note from Moderator: Please use Markdown on code snippets for easier reading.
                  mikmonken
                  OK strike that it does work, there seemed to be an issue with the browser version of wanderlist not syncing, which meant that despite it appearing to have content on it wasn’t sending it to the mirror.
                  All good now.
                  • paviroP
                    paviro
                    Glad you figured out how to fix it :)
                    – The Doctor
                    • K
                      Kukielka58
                      Greetings,
                      first of all, thanks for making the module!
                      Sadly I can’t really appreciate your work, because it doesn’t work for me. :(
                      I’m running magicMirror on a Contos7 VM on my Homeserver.
                      The code in the Line 42 always returns me “undefined”.
                      this.tasks[this.config.lists[i]]
                      However retrieving the tasks via curl seems fine.
                      Here is my Config:
                      			position: 'top_right',
                      			header: 'To-Do Liste',
                      				accessToken: '*********************************',
                      				clientId: '*********************',
                      				lists: ['inbox'],
                      				interval: 5,
                      				maximumEntries: 5,
                      				fade: true
                      I’m really looking forward to hear from you. :)
                      • paviroP
                        paviro
                        Are you sure this has nothing to do with your setup? Centos 7 is not officially supported.
                        – The Doctor
                        K 1 Reply Last reply
                        • K
                          Kukielka58 @paviro
                          @paviro I know that it’s not officially supported but everything else seems fine.
                          Maybe any dependencies I’m not awayre of? I already installed npm request manually.
                          • paviroP
                            paviro
                            Not sure this error seems off to me since I check if the variable is undefined… Well I am on holiday right now so I can’t really check anything, sorry :/
                            – The Doctor
                            K 2 Replies Last reply
                            • K
                              Kukielka58 @paviro
                              @paviro No Problem at all, hope you enjoy you holidays! :)
                              • K
                                Kukielka58 @paviro
                                @paviro After further inspection it seems like the array this.tasks = []; is always empty. which is why if (typeof this.tasks[this.config.lists[i]] != “undefined”) is always false. Any Ideas? :(
                                • paviroP
                                  paviro
                                  Please try using the fetcher_debug_client.js. You have to fill in your data in createFetcher("id", "Inbox", 1000, accessToken, clientID); at the bottom :) You can then run it with node fetcher_debug_client.js from the module directory.
                                  – The Doctor
                                  • K
                                    Kukielka58 @paviro
                                    @paviro Did exactly what you said. I ran node fetcher_debug_client.js from the /opt/MagicMirror/modules/MMM-Wunderlist/ directory and it seems to have worked.
                                    Create new todo fetcher for list: Inbox - Interval: 1000
                                    • K
                                      Kukielka58 @paviro
                                      @paviro said in Wunderlist - your todos on the mirror:
                                      Any progress so far?
                                        Sunburned
                                        Hey all,
                                        Love this module, just got it working and i think it is going to be really helpful staying organized. I am having one issue i was hoping to get some assistance with. New todo’s show up fine, however when one is marked as done, it does not disappear from the mirror, it will disappear from the phone app if i do it on the computer and vice versa. If i remove an item (or multiple items) and add something new then the completed items are removed. Any thoughts?
                                          Sunburned
                                          Has anyone encountered an issue where Wunderlist freezes? I am getting the module to show with my todo’s but they do not update after the magicmirror application has been running for more than about 18 hours. If i restart the magic mirror application it does update. As a side note, other modules on the mirror do update as well, so i am thinking it is possibly some freezing issue rather than a communication one.
                                            Sunburned
                                            So I could not figure out why Wunderlist is freezing so just did a workaround by setting up a cron job to reset the pi twice a day and start up the mirror. So far that is working for me.
                                            pugslyP 1 Reply Last reply
                                            • 4 / 6
