    Wunderlist - your todos on the mirror
    113 Posts 27 Posters 213.8k Views 22 Watching
    • laknermiL
      laknermi
      Sorry to start a new question thread but how do you determine the app url and auth callback url to get the token from Wunderlist? I know it must be very simple but I can’t seem to figure it out. Is the app url just http://localhost:8080?
      KirAsh4K paviroP 2 Replies Last reply
      • KirAsh4K
        KirAsh4 Moderator @laknermi
        @laknermi, you can start your own new topic with your question(s) posted. It’s preferred that way, so we keep the discussions on-topic for the original poster. And then someone more familiar with that module can reply to you.
        laknermiL 1 Reply Last reply
        • laknermiL
          laknermi @KirAsh4
          @KirAsh4 Thanks!
          • paviroP
            paviro @laknermi
            @laknermi does not matter just leave it as it is when you create the app.
            – The Doctor
            • paviroP
              paviro
              Hey all of you! :slight_smile:
              Please try again with the updated version from GitHub!
              Thanks to @MichMich for now knowing how to better handle API requests in Node :D
              – The Doctor
              • laknermiL
                laknermi @paviro
                @paviro Hmmm… The developer portal at Wunderlist will not allow me to create a new app if I don’t provide an app URL and Auth callback URL.
                paviroP 1 Reply Last reply
                • paviroP
                  paviro @laknermi
                  @laknermi then set it to http://localhost I thought it was the default.
                  – The Doctor
                  • laknermiL
                    laknermi @paviro
                    @paviro Okay. I’ll try creating a new token with app URL and callback URL set to http://localhost.
                    • laknermiL
                      laknermi @laknermi
                      @laknermi "@paviro
                      Referencing my post for posterity
                      I got it to work! I created a new app in Wunderlist and set the App URL to “https://a.wunderlist.com/api/v1/lists” and Auth Callback URL to “http://localhost:8080” then applied the accessToken and clientID as @jagerpower did above.
                      • paviroP
                        paviro @laknermi
                        @laknermi the App url should not be necessary :) or can be set to anything, like the callback too.
                        – The Doctor
                        • laknermiL
                          laknermi @paviro
                          @paviro In that case, your updated version works great! (Which by the way is incredibly cool!!! :dark_sunglasses: )
                          • paviroP
                            paviro @laknermi
                            @laknermi glad you like it :slight_smile:
                            – The Doctor
                              jagerpower
                              @paviro I reinstalled my MM and it works now. Thank you for this module
                              Reply Quote 2
                              • Wilco89W
                                Wilco89
                                Looks like i’ve got same issue,
                                tried the Curl line you said before, that gives me the info tht is is all correct.
                                but nothing shows up.
                                • Wilco89W
                                  Wilco89
                                  Seems to work after a second npm install.
                                    mikmonken
                                    Hi, i’m having some problems with this too.
                                    tokens and client ID are generated, and wanderlist appears on my mirror but non of this list content.
                                    and when i run the curl command i get this.
                                    {“error”:{“type”:“server_error”,“translation_key”:“api_error_unknown”,“message”:“An unknown server error occurred”,“authentication”:[“missing”]}}
                                    i am a complete novice and just trying to follow instructions, but i’ve clearly messed up somewhere.
                                    Access token and client id are taken as the values that are labelled just that.
                                    heres what i have in my config.js ££££ have replaced numbers
                                                            module: 'MMM-Wunderlist',
                                                            position: 'left',  // This can be any of the regions. Best results in left or right regions.
                                                            header: 'To Do', // This is optional
        accessToken:    '07ad3c20bb0500b£££££££££££££££££a759b6a7e07da2',
        clientID:       'f1££££££££££££££££££1eb',
        lists:          ["Inbox"],
        maximumEntries: '60',
        interval:       '1',
        fade:           'true',
                                    any help would be really appreciated.
                                    Note from Moderator: Please use Markdown on code snippets for easier reading.
                                      mikmonken
                                      OK strike that it does work, there seemed to be an issue with the browser version of wanderlist not syncing, which meant that despite it appearing to have content on it wasn’t sending it to the mirror.
                                      All good now.
                                      • paviroP
                                        paviro
                                        Glad you figured out how to fix it :)
                                        – The Doctor
                                        • K
                                          Kukielka58
                                          Greetings,
                                          first of all, thanks for making the module!
                                          Sadly I can’t really appreciate your work, because it doesn’t work for me. :(
                                          I’m running magicMirror on a Contos7 VM on my Homeserver.
                                          The code in the Line 42 always returns me “undefined”.
                                          this.tasks[this.config.lists[i]]
                                          However retrieving the tasks via curl seems fine.
                                          Here is my Config:
                                          			position: 'top_right',
                                          			header: 'To-Do Liste',
                                          				accessToken: '*********************************',
                                          				clientId: '*********************',
                                          				lists: ['inbox'],
                                          				interval: 5,
                                          				maximumEntries: 5,
                                          				fade: true
                                          I’m really looking forward to hear from you. :)
                                          • paviroP
                                            paviro
                                            Are you sure this has nothing to do with your setup? Centos 7 is not officially supported.
                                            – The Doctor
                                            K 1 Reply Last reply
                                            • 3 / 6
