    Wunderlist - your todos on the mirror
    113 Posts 27 Posters 209.1k Views 22 Watching
      jagerpower @paviro
      @paviro alt text
        paviro @jagerpower
        @jagerpower toggle the array that’s logged by the module anything in there?
        – The Doctor
          jagerpower @paviro
          @paviro alt text
            paviro @jagerpower
            @jagerpower also toggle the array in the array until there is nothing else to toggle…
            – The Doctor
              jagerpower @paviro
              @paviro do i need to toggle these too?
              alt text
                paviro @jagerpower
                @jagerpower sorry forgot about those… Will add a Screenshot to this post when I am home.
                – The Doctor
                • L Offline
                  laknermi
                  Sorry to start a new question thread but how do you determine the app url and auth callback url to get the token from Wunderlist? I know it must be very simple but I can’t seem to figure it out. Is the app url just http://localhost:8080?
                  K P 2 Replies Last reply Reply Quote 0
                  • K Offline
                    KirAsh4 Moderator @laknermi
                    @laknermi, you can start your own new topic with your question(s) posted. It’s preferred that way, so we keep the discussions on-topic for the original poster. And then someone more familiar with that module can reply to you.
                    • L Offline
                      laknermi @KirAsh4
                      @KirAsh4 Thanks!
                        paviro @laknermi
                        @laknermi does not matter just leave it as it is when you create the app.
                        – The Doctor
                          paviro
                          Hey all of you! :slight_smile:
                          Please try again with the updated version from GitHub!
                          Thanks to @MichMich for now knowing how to better handle API requests in Node :D
                          – The Doctor
                          • L Offline
                            laknermi @paviro
                            @paviro Hmmm… The developer portal at Wunderlist will not allow me to create a new app if I don’t provide an app URL and Auth callback URL.
                              paviro @laknermi
                              @laknermi then set it to http://localhost I thought it was the default.
                              – The Doctor
                              • L Offline
                                laknermi @paviro
                                @paviro Okay. I’ll try creating a new token with app URL and callback URL set to http://localhost.
                                • L Offline
                                  laknermi @laknermi
                                  @laknermi "@paviro
                                  Referencing my post for posterity
                                  I got it to work! I created a new app in Wunderlist and set the App URL to “https://a.wunderlist.com/api/v1/lists” and Auth Callback URL to “http://localhost:8080” then applied the accessToken and clientID as @jagerpower did above.
                                    paviro @laknermi
                                    @laknermi the App url should not be necessary :) or can be set to anything, like the callback too.
                                    – The Doctor
                                    • L Offline
                                      laknermi @paviro
                                      @paviro In that case, your updated version works great! (Which by the way is incredibly cool!!! :dark_sunglasses: )
                                        paviro @laknermi
                                        @laknermi glad you like it :slight_smile:
                                        – The Doctor
                                          jagerpower
                                          @paviro I reinstalled my MM and it works now. Thank you for this module
                                          • W Offline
                                            Wilco89
                                            Looks like i’ve got same issue,
                                            tried the Curl line you said before, that gives me the info tht is is all correct.
                                            but nothing shows up.
                                            • 3 / 6
