    Wunderlist - your todos on the mirror
    113 Posts 27 Posters 213.8k Views 22 Watching
    • laknermiL
      laknermi @KirAsh4
      @KirAsh4 Thanks!
      • paviroP
        paviro @laknermi
        @laknermi does not matter just leave it as it is when you create the app.
        – The Doctor
        laknermiL 1 Reply Last reply
        • paviroP
          paviro
          Hey all of you! :slight_smile:
          Please try again with the updated version from GitHub!
          Thanks to @MichMich for now knowing how to better handle API requests in Node :D
          – The Doctor
          • laknermiL
            laknermi @paviro
            @paviro Hmmm… The developer portal at Wunderlist will not allow me to create a new app if I don’t provide an app URL and Auth callback URL.
            paviroP 1 Reply Last reply
            • paviroP
              paviro @laknermi
              @laknermi then set it to http://localhost I thought it was the default.
              – The Doctor
              • laknermiL
                laknermi @paviro
                @paviro Okay. I’ll try creating a new token with app URL and callback URL set to http://localhost.
                • laknermiL
                  laknermi @laknermi
                  @laknermi "@paviro
                  Referencing my post for posterity
                  I got it to work! I created a new app in Wunderlist and set the App URL to “https://a.wunderlist.com/api/v1/lists” and Auth Callback URL to “http://localhost:8080” then applied the accessToken and clientID as @jagerpower did above.
                  • paviroP
                    paviro @laknermi
                    @laknermi the App url should not be necessary :) or can be set to anything, like the callback too.
                    – The Doctor
                    • laknermiL
                      laknermi @paviro
                      @paviro In that case, your updated version works great! (Which by the way is incredibly cool!!! :dark_sunglasses: )
                      • paviroP
                        paviro @laknermi
                        @laknermi glad you like it :slight_smile:
                        – The Doctor
                          jagerpower
                          @paviro I reinstalled my MM and it works now. Thank you for this module
                          Reply Quote 2
                          • Wilco89W
                            Wilco89
                            Looks like i’ve got same issue,
                            tried the Curl line you said before, that gives me the info tht is is all correct.
                            but nothing shows up.
                            • Wilco89W
                              Wilco89
                              Seems to work after a second npm install.
                                mikmonken
                                Hi, i’m having some problems with this too.
                                tokens and client ID are generated, and wanderlist appears on my mirror but non of this list content.
                                and when i run the curl command i get this.
                                {“error”:{“type”:“server_error”,“translation_key”:“api_error_unknown”,“message”:“An unknown server error occurred”,“authentication”:[“missing”]}}
                                i am a complete novice and just trying to follow instructions, but i’ve clearly messed up somewhere.
                                Access token and client id are taken as the values that are labelled just that.
                                heres what i have in my config.js ££££ have replaced numbers
                                                        module: 'MMM-Wunderlist',
                                                        position: 'left',  // This can be any of the regions. Best results in left or right regions.
                                                        header: 'To Do', // This is optional
        accessToken:    '07ad3c20bb0500b£££££££££££££££££a759b6a7e07da2',
        clientID:       'f1££££££££££££££££££1eb',
        lists:          ["Inbox"],
        maximumEntries: '60',
        interval:       '1',
        fade:           'true',
                                any help would be really appreciated.
                                Note from Moderator: Please use Markdown on code snippets for easier reading.
                                  mikmonken
                                  OK strike that it does work, there seemed to be an issue with the browser version of wanderlist not syncing, which meant that despite it appearing to have content on it wasn’t sending it to the mirror.
                                  All good now.
                                  • paviroP
                                    paviro
                                    Glad you figured out how to fix it :)
                                    – The Doctor
                                    • K
                                      Kukielka58
                                      Greetings,
                                      first of all, thanks for making the module!
                                      Sadly I can’t really appreciate your work, because it doesn’t work for me. :(
                                      I’m running magicMirror on a Contos7 VM on my Homeserver.
                                      The code in the Line 42 always returns me “undefined”.
                                      this.tasks[this.config.lists[i]]
                                      However retrieving the tasks via curl seems fine.
                                      Here is my Config:
                                      			position: 'top_right',
                                      			header: 'To-Do Liste',
                                      				accessToken: '*********************************',
                                      				clientId: '*********************',
                                      				lists: ['inbox'],
                                      				interval: 5,
                                      				maximumEntries: 5,
                                      				fade: true
                                      I’m really looking forward to hear from you. :)
                                      • paviroP
                                        paviro
                                        Are you sure this has nothing to do with your setup? Centos 7 is not officially supported.
                                        – The Doctor
                                        K 1 Reply Last reply
                                        • K
                                          Kukielka58 @paviro
                                          @paviro I know that it’s not officially supported but everything else seems fine.
                                          Maybe any dependencies I’m not awayre of? I already installed npm request manually.
                                          • paviroP
                                            paviro
                                            Not sure this error seems off to me since I check if the variable is undefined… Well I am on holiday right now so I can’t really check anything, sorry :/
                                            – The Doctor
                                            K 2 Replies Last reply
                                            • 3 / 6
