    Wunderlist - your todos on the mirror
    113 Posts 27 Posters 212.3k Views 22 Watching
      paviro @jagerpower
      @jagerpower check the log not the element should be another tab.
      – The Doctor
        CGabo
        @jagerpower You find it under “Console”
        Btw. changing the interval to 1, I wouldn’t recommend. It pulls the data every 1 sec, leave it to 60 (default) . I personally increased it to 3600 (1h).
          jagerpower
          @CGabo @paviro alt text
            paviro @jagerpower
            @jagerpower are there any log after that from the module?
            – The Doctor
              jagerpower @paviro
              @paviro alt text
                paviro @jagerpower
                @jagerpower toggle the array that’s logged by the module anything in there?
                – The Doctor
                  jagerpower @paviro
                  @paviro alt text
                    paviro @jagerpower
                    @jagerpower also toggle the array in the array until there is nothing else to toggle…
                    – The Doctor
                      jagerpower @paviro
                      @paviro do i need to toggle these too?
                      alt text
                        paviro @jagerpower
                        @jagerpower sorry forgot about those… Will add a Screenshot to this post when I am home.
                        – The Doctor
                        • L
                          laknermi
                          Sorry to start a new question thread but how do you determine the app url and auth callback url to get the token from Wunderlist? I know it must be very simple but I can’t seem to figure it out. Is the app url just http://localhost:8080?
                          K P 2 Replies Last reply Reply Quote 0
                          • K
                            KirAsh4 Moderator @laknermi
                            @laknermi, you can start your own new topic with your question(s) posted. It’s preferred that way, so we keep the discussions on-topic for the original poster. And then someone more familiar with that module can reply to you.
                            • L
                              laknermi @KirAsh4
                              @KirAsh4 Thanks!
                                paviro @laknermi
                                @laknermi does not matter just leave it as it is when you create the app.
                                – The Doctor
                                  paviro
                                  Hey all of you! :slight_smile:
                                  Please try again with the updated version from GitHub!
                                  Thanks to @MichMich for now knowing how to better handle API requests in Node :D
                                  – The Doctor
                                  • L
                                    laknermi @paviro
                                    @paviro Hmmm… The developer portal at Wunderlist will not allow me to create a new app if I don’t provide an app URL and Auth callback URL.
                                      paviro @laknermi
                                      @laknermi then set it to http://localhost I thought it was the default.
                                      – The Doctor
                                      • L
                                        laknermi @paviro
                                        @paviro Okay. I’ll try creating a new token with app URL and callback URL set to http://localhost.
                                        • L
                                          laknermi @laknermi
                                          @laknermi "@paviro
                                          Referencing my post for posterity
                                          I got it to work! I created a new app in Wunderlist and set the App URL to “https://a.wunderlist.com/api/v1/lists” and Auth Callback URL to “http://localhost:8080” then applied the accessToken and clientID as @jagerpower did above.
                                            paviro @laknermi
                                            @laknermi the App url should not be necessary :) or can be set to anything, like the callback too.
                                            – The Doctor
                                            • 3 / 6
