    MMM-Traffic - make text lighter ?
    10 Posts 4 Posters 5.8k Views 4 Watching
    • I Offline
      ironman_DK
      how can I make the highlighted text lighter (and only this text, not the text above )
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @ironman_DK
        @ironman_DK should be
        .MMM-Traffic div.small.dimmed {
          //your magic
        but couldn’t test it
        • I Offline
          ironman_DK @strawberry 3.141
          @strawberry-3.141 what do you mean do I have to delete it or … I guess that the text regarding the text is here :
          //routeName
          if (this.config.route_name) {
          routeName.className = ‘dimmed small’;
          if (this.summary.length > 0 && this.config.show_summary){
          routeName.innerHTML = this.config.route_name + ’ ’ + this.config.summaryText + ’ ’ + this.summary;
          } else {
          routeName.innerHTML = this.config.route_name;
            Mykle1 Project Sponsor Module Developer @ironman_DK
            @ironman_DK said in MMM-Traffic - make text lighter ?:
            I think he means make a custon.css entry with the info he gave you rather than change the module files
            • I Offline
              ironman_DK @Mykle1
              @Mykle1 I have solved the problem, I had to add bright in the text :
              //routeName
              routeName.className = ‘bright small’;
              routeName.innerHTML = this.config.route_name + ’ ’ + this.config.summaryText + ’ ’ + this.summary + ’ ’ + this.config.arriveByText + ’ ’ + this.config.arrival_time.substring(0,2) + “:” + this.config.arrival_time.substring(2,4);
              } else {
              console.log(typeof this.config.arrival_time );
              routeName.innerHTML = this.config.route_name + ’ ’ + this.config.arriveByText + ’ ’ + this.config.arrival_time.substring(0,2) + “:” + this.config.arrival_time.substring(2,4);
              Mykle1M P 2 Replies Last reply Reply Quote 0
                That’s one way of doing it but they never recommend changing the module file. That is why he gave you a custom.css entry. If that module gets updated you will lose your changes. If you had made the change in the custom.css file then you would not lose your changes if the module gets updated.
                Peace
                • P Offline
                  pjkoeleman @ironman_DK
                  @ironman_DK Thats not the way to do this.
                  Do it this way:
                  • When you don’t have a custom.css create one in /MagicMirror/css
                  • Add the following code to custom.css
                  color: #00FF00;
                  Now you have the text in green but you can change that as you like.
                  I 1 Reply Last reply Reply Quote 1
                  • P Offline
                    pjkoeleman @Mykle1
                    @Mykle1
                    I’am not that fast in typing and testing it …
                      Mykle1 Project Sponsor Module Developer @pjkoeleman
                      @pjkoeleman
                      I beat you by 1ms ;-)
                      • I Offline
                        ironman_DK @pjkoeleman
                        @pjkoeleman ahh off course,I have done it, Thnak you for your help :-)
