    Fitbit
    129 Posts 42 Posters 226.2k Views 37 Watching
    • StoffbeuteluweS
      Stoffbeuteluwe Project Sponsor
      Hi is the module still working ?.???.
      • V
        voodew @bhepler
        @bhepler
        This post helped me the most.
        • Example config file on the module GitHub page contains errors. The character after config: should be {, not [
        • The secret key and appID field values need to be surrounded by single quotes, something not explained in the readme file.
        Thank you.
        • Arno-StrasbourgA
          Arno-Strasbourg
          Hi guys,
          I don’t know if the module is still maintained. But I have just implemented it. I have got the credentiels. I have put the code in the config.js file. It works fine but I have no datas refresh and an error in the log :
          /home/pi/.pm2/logs/mm-error.log last 15 lines:
          0|mm | [2020-05-10 13:41:56.342] [ERROR] TypeError: PythonShell.run is not a function
          0|mm | at Class.setCreds (/home/pi/MagicMirror/modules/MMM-fitbit/node_helper.js:32:15)
          0|mm | at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-fitbit/node_helper.js:18:9)
          0|mm | at Socket. (/home/pi/MagicMirror/js/node_helper.js:113:11)
          0|mm | at Socket.emit (events.js:200:13)
          0|mm | at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
          0|mm | at processTicksAndRejections (internal/process/task_queues.js:82:9)
          0|mm | [2020-05-10 13:41:56.380] [ERROR] TypeError: PythonShell is not a constructor
          0|mm | at Class.getData (/home/pi/MagicMirror/modules/MMM-fitbit/node_helper.js:43:25)
          0|mm | at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-fitbit/node_helper.js:22:9)
          0|mm | [2020-05-10 13:43:43.317] [LOG]
          0|mm | Set credential request recieved.
          0|mm | [2020-05-10 13:43:43.318] [LOG]
          0|mm | {
          0|mm | client_id: '22BR8T',
          0|mm | client_secret: '51313d185cxxxxxxxxxxxxxxxxd141c99'
          0|mm | }
          0|mm | [2020-05-10 13:43:43.329] [LOG]
          0|mm | Whoops! There was an uncaught exception...
          0|mm | [2020-05-10 13:43:43.330] [ERROR] TypeError: PythonShell.run is not a function
          0|mm | [2020-05-10 13:43:43.334] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          0|mm | [2020-05-10 13:43:43.335] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          0|mm | [2020-05-10 13:43:43.336] [LOG] Initial run request recieved.
          0|mm | [2020-05-10 13:43:43.338] [LOG] Running getData.py
          0|mm | [2020-05-10 13:43:43.339] [LOG] Whoops! There was an uncaught exception...
          0|mm | [2020-05-10 13:43:43.342] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          0|mm | [2020-05-10 13:43:43.342] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          0|mm | [2020-05-10 13:43:43.344] [LOG] [NewPIR] Initialize...
          0|mm | [2020-05-10 13:43:43.340] [ERROR] TypeError: PythonShell is not a constructor
          Do someone has any idea of that error ?
          StoffbeuteluweS 1 Reply Last reply
          • StoffbeuteluweS
            Stoffbeuteluwe Project Sponsor @Arno-Strasbourg
            @Arno-Strasbourg Hey, please install MMM-Fitbit2 that works perfect.:thumbs_up_medium-light_skin_tone:
            • Arno-StrasbourgA
              Arno-Strasbourg
              Oh ! There is an other app !! Where can I found it ? It isn’t on the gitub third party modules ?
              Edit : Got it ! Thank you @Stoffbeuteluwe
              • StoffbeuteluweS
                @Arno-Strasbourg https://github.com/m-roberts/MMM-Fitbit2
                • Arno-StrasbourgA
                  Arno-Strasbourg
                  Yes I confirm, it works very well !! Thank you very much !!
                  Just a small question, I put it on the bottom_bar, but it appear on the bottom left.
                  How can i center it please ? with the MMM-Fitbit2.css or custom.css ? and wich command to add ?
                  That makes 2 questions in fact ! :face_with_hand_over_mouth:
                  • StoffbeuteluweS
                    @Arno-Strasbourg you can try bottom_center
                    Arno-StrasbourgA 1 Reply Last reply
                    • Arno-StrasbourgA
                      Arno-Strasbourg @Stoffbeuteluwe
                      @Stoffbeuteluwe It isn’t exactly the bottom bar. But it’s ok. It will be good for me.
                      Thank you !
                      • 6
                      • 7
                      • 7 / 7
