    Looking for Austrian Testers
    16 Posts 4 Posters 8.8k Views 4 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @nogE
      @nogE can you send me your config to investigate?
      nogEN 1 Reply Last reply Reply Quote 0
      • nogEN Offline
        nogE
        please take a look.
        		"module": "MMM-Fuel",
        		"position": "bottom_right",
        		"config": {
        			"lat": 48.131927,
        			"lng": 13.463719,
        			"types": [
        				"diesel"
        			"provider": "spritpreisrechner"
        		"classes": "default for_all"
        thx
        • nogEN Offline
          nogE @strawberry 3.141
          @strawberry-3.141
          wrong config file. sorry
          		"config": {
          			"lat": 48.131927,
          			"lng": 13.463719,
          			"types": [
          				"diesel",
          				"e5"
            @nogE if you want diesel and benzin you have to do
            types: [
              "diesel",
              "e5"
            EDIT ok i will check it
            EDIT2 ok found an issue, trying to fix it now.
            • nogEN Offline
              @strawberry-3.141
              maby it could help: my config.js file is created with MMM-Admin-Interface
                @nogE the problem was related to the code not the config
                should be fixed now, get the changes with git pull inside the MMM-Fuel directory.
                • nogEN Offline
                  @strawberry-3.141
                  works perfect!! thx for fast response!
                  Greetings from Upper Austria (vlg Mostschädln)
                    Thanks for testing.
                    I released the new features to the master branch, you can go back there by git checkout master and git pull in the MMM-Fuel directory.
                    • nogEN Offline
                      @strawberry-3.141
                      nice tool. installed, config and run with no problems. I has a question: is it possible to switch maps without MMM-voice?
                        @nogE that is not possible. In which way the user should be able to toggle the map?
