    Looking for Austrian Testers
    16 Posts 4 Posters 9.9k Views 4 Watching
    • nogEN
      nogE
      Installed --> startet --> works perfectly, all filling stations around me are visible. Good work!!
      cu
      Egon
      • nogEN
        nogE
        “normal” Benzin e5 not working
        • strawberry 3.141S
          strawberry 3.141 Project Sponsor Module Developer @nogE
          @nogE can you send me your config to investigate?
          nogEN 1 Reply Last reply
          • nogEN
            nogE
            please take a look.
            		"module": "MMM-Fuel",
            		"position": "bottom_right",
            		"config": {
            			"lat": 48.131927,
            			"lng": 13.463719,
            			"types": [
            				"diesel"
            			"provider": "spritpreisrechner"
            		"classes": "default for_all"
            thx
            • nogEN
              nogE @strawberry 3.141
              @strawberry-3.141
              wrong config file. sorry
              		"config": {
              			"lat": 48.131927,
              			"lng": 13.463719,
              			"types": [
              				"diesel",
              				"e5"
              • strawberry 3.141S
                @nogE if you want diesel and benzin you have to do
                types: [
                  "diesel",
                  "e5"
                EDIT ok i will check it
                EDIT2 ok found an issue, trying to fix it now.
                • nogEN
                  @strawberry-3.141
                  maby it could help: my config.js file is created with MMM-Admin-Interface
                  • strawberry 3.141S
                    @nogE the problem was related to the code not the config
                    should be fixed now, get the changes with git pull inside the MMM-Fuel directory.
                    • nogEN
                      @strawberry-3.141
                      works perfect!! thx for fast response!
                      Greetings from Upper Austria (vlg Mostschädln)
                      • strawberry 3.141S
                        Thanks for testing.
                        I released the new features to the master branch, you can go back there by git checkout master and git pull in the MMM-Fuel directory.
                        • nogEN
                          @strawberry-3.141
                          nice tool. installed, config and run with no problems. I has a question: is it possible to switch maps without MMM-voice?
                          • strawberry 3.141S
                            @nogE that is not possible. In which way the user should be able to toggle the map?
                              schlachtkreuzer6
                              @strawberry-3-141 OMG! Thank you so much :smile:
                                schlachtkreuzer6 @strawberry 3.141
                                @strawberry-3.141 works great!
