    Looking for Austrian Testers
    16 Posts 4 Posters 9.9k Views 4 Watching
    • nogEN
      nogE
      “normal” Benzin e5 not working
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @nogE
        @nogE can you send me your config to investigate?
        nogEN 1 Reply Last reply
        • nogEN
          nogE
          please take a look.
          		"module": "MMM-Fuel",
          		"position": "bottom_right",
          		"config": {
          			"lat": 48.131927,
          			"lng": 13.463719,
          			"types": [
          				"diesel"
          			"provider": "spritpreisrechner"
          		"classes": "default for_all"
          thx
          • nogEN
            nogE @strawberry 3.141
            @strawberry-3.141
            wrong config file. sorry
            		"config": {
            			"lat": 48.131927,
            			"lng": 13.463719,
            			"types": [
            				"diesel",
            				"e5"
            • strawberry 3.141S
              @nogE if you want diesel and benzin you have to do
              types: [
                "diesel",
                "e5"
              EDIT ok i will check it
              EDIT2 ok found an issue, trying to fix it now.
              • nogEN
                @strawberry-3.141
                maby it could help: my config.js file is created with MMM-Admin-Interface
                • strawberry 3.141S
                  @nogE the problem was related to the code not the config
                  should be fixed now, get the changes with git pull inside the MMM-Fuel directory.
                  • nogEN
                    @strawberry-3.141
                    works perfect!! thx for fast response!
                    Greetings from Upper Austria (vlg Mostschädln)
                    • strawberry 3.141S
                      Thanks for testing.
                      I released the new features to the master branch, you can go back there by git checkout master and git pull in the MMM-Fuel directory.
                      • nogEN
                        @strawberry-3.141
                        nice tool. installed, config and run with no problems. I has a question: is it possible to switch maps without MMM-voice?
                        • strawberry 3.141S
                          @nogE that is not possible. In which way the user should be able to toggle the map?
                            schlachtkreuzer6
                            @strawberry-3-141 OMG! Thank you so much :smile:
                              schlachtkreuzer6 @strawberry 3.141
                              @strawberry-3.141 works great!
