    Looking for Austrian Testers
    16 Posts 4 Posters 8.9k Views 4 Watching
    • strawberry 3.141S Offline
      I created an addon for my module MMM-Fuel.
      [card:fewieden/MMM-Fuel]
      Now it also supports Austria’s gas stations.
      To test do the following:
      git clone https://github.com/fewieden/MMM-Fuel.git
      cd MMM-Fuel
      git checkout develop
      npm install --productive
      Then add the module to the config file (for Austria there is no API key needed).
          module: "MMM-Fuel",
              lat: 48.19659782973711,
              lng: 16.183596614516993,
              types: ["diesel"], // spritpreisrechner.at supports the types "diesel", "e5" and "gas"
              provider: "spritpreisrechner",
      @kurt @schlachtkreuzer6 @flo80 @spedja @cpramhofer @gerbin @Pegasus @schmo90 @miek
      K nogEN schlachtkreuzer6S 3 Replies Last reply Reply Quote 1
      • K Offline
        kurt @strawberry 3.141
        @strawberry-3.141
        Hi
        Installed yesterday this modul and it’s working fine, first showing the stations with the lowest prices and after a while the ones which are nearest to the koordinates you gave in under lat: and lng:
        Cool thing for us :flag_at: and Thanks a lot strawberry for your help again, as I am not a champ in installing modules :rolling_eyes:
        Greetings from Vienna
        kurt
                               module: "MMM-Fuel",
                               lat: 48.218403,
                               lng: 16.331819,
                               types: ["diesel", "e5"], // spritpreisrechner.at supports the types "diesel", "e5" and "gas"
        • nogEN Offline
          nogE
          Installed --> startet --> works perfectly, all filling stations around me are visible. Good work!!
          cu
          Egon
          • nogEN Offline
            nogE
            “normal” Benzin e5 not working
            strawberry 3.141S 1 Reply Last reply Reply Quote 1
              strawberry 3.141 Project Sponsor Module Developer @nogE
              @nogE can you send me your config to investigate?
              nogEN 1 Reply Last reply Reply Quote 0
              • nogEN Offline
                nogE
                please take a look.
                		"module": "MMM-Fuel",
                		"position": "bottom_right",
                		"config": {
                			"lat": 48.131927,
                			"lng": 13.463719,
                			"types": [
                				"diesel"
                			"provider": "spritpreisrechner"
                		"classes": "default for_all"
                thx
                • nogEN Offline
                  nogE @strawberry 3.141
                  @strawberry-3.141
                  wrong config file. sorry
                  		"config": {
                  			"lat": 48.131927,
                  			"lng": 13.463719,
                  			"types": [
                  				"diesel",
                  				"e5"
                    @nogE if you want diesel and benzin you have to do
                    types: [
                      "diesel",
                      "e5"
                    EDIT ok i will check it
                    EDIT2 ok found an issue, trying to fix it now.
                    • nogEN Offline
                      @strawberry-3.141
                      maby it could help: my config.js file is created with MMM-Admin-Interface
                        @nogE the problem was related to the code not the config
                        should be fixed now, get the changes with git pull inside the MMM-Fuel directory.
