    How to use "require" in a module?
    4 Posts 3 Posters 4.2k Views 2 Watching
      mbalfour
      I’m trying to make my first module. A pretty simple one, I just want to display the IP address of my Raspberry Pi. (I’m not assigning it a static addr, so if it changes I’d like to know the new addr to remote into)
      A quick google turned up some code for querying for your local IP address. However, it’s not working. I’m getting “Uncaught ReferenceError: require is not defined”. Am I missing something silly here? (Yes, I know the actual ip-getting code is commented out, I’ll bring it back once I can get the reference to os working)
      Here’s the code:
      var os = require("os");
      Module.register("my_ip", {
          // Default module config.
      	defaults: {
          // Override dom generator.
      	getDom: function () {
      	    var ip = location.host;
      	    var ifaces = os.networkInterfaces();
      	    Object.keys(ifaces).forEach(function (ifname) {
      	        var alias = 0;
      	        ifaces[ifname].forEach(function (iface) {
      	            if ('IPv4' !== iface.family || iface.internal !== false) {
      	                // skip over internal (i.e. 127.0.0.1) and non-ipv4 addresses
      	                return;
      	            if (alias >= 1) {
      	                // this single interface has multiple ipv4 addresses
      	                console.log(ifname + ':' + alias, iface.address);
                          ip = iface.address;
      	            } else {
      	                // this interface has only one ipv4 adress
      	                console.log(ifname, iface.address);
                          ip = iface.address;
      	            ++alias;
      	    wrapper.innerHTML = ip;
      		return wrapper;
      • strawberry 3.141S Offline
        take a look into the documentation on how to write a module, especially the part with node_helper
          mbalfour
          Thanks! I’ve got it working with node_helper now. It seems a bit convoluted though, since my module now sends a socket notification to request the IP, and listens for the socket notification to refresh the local variable and redraw the DOM. Is this actually the correct way to do it?
          • K Offline
            KirAsh4 Moderator
            That’s how the node_helper method works, module sends a request, the node_helper.js script responds.
