    Weather info not showing up on screen
    12 Posts 3 Posters 7.4k Views 2 Watching
      mar4pack
      Total newbie to this. I have everything up and running, but for some reason my current weather and weather forecast will not show up on my screen. I have my location id entered in, and my API key also entered into the config file. I have read other forums on the topic, but still cannot get the info to show on my screen. Any help would be appreciated.
        Mykle1 Project Sponsor Module Developer @mar4pack
        @mar4pack
        That’s usually a config issue. Post your config (without API key) here so we can take a look at it. I’m assuming your other modules work eg. clock?
          mar4pack
          /* Magic Mirror Config Sample
          • By Michael Teeuw http://michaelteeuw.nl
          • MIT Licensed.
          var config = {
          port: 8080,
          ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses.
          language: "en",
          timeFormat: 12,
          units: "metric",
          		module: "alert",
          		module: "updatenotification",
          		position: "top_bar"
          		module: "clock",
          		position: "top_left"
          		header: "US Holidays",
          					symbol: "calendar-check-o ",
          					url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
          		module: "compliments",
          		position: "lower_third"
          		module: "currentweather",
          			locationID: "4542765",  //ID from http://www.openweathermap.org/help/city_list.txt
          			appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
          		module: "weatherforecast",
          		header: "Weather Forecast",
          			appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
          		module: "newsfeed",
          		position: "bottom_bar",
          			feeds: [
          					title: "New York Times",
          			showSourceTitle: true,
          			showPublishDate: true
          if (typeof module !== “undefined”) {module.exports = config;}
            mar4pack @Mykle1
            @Mykle1
            Yes clock works and other modules load. Oddly enough I was able to get the weather underground module working.
            brobergB Mykle1M 2 Replies Last reply Reply Quote 0
            • brobergB Offline
              broberg Project Sponsor @mar4pack
              @mar4pack Do note, that the API used for the default weather modules are not foolproof, It usually takes time for the API-key to get valid and sometimes it will just stop sending data for your location. This will happen from time to time (as I have noticed) and this has nothing to do with the MagicMirror, the config or the modules, it’s just a lack of data from the service provider.
              In my cases it usually works again in a 24H time period. (it has happen twice in 7 weeks)
                @mar4pack said in Weather info not showing up on screen:
                I think @broberg may be right, unless you entered your API key incorrectly. As a test, I entered your location: "Midwest City, OK", and your locationID: "4542765", into my weatherforecast, using my appid: and it loaded right up without a hitch.
                  mar4pack @Mykle1
                  Still cannot get it to work. I created another appid and that does not work either. Entered both id’s in correctly and it wont load. Any other suggestions?
                    Even removing the header option altogether still worked for me. Below you see the location: empty and it still works.
                    			disabled: false,
                    				appid: "MY API KEY"
                    Did you do an automatic install?
                    Manual install?
                    Upgrade from 2.1.0?
                      mar4pack @Mykle1
                      Automatic install. Following one of the guides on here where you end up removing unnecessary programs and cleaning up the pi a little bit.
                        @mar4pack
                        Yes, this one I assume.
                        https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
