Weather info not showing up on screen
12 Posts 3 Posters 7.0k Views 2 Watching
    mar4pack
    Total newbie to this. I have everything up and running, but for some reason my current weather and weather forecast will not show up on my screen. I have my location id entered in, and my API key also entered into the config file. I have read other forums on the topic, but still cannot get the info to show on my screen. Any help would be appreciated.
    M 1 Reply Last reply Apr 14, 2017, 5:26 AM Reply Quote 0
      Mykle1 Project Sponsor Module Developer @mar4pack
      @mar4pack
      That’s usually a config issue. Post your config (without API key) here so we can take a look at it. I’m assuming your other modules work eg. clock?
      M 1 Reply Last reply Apr 14, 2017, 5:40 AM Reply Quote 0
        mar4pack
        /* Magic Mirror Config Sample
        • MIT Licensed.
        var config = {
        port: 8080,
        ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses.
        language: "en",
        timeFormat: 12,
        units: "metric",
        		module: "alert",
        		module: "updatenotification",
        		position: "top_bar"
        		module: "clock",
        		position: "top_left"
        		header: "US Holidays",
        					symbol: "calendar-check-o ",
        		module: "compliments",
        		position: "lower_third"
        		module: "currentweather",
        			locationID: "4542765",  //ID from http://www.openweathermap.org/help/city_list.txt
        			appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
        		module: "weatherforecast",
        		header: "Weather Forecast",
        			appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
        		module: "newsfeed",
        		position: "bottom_bar",
        			feeds: [
        					title: "New York Times",
        			showSourceTitle: true,
        			showPublishDate: true
        if (typeof module !== “undefined”) {module.exports = config;}
          mar4pack @Mykle1
          @Mykle1
          Yes clock works and other modules load. Oddly enough I was able to get the weather underground module working.
          B M 2 Replies Last reply Apr 14, 2017, 9:43 AM Reply Quote 0
            broberg Project Sponsor @mar4pack
            @mar4pack Do note, that the API used for the default weather modules are not foolproof, It usually takes time for the API-key to get valid and sometimes it will just stop sending data for your location. This will happen from time to time (as I have noticed) and this has nothing to do with the MagicMirror, the config or the modules, it’s just a lack of data from the service provider.
            In my cases it usually works again in a 24H time period. (it has happen twice in 7 weeks)
              @mar4pack said in Weather info not showing up on screen:
              I think @broberg may be right, unless you entered your API key incorrectly. As a test, I entered your location: "Midwest City, OK", and your locationID: "4542765", into my weatherforecast, using my appid: and it loaded right up without a hitch.
              M 1 Reply Last reply Apr 14, 2017, 2:57 PM Reply Quote 0
                mar4pack @Mykle1
                Still cannot get it to work. I created another appid and that does not work either. Entered both id’s in correctly and it wont load. Any other suggestions?
                M 1 Reply Last reply Apr 14, 2017, 3:22 PM Reply Quote 0
                  Even removing the header option altogether still worked for me. Below you see the location: empty and it still works.
                  			disabled: false,
                  				appid: "MY API KEY"
                  Did you do an automatic install?
                  Manual install?
                  Upgrade from 2.1.0?
                  M 1 Reply Last reply Apr 14, 2017, 3:27 PM Reply Quote 0
                    mar4pack @Mykle1
                    Automatic install. Following one of the guides on here where you end up removing unnecessary programs and cleaning up the pi a little bit.
                    M 2 Replies Last reply Apr 14, 2017, 3:29 PM Reply Quote 0
                      @mar4pack
                      Yes, this one I assume.
                      https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
