    Wifi isolation for pir sensor
    7 Posts 2 Posters 3.4k Views 2 Watching
    • V Offline
      vicdilou
      Hello
      I read that it was necessary to put a ferrite bead around the cables, I try but it doesn’t work. You know how to do it and where on the cable ?
      Thank you :)
      johnnyboyJ 1 Reply Last reply Reply Quote 0
      • johnnyboyJ Offline
        johnnyboy @vicdilou
        This post is deleted!
        • V Offline
          vicdilou @johnnyboy
          @johnnyboy the sensor will be about sixty centimeters of raspberry
            johnnyboy @vicdilou
            • V Offline
              vicdilou @johnnyboy
              @johnnyboy I used several cables
              I have to put all the cables in the ferrite bead ?
                johnnyboy @vicdilou
                • V Offline
                  vicdilou @johnnyboy
                  @johnnyboy There is no break in connection I think, I use this to test the sensor and it says always “Motion detected”.
                  from gpiozero import MotionSensor
                  import time
                  pir = MotionSensor(4)
                  while True: #repeat this forever
                      if pir.motion_detected: # if motion is detected print the message
                          print("Motion detected!")
                      if not pir.motion_detected: # if no motion is detected print the message
                          print("No motion detected!")
                      time.sleep(1)
