    MMM-Bergfex doesent load respectively should be a valid spdx license expression
    30 Posts 6 Posters 19.5k Views 6 Watching
    • G Offline
      gianienderlin
      to be honest, I don’t know what I’ve changed, too long ago. but it works for me
      • G Offline
        gianienderlin @gianienderlin
        oh sorry, i cant upload my files…
        Error
        You do not have enough privileges for this action
          marphi1602
          Has anybody solved the issue? I am facing also the “loading” issue. I was thinking of that a certain ski area doesn´t exist anymore, but I took only one (Hintertux) which is definitely open and listed on the web page… In case somebody solved the issue, please upload your files.
            astrakid
            not yet, i am waiting for the files of gianienderlin, then i can find out what is the fix.
            • G Offline
              gianienderlin
              here are my custom files. please let me know if they work.
              http://www.filehosting.org/file/details/705911/MMM-bergfex.zip
              M H 2 Replies Last reply Reply Quote 0
                astrakid
                @gianienderlin said in MMM-Bergfex doesent load respectively should be a valid spdx license expression:
                as far as i could see there is one main change in node_helper.js:
                instead of
                var sys = require(‘sys’);
                he uses
                var util = require(‘util’);
                regards,
                andre
                  marphi1602 @gianienderlin
                  @gianienderlin worked for me! The only thing what I´ve changed was the const in node_helper.js.
                  Due to the fact that I am more interested in seeing the results of the Austrian ski resorts I put // Constants
                  const URL = “http://www.bergfex.at/oesterreich/schneewerte/”;
                  Thank you!
                  • G Offline
                    gianienderlin
                    yes this is possible: -) but thought there was more…
                      marphi1602
                      anybody knows how I have to set ‘Kitzbühel - Kirchberg’ to the config? I think I am struggling with the “ü” same also for special characters like “-”… In case I am putting Kitzbühel into the config it says loading…
                        astrakid
                        @marphi1602 said in MMM-Bergfex doesent load respectively should be a valid spdx license expression:
                        it works for me without an issue. my config part:
                                                module: 'MMM-bergfex',
                                                position: 'top_right',
                                                classes: 'small dimmed',
                                                    updateInterval: 30*60*1000,
                                                    animationSpeed: 0,
                                                    header: 'Schneebericht',
                                                        skiareas: [
        'Fieberbrunn - Saalbach Hinterglemm Leogang',
        'Kitzbühel - Kirchberg',
                                                        shortenArea: 20,
                                                        cssclassrow: 'normal',
                                                        cssclassheader: 'bright'
                        edit: which ‘locale’ are you using? i have “C” configured except “LANGUAGE=” and “LC_ALL=”.
                        edit2: maybe you can try this (this is what is visible in the logfile): ‘Kitzbhel - Kirchberg’
                        • 3 / 3
