MMM-Bergfex doesent load respectively should be a valid spdx license expression
30 Posts 6 Posters 16.5k Views 6 Watching
  • G Offline
    gianienderlin
    Hi
    I have problems with installation from MMM-Bergfex.
    During the installation the warning comes MMM-Bregfex should be a valid spdx license expression.
    What does it mean?
    Thanks for your help
      astrakid
      same issue here for me… tried lots of different snow areas, at least only one, but still only “loading…”.
      R 1 Reply Last reply Jan 3, 2018, 6:23 PM Reply Quote 0
      • G Offline
        gianienderlin
        hello astrakid
        meanwhile the module works without errors. I had to make some adjustments to the files. if you are interested, I can send you my files.
        greetings giani
        A 1 Reply Last reply Oct 31, 2017, 6:37 PM Reply Quote 0
          astrakid @gianienderlin
          @gianienderlin
          That would be cool. Or put ut in here for ithers as well.
          • G Offline
            gianienderlin
            to be honest, I don’t know what I’ve changed, too long ago. but it works for me
            G 1 Reply Last reply Nov 2, 2017, 1:36 PM Reply Quote 0
            • G Offline
              gianienderlin @gianienderlin
              oh sorry, i cant upload my files…
              Error
              You do not have enough privileges for this action
                marphi1602
                Has anybody solved the issue? I am facing also the “loading” issue. I was thinking of that a certain ski area doesn´t exist anymore, but I took only one (Hintertux) which is definitely open and listed on the web page… In case somebody solved the issue, please upload your files.
                  astrakid
                  not yet, i am waiting for the files of gianienderlin, then i can find out what is the fix.
                  • G Offline
                    gianienderlin
                    here are my custom files. please let me know if they work.
                    http://www.filehosting.org/file/details/705911/MMM-bergfex.zip
                    M H 2 Replies Last reply Nov 6, 2017, 7:54 PM Reply Quote 0
                      astrakid
                      @gianienderlin said in MMM-Bergfex doesent load respectively should be a valid spdx license expression:
                      as far as i could see there is one main change in node_helper.js:
                      instead of
                      var sys = require(‘sys’);
                      he uses
                      var util = require(‘util’);
                      regards,
                      andre
