    MMM-Bergfex doesent load respectively should be a valid spdx license expression
    30 Posts 6 Posters 19.6k Views 6 Watching
      astrakid @gianienderlin
      @gianienderlin
      That would be cool. Or put ut in here for ithers as well.
      • G Offline
        gianienderlin
        to be honest, I don’t know what I’ve changed, too long ago. but it works for me
        • G Offline
          gianienderlin @gianienderlin
          oh sorry, i cant upload my files…
          Error
          You do not have enough privileges for this action
            marphi1602
            Has anybody solved the issue? I am facing also the “loading” issue. I was thinking of that a certain ski area doesn´t exist anymore, but I took only one (Hintertux) which is definitely open and listed on the web page… In case somebody solved the issue, please upload your files.
              astrakid
              not yet, i am waiting for the files of gianienderlin, then i can find out what is the fix.
              • G Offline
                gianienderlin
                here are my custom files. please let me know if they work.
                http://www.filehosting.org/file/details/705911/MMM-bergfex.zip
                M H 2 Replies Last reply Reply Quote 0
                  astrakid
                  @gianienderlin said in MMM-Bergfex doesent load respectively should be a valid spdx license expression:
                  as far as i could see there is one main change in node_helper.js:
                  instead of
                  var sys = require(‘sys’);
                  he uses
                  var util = require(‘util’);
                  regards,
                  andre
                    marphi1602 @gianienderlin
                    @gianienderlin worked for me! The only thing what I´ve changed was the const in node_helper.js.
                    Due to the fact that I am more interested in seeing the results of the Austrian ski resorts I put // Constants
                    const URL = “http://www.bergfex.at/oesterreich/schneewerte/”;
                    Thank you!
                    • G Offline
                      gianienderlin
                      yes this is possible: -) but thought there was more…
                        marphi1602
                        anybody knows how I have to set ‘Kitzbühel - Kirchberg’ to the config? I think I am struggling with the “ü” same also for special characters like “-”… In case I am putting Kitzbühel into the config it says loading…
