    MMM-Bergfex doesent load respectively should be a valid spdx license expression
    30 Posts 6 Posters 19.6k Views 6 Watching
    • G Offline
      gianienderlin
      hello astrakid
      meanwhile the module works without errors. I had to make some adjustments to the files. if you are interested, I can send you my files.
      greetings giani
        astrakid @gianienderlin
        @gianienderlin
        That would be cool. Or put ut in here for ithers as well.
        • G Offline
          gianienderlin
          to be honest, I don’t know what I’ve changed, too long ago. but it works for me
          • G Offline
            gianienderlin @gianienderlin
            oh sorry, i cant upload my files…
            Error
            You do not have enough privileges for this action
              marphi1602
              Has anybody solved the issue? I am facing also the “loading” issue. I was thinking of that a certain ski area doesn´t exist anymore, but I took only one (Hintertux) which is definitely open and listed on the web page… In case somebody solved the issue, please upload your files.
                astrakid
                not yet, i am waiting for the files of gianienderlin, then i can find out what is the fix.
                • G Offline
                  gianienderlin
                  here are my custom files. please let me know if they work.
                  http://www.filehosting.org/file/details/705911/MMM-bergfex.zip
                  M H 2 Replies Last reply Reply Quote 0
                    astrakid
                    @gianienderlin said in MMM-Bergfex doesent load respectively should be a valid spdx license expression:
                    as far as i could see there is one main change in node_helper.js:
                    instead of
                    var sys = require(‘sys’);
                    he uses
                    var util = require(‘util’);
                    regards,
                    andre
                      marphi1602 @gianienderlin
                      @gianienderlin worked for me! The only thing what I´ve changed was the const in node_helper.js.
                      Due to the fact that I am more interested in seeing the results of the Austrian ski resorts I put // Constants
                      const URL = “http://www.bergfex.at/oesterreich/schneewerte/”;
                      Thank you!
                      • G Offline
                        gianienderlin
                        yes this is possible: -) but thought there was more…
