    MMM-Bergfex doesent load respectively should be a valid spdx license expression
    30 Posts 6 Posters 18.9k Views 6 Watching
    • G Offline
      gianienderlin
      Hi
      I have problems with installation from MMM-Bergfex.
      During the installation the warning comes MMM-Bregfex should be a valid spdx license expression.
      What does it mean?
      Thanks for your help
        astrakid
        same issue here for me… tried lots of different snow areas, at least only one, but still only “loading…”.
        • G Offline
          gianienderlin
          hello astrakid
          meanwhile the module works without errors. I had to make some adjustments to the files. if you are interested, I can send you my files.
          greetings giani
            astrakid @gianienderlin
            @gianienderlin
            That would be cool. Or put ut in here for ithers as well.
            • G Offline
              gianienderlin
              to be honest, I don’t know what I’ve changed, too long ago. but it works for me
              • G Offline
                gianienderlin @gianienderlin
                oh sorry, i cant upload my files…
                Error
                You do not have enough privileges for this action
                  marphi1602
                  Has anybody solved the issue? I am facing also the “loading” issue. I was thinking of that a certain ski area doesn´t exist anymore, but I took only one (Hintertux) which is definitely open and listed on the web page… In case somebody solved the issue, please upload your files.
                    astrakid
                    not yet, i am waiting for the files of gianienderlin, then i can find out what is the fix.
                    • G Offline
                      gianienderlin
                      here are my custom files. please let me know if they work.
                      http://www.filehosting.org/file/details/705911/MMM-bergfex.zip
                      M H 2 Replies Last reply Reply Quote 0
                        astrakid
                        @gianienderlin said in MMM-Bergfex doesent load respectively should be a valid spdx license expression:
                        as far as i could see there is one main change in node_helper.js:
                        instead of
                        var sys = require(‘sys’);
                        he uses
                        var util = require(‘util’);
                        regards,
                        andre
