    MMM-PIR-Sensor with RelayPin and execute script
    9 Posts 3 Posters 5.4k Views 3 Watching
    • nogEN
      nogE
      My goal is: PIR Sensor detect presence and switch the relay pin. Additionally it should execute ah script hue_on.sh to switch MirrorLight on.
      Scripts works fine form CLI
      In which position of the node_helper.js from MMM-PIR-Sensor Module i put the lines
      exec(“/home/pi/scripts/hue_on.sh”, null);
      exec(“/home/pi/scripts/hue_off.sh”, null);
      pls help
      thx
      • B
        Blackmirror
        I have build in this python script in tho rc.local
        import RPi.GPIO as GPIO
        import time
        #Board Mode: Angabe der Pin-Nummer
        GPIO.setmode(GPIO.BOARD)
        #GPIO Pin definieren fuer den Dateneingang vom Sensor
        PIR_GPIO = 13
        Relay_GPIO = 37
        GPIO.setup(PIR_GPIO, GPIO.IN)
        GPIO.setup(Relay_GPIO, GPIO.OUT)
        GPIO.output(Relay_GPIO, True)
        GPIO.setup(32,GPIO.IN)
        read=0
        wait=0
        ein=0
        button=1
        while True :
           #PIR auslesen
           read = GPIO.input(PIR_GPIO)
           button = GPIO.input(32)
           if ((read==1 or button==0) and wait==0):
             GPIO.output(Relay_GPIO, False)
             wait=1
             ein=1
             time.sleep(0.5)
           elif ein==1 and button==0:
             ein=0
             time.sleep(0.5)
        • nogEN
          nogE
          Hi Blackmirror,
          thx for helping, i am no coders.
          pls can you explain me, howto it works to start with your script my hue_on.sh and hue.off.sh scripts?
          best regards
          Egon
          • nogEN
            nogE
            Sorry i understand. MMM-PIR-Sensor config with no RelayPin config. Make RelayPin with your script.
            • B
              Blackmirror @nogE
              @nogE
              The MMM-PIR-Sensor module have not work at me.
              So i make a new datei this the name PIR.py in my home - ordner.
              And add python PIR.py in the rc.local
              After this was switch the PIR on the GPIO-Pin 13 the relay-pin 37. Add pin 32 i have a button to open the relay manual.
              • nogEN
                nogE
                when execute the python script (python /home/pi/scripts/light.py), i got following error:
                File “/home/pi/scripts/light.py”, line 22
                • nogEN
                  nogE
                  i got an error when i run python script. now the whole error message:
                  IndentationError: expected an indented block
                  thx
                  • Y
                    yawns Moderator @nogE
                    @nogE
                    Python is a bit tricky. Unlike other languages python needs proper indentation. Make sure you don’t mix up tabs and whitespaces. Best practice is to use 4 whitespaces instead of one tab.
                    • B
                      Blackmirror
                      Yes, the error code says, you have not enought whitespaces before the lines.
