    http request
    53 Posts 7 Posters 48.1k Views 6 Watching
      acdacd2
      is that correct ?
      		module: 'MMM-HTTPRequestDisplay',
      		position: 'bottom_bar',	// This can be any of the regions. Best results in left or right regions.
      		header: 'MMM-HTTPRequestDisplay', // This is optional
      			accessToken: 'http://api.openweathermap.org/data/2.5/weather?q=London,uk&mode=xml',
      Note from Moderator: Please use Markdown on code snippets for easier reading.
      • E Offline
        Eunanibus Module Developer
        Sorry, I made a lot of mistakes on the README it seems.
        Instead of
        accessToken : "http://etc"
        use
        httpRequestURL: "http://etc"
        apologies
          acdacd2
          no problemo,
          with this config, black screen
          			httpRequestURL: 'http://192.168.1.248:8889/status.xml',
          • E Offline
            Make sure that you’re not just copy and pasting blindly into your config file.
            After each
            etc
            Note the comma , after the module. That comma should only be there if there are more modules.
            Likewise, if you’re pasting it last, you need to make sure the module before it has one, to let the script know there are more modules after the previous one.
            So the pattern is
               module: ‘firstModule’,
               option : ""
            }, <<< COMMA HERE
               module: ‘middleModule’,
               option : ""
            }, <<< COMMA HERE
               module: ‘last module’,
               option : ""
            } <<<<< NO COMMA
            hope that makes sense. hopefully that’s the problem.
              acdacd2
              This post is deleted!
                acdacd2
                • E Offline
                  Can you Zip up and upload your config file somewhere I can download it and I’ll take a look? Somewhere like pastebin.
                  • KirAsh4K Offline
                    KirAsh4 Moderator
                    Hey @acdacd2, please use proper Markdown when posting code. It really isn’t that hard to do and it makes it so much easier and pleasant for others to read, and possibly find errors quicker. Specifically you need to use back ticks before and after your code:
                         like so. Note that a back tick is not the same as the normal apostrophe, ` versus ' .
                    • E Offline
                      @KirAsh4 can you confirm MM startup with my module with this config file?
                      The module won’t show any results but MM should boot?
                      • KirAsh4K Offline
                        KirAsh4 Moderator
                        The file ‘status.xml’ doesn’t exist on my system, so it gets a 404 returned, however it does load up, and it does work.
                        • 6
                        • 3 / 6
