    MMM-awesome-alexa
    241 Posts 43 Posters 446.4k Views 47 Watching
      sdetweil @uok825
      @uok825 not lite, right?
      U 1 Reply Last reply Reply Quote 0
      • U
        uok825 @sdetweil
        @sdetweil not lite but “Raspberry Pi OS (32-bit) with desktop” is it problem?
        • not recommend software
          sdetweil @uok825
          @uok825 thats the correct version, all good…
          • U
            uok825 @sdetweil
            pi@raspberrypi:~ $ pm2 logs --lines=100
            [TAILING] Tailing last 100 lines for [all] processes (change the value with --lines option)
            /home/pi/.pm2/pm2.log last 100 lines:
            PM2        | 2020-06-26T19:32:13: PM2 log: App [MagicMirror:0] starting in -fork mode-
            PM2        | 2020-06-26T19:32:14: PM2 log: App [MagicMirror:0] online
            /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
            /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
            0|MagicMir |
            0|MagicMir | > magicmirror@2.11.0 start /home/pi/MagicMirror
            0|MagicMir | > ./run-start.sh $1
            0|MagicMir |
            0|MagicMir | [2020-06-26 19:32:39.858] [LOG] Starting MagicMirror: v2.11.0
            0|MagicMir | [2020-06-26 19:32:40.063] [LOG] Loading config ...
            0|MagicMir | [2020-06-26 19:32:40.158] [LOG] Loading module helpers ...
            0|MagicMir | [2020-06-26 19:32:40.196] [LOG] No helper found for module: alert.
            0|MagicMir | [2020-06-26 19:32:41.395] [LOG] Initializing new module helper ...
            0|MagicMir | [2020-06-26 19:32:41.428] [LOG] Module helper loaded: updatenotification
            0|MagicMir | [2020-06-26 19:32:41.451] [LOG] No helper found for module: clock.
            0|MagicMirror  | [2020-06-26 19:32:48.510] [LOG] Initializing new module helper ...
            0|MagicMirror  | [2020-06-26 19:32:48.525] [LOG] Module helper loaded: calendar
            0|MagicMirror  | [2020-06-26 19:32:48.537] [LOG] No helper found for module: currentweather.
            0|MagicMirror  | [2020-06-26 19:32:48.551] [LOG] No helper found for module: weatherforecast.
            0|MagicMirror  | [2020-06-26 19:32:49.314] [LOG] Initializing new module helper ...
            0|MagicMirror  | [2020-06-26 19:32:49.334] [LOG] Module helper loaded: newsfeed
            0|MagicMirror  | [2020-06-26 19:32:53.427] [LOG] Initializing new module helper ...
            0|MagicMirror  | [2020-06-26 19:32:53.442] [LOG] Module helper loaded: MMM-Screencast
            0|MagicMirror  | [2020-06-26 19:32:53.478] [LOG] Initializing new module helper ...
            0|MagicMirror  | [2020-06-26 19:32:53.505] [LOG] Module helper loaded: MMM-LICE
            0|MagicMirror  | [2020-06-26 19:33:03.595] [LOG] Initializing new module helper ...
            0|MagicMirror  | [2020-06-26 19:33:03.605] [LOG] Module helper loaded: MMM-awesome-alexa
            0|MagicMirror  | [2020-06-26 19:33:03.624] [LOG] All module helpers loaded.
            0|MagicMirror  | [2020-06-26 19:33:05.811] [LOG] Starting server on port 8080 ...
            0|MagicMirror  | [2020-06-26 19:33:05.999] [LOG] Server started ...
            0|MagicMirror  | [2020-06-26 19:33:06.043] [LOG] Connecting socket for: updatenotification
            0|MagicMirror  | [2020-06-26 19:33:06.071] [LOG] Connecting socket for: calendar
            0|MagicMirror  | [2020-06-26 19:33:06.113] [LOG] Starting node helper for: calendar
            0|MagicMirror  | [2020-06-26 19:33:06.134] [LOG] Connecting socket for: newsfeed
            0|MagicMirror  | [2020-06-26 19:33:06.160] [LOG] Starting module: newsfeed
            0|MagicMirror  | [2020-06-26 19:33:06.165] [LOG] Connecting socket for: MMM-Screencast
            0|MagicMirror  | [2020-06-26 19:33:06.207] [LOG] Connecting socket for: MMM-LICE
            0|MagicMirror  | [2020-06-26 19:33:06.231] [LOG] Starting node_helper for: MMM-LICE
            0|MagicMirror  | [2020-06-26 19:33:06.265] [LOG] Connecting socket for: MMM-awesome-alexa
            0|MagicMirror  | [2020-06-26 19:33:06.293] [LOG] Sockets connected & modules started ...
            0|MagicMirror  | [2020-06-26 19:33:06.320] [LOG]
            0|MagicMirror  | Ready to go! Please point your browser to: http://0.0.0.0:8080
            0|MagicMirror  | Starting chromium browser now, have patience, it takes a minute
            0|MagicMirror  | [2020-06-26 19:33:06.989] [LOG]
            0|MagicMirror  | Whoops! There was an uncaught exception...
            0|MagicMirror  | [2020-06-26 19:33:07.071] [ERROR]
            0|MagicMirror  | { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
            0|MagicMirror  |     at Server.setupListenHandle [as _listen2] (net.js:1280:14)
            0|MagicMirror  |     at listenInCluster (net.js:1328:12)
            0|MagicMirror  |     at doListen (net.js:1461:7)
            0|MagicMirror  |     at process._tickCallback (internal/process/next_tick.js:63:19)
            0|MagicMirror  |     at Function.Module.runMain (internal/modules/cjs/loader.js:834:11)
            0|MagicMirror  |     at startup (internal/bootstrap/node.js:283:19)
            0|MagicMirror  |     at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
            0|MagicMirror  |   code: 'EADDRINUSE',
            0|MagicMirror  |   errno: 'EADDRINUSE',
            0|MagicMirror  |   syscall: 'listen',
            0|MagicMirror  |   address: '0.0.0.0',
            0|MagicMirror  |   port: 8080 }
            0|MagicMirror  | [2020-06-26 19:33:07.445] [LOG]
            0|MagicMirror  | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            0|MagicMirror  | [2020-06-26 19:33:07.470] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            0|MagicMirror  | [2020-06-26 19:34:39.220] [LOG]
            0|MagicMirror  | Use existing news fetcher for url: http://www.cumhuriyet.com.tr/rss/son_dakika.xml
            0|MagicMirror  | [2020-06-26 19:34:46.507] [LOG]
            0|MagicMirror  | Use existing news fetcher for url: https://www.birgun.net/xml/rss.xml
            0|MagicMirror  | [2020-06-26 19:34:46.823] [LOG]
            0|MagicMirror  | Use existing news fetcher for url: https://www.sozcu.com.tr/sitemap_google_news.xml
            PM2            | App [MagicMirror:0] exited with code [0] via signal [SIGINT]
            PM2            | App [MagicMirror:0] starting in -fork mode-
            PM2            | App [MagicMirror:0] online
            0|MagicMirror  | > magicmirror@2.11.0 start /home/pi/MagicMirror
            0|MagicMirror  | > ./run-start.sh $1
            0|MagicMirror  | [2020-06-26 19:35:35.559] [LOG] Starting MagicMirror: v2.11.0
            0|MagicMirror  | [2020-06-26 19:35:35.698] [LOG] Loading config ...
            0|MagicMirror  | [2020-06-26 19:35:35.787] [LOG] Loading module helpers ...
            0|MagicMirror  | [2020-06-26 19:35:35.832] [LOG] No helper found for module: alert.
            0|MagicMirror  | [2020-06-26 19:35:36.721] [LOG] Initializing new module helper ...
            0|MagicMirror  | [2020-06-26 19:35:36.746] [LOG] Module helper loaded: updatenotification
            0|MagicMirror  | [2020-06-26 19:35:36.775] [LOG] No helper found for module: clock.
            0|MagicMirror  | [2020-06-26 19:35:42.002] [LOG] Initializing new module helper ...
            0|MagicMirror  | [2020-06-26 19:35:42.018] [LOG] Module helper loaded: calendar
            0|MagicMirror  | [2020-06-26 19:35:42.042] [LOG] No helper found for module: currentweather.
            0|MagicMirror  | [2020-06-26 19:35:42.061] [LOG] No helper found for module: weatherforecast.
            0|MagicMirror  | [2020-06-26 19:35:42.609] [LOG] Initializing new module helper ...
            0|MagicMirror  | [2020-06-26 19:35:42.622] [LOG] Module helper loaded: newsfeed
            0|MagicMirror  | [2020-06-26 19:35:46.278] [LOG] Initializing new module helper ...
            0|MagicMirror  | [2020-06-26 19:35:46.292] [LOG] Module helper loaded: MMM-Screencast
            0|MagicMirror  | [2020-06-26 19:35:46.347] [LOG] Initializing new module helper ...
            0|MagicMirror  | [2020-06-26 19:35:46.355] [LOG] Module helper loaded: MMM-LICE
            0|MagicMirror  | [2020-06-26 19:35:58.302] [LOG] Initializing new module helper ...
            0|MagicMirror  | [2020-06-26 19:35:58.317] [LOG] Module helper loaded: MMM-awesome-alexa
            0|MagicMirror  | [2020-06-26 19:35:58.344] [LOG] All module helpers loaded.
            0|MagicMirror  | [2020-06-26 19:36:00.278] [LOG] Starting server on port 8080 ...
            0|MagicMirror  | [2020-06-26 19:36:00.469] [LOG] Server started ...
            0|MagicMirror  | [2020-06-26 19:36:00.497] [LOG] Connecting socket for: updatenotification
            0|MagicMirror  | [2020-06-26 19:36:00.543] [LOG] Connecting socket for: calendar
            0|MagicMirror  | [2020-06-26 19:36:00.571] [LOG] Starting node helper for: calendar
            0|MagicMirror  | [2020-06-26 19:36:00.605] [LOG] Connecting socket for: newsfeed
            0|MagicMirror  | [2020-06-26 19:36:00.621] [LOG] Starting module: newsfeed
            0|MagicMirror  | [2020-06-26 19:36:00.651] [LOG] Connecting socket for: MMM-Screencast
            0|MagicMirror  | [2020-06-26 19:36:00.694] [LOG] Connecting socket for: MMM-LICE
            0|MagicMirror  | [2020-06-26 19:36:00.725] [LOG] Starting node_helper for: MMM-LICE
            0|MagicMirror  | [2020-06-26 19:36:00.755] [LOG] Connecting socket for: MMM-awesome-alexa
            0|MagicMirror  | [2020-06-26 19:36:00.780] [LOG] Sockets connected & modules started ...
            0|MagicMirror  | [2020-06-26 19:36:00.815] [LOG]
            0|MagicMirror  | [2020-06-26 19:36:01.577] [LOG]
            0|MagicMirror  | [2020-06-26 19:36:01.640] [ERROR]
            0|MagicMirror  | [2020-06-26 19:36:02.095] [LOG]
            0|MagicMirror  | [2020-06-26 19:36:02.111] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            She is not wake up with “Alexa”
            S U 2 Replies Last reply Reply Quote 0
              sdetweil @uok825
              @uok825 u have it running already at boot…
              pm2 stop all
              • U
                uok825 @uok825
                @uok825 How can i fix the problem? Alexa don’t wake up.
                  sdetweil @uok825
                  @uok825 shut down all the magic Mirror servers…
                  do
                  pm2 status
                  show the results here
                  then
                  pm2 stop all
                  check to make sure none are running
                  ps -ef | grep MagicMirror
                  once all are stopped, then
                  pm2 start 0
                  then test
                  • U
                    uok825 @sdetweil
                    @sdetweil Still same, don’t wake up
                      sdetweil @uok825
                      @uok825 show me the logs
                      • U
                        uok825 @sdetweil
                        @sdetweil ```
                        PM2 | 2020-06-26T22:31:59: PM2 log: pid=2328 msg=failed to kill - retrying in 100ms
                        PM2 | 2020-06-26T22:32:00: PM2 log: pid=2328 msg=failed to kill - retrying in 100ms
                        PM2 | 2020-06-26T22:32:00: PM2 log: Process with pid 2328 still alive after 1600ms, sending it SIGKILL now…
                        PM2 | 2020-06-26T22:32:04: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGKILL]
                        PM2 | 2020-06-26T22:32:04: PM2 log: pid=2328 msg=process killed
                        PM2 | 2020-06-26T22:32:04: PM2 log: App [MagicMirror:0] starting in -fork mode-
                        PM2 | 2020-06-26T22:32:04: PM2 log: App [MagicMirror:0] online
                        PM2 | 2020-06-26T22:43:21: PM2 log: Stopping app:MagicMirror id:0
                        PM2 | 2020-06-26T22:43:25: PM2 log: pid=2675 msg=failed to kill - retrying in 100ms
                        PM2 | 2020-06-26T22:43:26: PM2 log: pid=2675 msg=failed to kill - retrying in 100ms
                        PM2 | 2020-06-26T22:43:27: PM2 log: pid=2675 msg=failed to kill - retrying in 100ms
                        PM2 | 2020-06-26T22:43:27: PM2 log: Process with pid 2675 still alive after 1600ms, sending it SIGKILL now…
                        PM2 | 2020-06-26T22:43:30: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGKILL]
                        PM2 | 2020-06-26T22:43:30: PM2 log: pid=2675 msg=process killed
                        PM2 | 2020-06-26T22:43:30: PM2 log: App [MagicMirror:0] starting in -fork mode-
                        PM2 | 2020-06-26T22:43:30: PM2 log: App [MagicMirror:0] online
                        PM2 | 2020-06-26T23:37:35: PM2 log: Stopping app:MagicMirror id:0
                        PM2 | 2020-06-26T23:37:38: PM2 log: pid=3078 msg=failed to kill - retrying in 100ms
                        PM2 | 2020-06-26T23:37:39: PM2 log: pid=3078 msg=failed to kill - retrying in 100ms
                        PM2 | 2020-06-26T23:37:40: PM2 log: pid=3078 msg=failed to kill - retrying in 100ms
                        PM2 | 2020-06-26T23:37:40: PM2 log: Process with pid 3078 still alive after 1600ms, sending it SIGKILL now…
                        PM2 | 2020-06-26T23:37:43: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGKILL]
                        PM2 | 2020-06-26T23:37:43: PM2 log: pid=3078 msg=process killed
                        PM2 | 2020-06-26T23:37:43: PM2 log: App [MagicMirror:0] starting in -fork mode-
                        PM2 | 2020-06-26T23:37:43: PM2 log: App [MagicMirror:0] online
                        PM2 | 2020-06-26T23:40:55: PM2 log: Stopping app:MagicMirror id:0
                        PM2 | 2020-06-26T23:40:58: PM2 log: pid=3768 msg=failed to kill - retrying in 100ms
                        PM2 | 2020-06-26T23:40:59: PM2 log: pid=3768 msg=failed to kill - retrying in 100ms
                        PM2 | 2020-06-26T23:40:59: PM2 log: Process with pid 3768 still alive after 1600ms, sending it SIGKILL now…
                        PM2 | 2020-06-26T23:41:03: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGKILL]
                        PM2 | 2020-06-26T23:41:03: PM2 log: pid=3768 msg=process killed
                        PM2 | 2020-06-26T23:41:03: PM2 log: App [MagicMirror:0] starting in -fork mode-
                        PM2 | 2020-06-26T23:41:03: PM2 log: App [MagicMirror:0] online
                        PM2 | 2020-06-26T23:45:57: PM2 log: Stopping app:MagicMirror id:0
                        PM2 | 2020-06-26T23:45:59: PM2 log: pid=4108 msg=failed to kill - retrying in 100ms
                        PM2 | 2020-06-26T23:46:00: PM2 log: pid=4108 msg=failed to kill - retrying in 100ms
                        PM2 | 2020-06-26T23:46:01: PM2 log: pid=4108 msg=failed to kill - retrying in 100ms
                        PM2 | 2020-06-26T23:46:01: PM2 log: Process with pid 4108 still alive after 1600ms, sending it SIGKILL now…
                        PM2 | 2020-06-26T23:46:04: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGKILL]
                        PM2 | 2020-06-26T23:46:04: PM2 log: pid=4108 msg=process killed
                        PM2 | 2020-06-26T23:48:57: PM2 log: App [MagicMirror:0] starting in -fork mode-
                        PM2 | 2020-06-26T23:48:57: PM2 log: App [MagicMirror:0] online
                        0|MagicMir | errno: ‘EADDRINUSE’,
                        0|MagicMir | syscall: ‘listen’,
                        0|MagicMir | address: ‘0.0.0.0’,
                        0|MagicMir | port: 8080 }
                        0|MagicMir | [2020-06-26 22:01:07.509] [ERROR] (node:804) UnhandledPromiseRejectionWarning: Error: Error: socket hang up
                        0|MagicMir | at obtainToken.then.catch.e (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_helper.js:1:6073)
                        0|MagicMir | at process._tickCallback (internal/process/next_tick.js:68:7)
                        0|MagicMir | [2020-06-26 22:01:07.556] [ERROR] (node:804) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
                        0|MagicMir | [2020-06-26 22:01:07.585] [ERROR] (node:804) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                        0|MagicMir | [2020-06-26 22:10:57.436] [ERROR] { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                        0|MagicMir | at Server.setupListenHandle [as _listen2] (net.js:1280:14)
                        0|MagicMir | at listenInCluster (net.js:1328:12)
                        0|MagicMir | at doListen (net.js:1461:7)
                        0|MagicMir | at process._tickCallback (internal/process/next_tick.js:63:19)
                        0|MagicMir | at Function.Module.runMain (internal/modules/cjs/loader.js:834:11)
                        0|MagicMir | at startup (internal/bootstrap/node.js:283:19)
                        0|MagicMir | at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                        0|MagicMir | code: ‘EADDRINUSE’,
                        0|MagicMir | [2020-06-26 22:29:48.332] [ERROR] { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                        0|MagicMir | [2020-06-26 22:32:38.374] [ERROR] { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                        0|MagicMir | [2020-06-26 22:44:05.320] [ERROR] { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                        0|MagicMir | [2020-06-26 23:38:17.501] [ERROR] { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                        0|MagicMir | [2020-06-26 23:41:37.375] [ERROR] { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                        0|MagicMir | [2020-06-26 23:49:31.461] [ERROR] { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                        0|MagicMir | [2020-06-26 23:38:16.062] [LOG] Module helper loaded: MMM-awesome-alexa
                        0|MagicMir | [2020-06-26 23:38:16.072] [LOG] All module helpers loaded.
                        0|MagicMir | [2020-06-26 23:38:17.060] [LOG] Starting server on port 8080 …
                        0|MagicMir | [2020-06-26 23:38:17.151] [LOG] Server started …
                        0|MagicMir | [2020-06-26 23:38:17.163] [LOG] Connecting socket for: updatenotification
                        0|MagicMir | [2020-06-26 23:38:17.177] [LOG] Connecting socket for: calendar
                        0|MagicMir | [2020-06-26 23:38:17.189] [LOG] Starting node helper for: calendar
                        0|MagicMir | [2020-06-26 23:38:17.201] [LOG] Connecting socket for: newsfeed
                        0|MagicMir | [2020-06-26 23:38:17.212] [LOG] Starting module: newsfeed
                        0|MagicMir | [2020-06-26 23:38:17.222] [LOG] Connecting socket for: MMM-Screencast
                        0|MagicMir | [2020-06-26 23:38:17.233] [LOG] Connecting socket for: MMM-LICE
                        0|MagicMir | [2020-06-26 23:38:17.250] [LOG] Starting node_helper for: MMM-LICE
                        0|MagicMir | [2020-06-26 23:38:17.256] [LOG] Connecting socket for: MMM-awesome-alexa
                        0|MagicMir | [2020-06-26 23:38:17.268] [LOG] Sockets connected & modules started …
                        0|MagicMir | [2020-06-26 23:38:17.284] [LOG]
                        0|MagicMir | Ready to go! Please point your browser to: http://0.0.0.0:8080
                        0|MagicMir | Starting chromium browser now, have patience, it takes a minute
                        0|MagicMir | [2020-06-26 23:38:17.481] [LOG] Whoops! There was an uncaught exception…
                        0|MagicMir | [2020-06-26 23:38:17.613] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                        0|MagicMir | [2020-06-26 23:38:17.629] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                        0|MagicMir |
                        0|MagicMir |
                        0|MagicMir | [2020-06-26 23:41:19.020] [LOG] Starting MagicMirror: v2.11.0
                        0|MagicMir | [2020-06-26 23:41:19.145] [LOG] Loading config …
                        0|MagicMir | [2020-06-26 23:41:19.195] [LOG] Loading module helpers …
                        0|MagicMir | [2020-06-26 23:41:19.212] [LOG] No helper found for module: alert.
                        0|MagicMir | [2020-06-26 23:41:19.638] [LOG] Initializing new module helper …
                        0|MagicMir | [2020-06-26 23:41:19.649] [LOG] Module helper loaded: updatenotification
                        0|MagicMir | [2020-06-26 23:41:19.661] [LOG] No helper found for module: clock.
                        0|MagicMir | [2020-06-26 23:41:23.649] [LOG] Initializing new module helper …
                        0|MagicMir | [2020-06-26 23:41:23.659] [LOG] Module helper loaded: calendar
                        0|MagicMir | [2020-06-26 23:41:23.670] [LOG] No helper found for module: currentweather.
                        0|MagicMir | [2020-06-26 23:41:23.678] [LOG] No helper found for module: weatherforecast.
                        0|MagicMir | [2020-06-26 23:41:23.923] [LOG] Initializing new module helper …
                        0|MagicMir | [2020-06-26 23:41:23.933] [LOG] Module helper loaded: newsfeed
                        0|MagicMir | [2020-06-26 23:41:26.712] [LOG] Initializing new module helper …
                        0|MagicMir | [2020-06-26 23:41:26.721] [LOG] Module helper loaded: MMM-Screencast
                        0|MagicMir | [2020-06-26 23:41:26.745] [LOG] Initializing new module helper …
                        0|MagicMir | [2020-06-26 23:41:26.754] [LOG] Module helper loaded: MMM-LICE
                        0|MagicMir | [2020-06-26 23:41:35.901] [LOG] Initializing new module helper …
                        0|MagicMir | [2020-06-26 23:41:35.912] [LOG] Module helper loaded: MMM-awesome-alexa
                        0|MagicMir | [2020-06-26 23:41:35.923] [LOG] All module helpers loaded.
                        0|MagicMir | [2020-06-26 23:41:36.918] [LOG] Starting server on port 8080 …
                        0|MagicMir | [2020-06-26 23:41:37.012] [LOG] Server started …
                        0|MagicMir | [2020-06-26 23:41:37.026] [LOG] Connecting socket for: updatenotification
                        0|MagicMir | [2020-06-26 23:41:37.037] [LOG] Connecting socket for: calendar
                        0|MagicMir | [2020-06-26 23:41:37.049] [LOG] Starting node helper for: calendar
                        0|MagicMir | [2020-06-26 23:41:37.062] [LOG] Connecting socket for: newsfeed
                        0|MagicMir | [2020-06-26 23:41:37.074] [LOG] Starting module: newsfeed
                        0|MagicMir | [2020-06-26 23:41:37.085] [LOG] Connecting socket for: MMM-Screencast
                        0|MagicMir | [2020-06-26 23:41:37.099] [LOG] Connecting socket for: MMM-LICE
                        0|MagicMir | [2020-06-26 23:41:37.111] [LOG] Starting node_helper for: MMM-LICE
                        0|MagicMir | [2020-06-26 23:41:37.123] [LOG] Connecting socket for: MMM-awesome-alexa
                        0|MagicMir | [2020-06-26 23:41:37.135] [LOG] Sockets connected & modules started …
                        0|MagicMir | [2020-06-26 23:41:37.144] [LOG]
                        0|MagicMir | [2020-06-26 23:41:37.349] [LOG] Whoops! There was an uncaught exception…
                        0|MagicMir | [2020-06-26 23:41:37.489] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                        0|MagicMir | [2020-06-26 23:41:37.497] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                        0|MagicMir |
                        0|MagicMir |
                        0|MagicMir | [2020-06-26 23:49:13.064] [LOG] Starting MagicMirror: v2.11.0
                        0|MagicMir | [2020-06-26 23:49:13.190] [LOG] Loading config …
                        0|MagicMir | [2020-06-26 23:49:13.237] [LOG] Loading module helpers …
                        0|MagicMir | [2020-06-26 23:49:13.252] [LOG] No helper found for module: alert.
                        0|MagicMir | [2020-06-26 23:49:13.678] [LOG] Initializing new module helper …
                        0|MagicMir | [2020-06-26 23:49:13.689] [LOG] Module helper loaded: updatenotification
                        0|MagicMir | [2020-06-26 23:49:13.701] [LOG] No helper found for module: clock.
                        0|MagicMir | [2020-06-26 23:49:17.732] [LOG] Initializing new module helper …
                        0|MagicMir | [2020-06-26 23:49:17.741] [LOG] Module helper loaded: calendar
                        0|MagicMir | [2020-06-26 23:49:17.753] [LOG] No helper found for module: currentweather.
                        0|MagicMir | [2020-06-26 23:49:17.763] [LOG] No helper found for module: weatherforecast.
                        0|MagicMir | [2020-06-26 23:49:18.002] [LOG] Initializing new module helper …
                        0|MagicMir | [2020-06-26 23:49:18.011] [LOG] Module helper loaded: newsfeed
                        0|MagicMir | [2020-06-26 23:49:20.774] [LOG] Initializing new module helper …
                        0|MagicMir | [2020-06-26 23:49:20.784] [LOG] Module helper loaded: MMM-Screencast
                        0|MagicMir | [2020-06-26 23:49:30.044] [LOG] Initializing new module helper …
                        0|MagicMir | [2020-06-26 23:49:30.054] [LOG] Module helper loaded: MMM-awesome-alexa
                        0|MagicMir | [2020-06-26 23:49:30.064] [LOG] All module helpers loaded.
                        0|MagicMir | [2020-06-26 23:49:31.041] [LOG] Starting server on port 8080 …
                        0|MagicMir | [2020-06-26 23:49:31.128] [LOG] Server started …
                        0|MagicMir | [2020-06-26 23:49:31.140] [LOG] Connecting socket for: updatenotification
                        0|MagicMir | [2020-06-26 23:49:31.155] [LOG] Connecting socket for: calendar
                        0|MagicMir | [2020-06-26 23:49:31.165] [LOG] Starting node helper for: calendar
                        0|MagicMir | [2020-06-26 23:49:31.175] [LOG] Connecting socket for: newsfeed
                        0|MagicMir | [2020-06-26 23:49:31.189] [LOG] Starting module: newsfeed
                        0|MagicMir | [2020-06-26 23:49:31.200] [LOG] Connecting socket for: MMM-Screencast
                        0|MagicMir | [2020-06-26 23:49:31.208] [LOG] Connecting socket for: MMM-awesome-alexa
                        0|MagicMir | [2020-06-26 23:49:31.226] [LOG] Sockets connected & modules started …
                        0|MagicMir | [2020-06-26 23:49:31.232] [LOG]
                        0|MagicMir | [2020-06-26 23:49:31.441] [LOG] Whoops! There was an uncaught exception…
                        0|MagicMir | [2020-06-26 23:49:31.570] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                        0|MagicMir | [2020-06-26 23:49:31.585] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                          sdetweil @uok825
                          @uok825 still says address in use… do you have it stopped or not? what does pm2 status show?
                          do NOT reboot
                          • U
                            uok825 @sdetweil
                            @sdetweil i “pm2 stop all”
                              sdetweil @uok825
                              @uok825 pm2 status please
                              • U
                                uok825 @sdetweil
                                @sdetweil Wait flushing
                                • U
                                  uok825 @sdetweil
                                  @sdetweil 0|MagicMir | [2020-06-27 01:24:01.211] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: Europe is not defined
                                  0|MagicMir | at Object. (/home/pi/MagicMirror/config/config.js:126:15)
                                  0|MagicMir | at Module._compile (internal/modules/cjs/loader.js:778:30)
                                  0|MagicMir | at Object.Module._extensions…js (internal/modules/cjs/loader.js:789:10)
                                  0|MagicMir | at Module.load (internal/modules/cjs/loader.js:653:32)
                                  0|MagicMir | at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                                  0|MagicMir | at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                                  0|MagicMir | at Module.require (internal/modules/cjs/loader.js:692:17)
                                  0|MagicMir | at require (internal/modules/cjs/helpers.js:25:18)
                                  0|MagicMir | at loadConfig (/home/pi/MagicMirror/js/app.js:69:12)
                                  0|MagicMir | at App.start (/home/pi/MagicMirror/js/app.js:210:3)
                                  0|MagicMir | [2020-06-27 01:24:03.383] [ERROR] { Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
                                  0|MagicMir | at GetAddrInfoReqWrap.doListen [as callback] (net.js:1461:7)
                                  0|MagicMir | at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:61:10)
                                  0|MagicMir | address: ‘127.0.0.1’,
                                  /home/pi/.pm2/logs/MagicMirror-out.log last 200 lines:
                                  0|MagicMir |
                                  0|MagicMir |
                                  0|MagicMir | [2020-06-27 01:24:01.042] [LOG] Starting MagicMirror: v2.11.0
                                  0|MagicMir | [2020-06-27 01:24:01.170] [LOG] Loading config …
                                  0|MagicMir | [2020-06-27 01:24:01.223] [LOG] Loading module helpers …
                                  0|MagicMir | [2020-06-27 01:24:01.652] [LOG] Initializing new module helper …
                                  0|MagicMir | [2020-06-27 01:24:01.664] [LOG] Module helper loaded: updatenotification
                                  0|MagicMir | [2020-06-27 01:24:01.679] [LOG] No helper found for module: helloworld.
                                  0|MagicMir | [2020-06-27 01:24:01.691] [LOG] All module helpers loaded.
                                  0|MagicMir | [2020-06-27 01:24:02.810] [LOG] Starting server on port 8080 …
                                  0|MagicMir | [2020-06-27 01:24:02.948] [LOG] Server started …
                                  0|MagicMir | [2020-06-27 01:24:02.960] [LOG] Connecting socket for: updatenotification
                                  0|MagicMir | [2020-06-27 01:24:02.973] [LOG] Sockets connected & modules started …
                                  0|MagicMir | [2020-06-27 01:24:02.984] [LOG]
                                  0|MagicMir | Ready to go! Please point your browser to: http://localhost:8080
                                  0|MagicMir | [2020-06-27 01:24:03.350] [LOG] Whoops! There was an uncaught exception…
                                  0|MagicMir | [2020-06-27 01:24:03.495] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                  0|MagicMir | [2020-06-27 01:24:03.513] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                    sdetweil @uok825
                                    @uok825
                                    so, u gotta fix this, PM2 keeps restarting…
                                    i don’t want you to use pm2 to test
                                    do
                                    pm2 stop  all
                                    then
                                    cd ~/MagicMirror
                                    npm run config:check
                                    find and fix error
                                    if no error, then
                                    npm start
                                    verify working
                                    ctrl-c to exit MM
                                    then pm2 start
                                    • U
                                      uok825 @sdetweil
                                      @sdetweil config is running correct but
                                      It causes by Screencast maybe?
                                      My config
                                        sdetweil @uok825
                                        @uok825 you still have something running using port 8080…
                                        disable the modules one by one
                                        add
                                          module: name,
                                          disabled: true,             // < --- add this
                                        i don’t know anything about the modules themselves…
                                        • U
                                          uok825 @sdetweil
                                          @sdetweil Maybe screencast?
                                          • U
                                            uok825 @sdetweil
                                            @sdetweil Disabled all but nothing change
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 12
                                            • 13
                                            • 7 / 13
