    Random Quotes
    19 Posts 9 Posters 16.8k Views 8 Watching
    • KirAsh4K Offline
      KirAsh4 Moderator
      I forgot who asked me to release my code, it may have been @paviro, but I honestly don’t remember. One of the very first modules I wanted was something that displays a random quote, so I modified the supplied ‘Compliments’ one to my needs. I used the popular http://www.brainyquote.com web site to fetch quotes, however they don’t provide an API. And looking around the web, all of the random quotes web sites that I found with an API only allows you one random quote per day. If you want a random one each time you send a request, then you need to subscribe and pay them. So, in keeping the ‘free’ nature of the module, I decided to hard code a few categories and quotes from each from BrainyQuote. If you want to edit the quotes, you’ll have to do that in the module’s js file.
      http://github.com/KirAsh4/random_quotes/
      • Wilco89W Offline
        Wilco89
        I just installed it. it’s working fine, Did send you a PR there were some typos in the readme file. some people wouldn’t be able to install it with that typos.
        • KirAsh4K Offline
          KirAsh4 Moderator
          Thanks, merged into dev. Will push it to master as well.
          • P Offline
            pietrodona
            Hi, I am very bad with javascript is it possible to load the quotes from a text file?
            • KirAsh4K Offline
              KirAsh4 Moderator
              Not as written. It would require a bit of rewriting to allow for a local call to a file. Not impossible, just not written.
              • G Offline
                geeflaxx
                so is that right that you put the information from your script not from brainyguote?
                so i can change it in vocal to learn an another language ?
                i mean its only a script what change the text per time ?
                if that is it that i am thanksfull
                that i need it (for example for my english…)
                • KirAsh4K Offline
                  KirAsh4 Moderator
                  All the quotes are in the random_quotes.js file. You can change them to anything you want.
                  • G Offline
                    geeflaxx
                    so i have to add the paramteres (updateintervall etc) in my config ?
                    because in your example wasn’t that
                    very thank you!
                    ‘modules: [
                    module: ‘random_quotes’,
                    position: ‘lower_third’,
                    updateIntervall=500 // The config property is optional
                    fadeSpeed=4 // Without a config, a random quote is shown,
                    category=random // selected from all of the categories available.
                    • KirAsh4K Offline
                      KirAsh4 Moderator
                      Correct, as the documentation shows.
                      • strawberry 3.141S Offline
                        strawberry 3.141 Project Sponsor Module Developer @geeflaxx
                        @geeflaxx you need to write it down like this
                            module: 'random_quotes',
                            position: 'lower_third',
                                updateIntervall: 500,
                                fadeSpeed: 4,
                                category: 'random'
