    MMM-MyCommute
    286 Posts 80 Posters 656.3k Views 77 Watching
    • L Offline
      Looking @j.e.f.f
      Hey j.e.f.f,
      Here is what I pasted… I am sure it is something real goofy. I did get an API KEY from Google. Maybe there was addition code I needed to put else where. This is my first time project with MM. Really cool.
      CODE:
      	module: 'MMM-MyCommute',
      	header: 'Trafic',
      	position: 'top_right',
      		showHeader: true,
      		//------ headerText: 'Traffic',
      		apikey: 'PUT IN GOOGLE API',
      		origin: 'PUT MY ADDRESS. 123 ST, TOWN, ST ZIPCODE',
      		startTime: '00:00',
      		endTime: '23:59',
      		hideDays: [0,6],
      		destinations: [
      			destination: 'PUT IN WORK ADDRESS',
      			label: 'Emerson Parkside Academy',
      			mode: 'driving',
      			color: '#82E5AA'
      Your help would be greatly appreciated. Thank you!
      • L Offline
        Looking @Looking
        @Looking
        Should I have something within the MODULES directory to correspond to this cool MMM-MyCommute module?
        • L Offline
          Looking @Looking
          Hey there j.e.f.f.
          I figured out that I missed the whole part about installing the actual MMM-MyCommute module, https://github.com/jclarke0000/MMM-MyCommute . I am letting it run in MM but under the header TRAFFIC on MM it just says Loading… I rechecked my API key and made sure I did not mistype. Any thoughts?
          • L Offline
            Looking @Looking
            @Looking
            Ok I simply rebooted my Pi and the MyCommute module did show up. I see the car icon, the name I gave it but the place where I would see the commute time is populated with the message of ‘Error’ . I think I see this happen for someone on this board…Let me look. But in the meantime thanks for helping me and if I do not get this I will post again. Love the module and the community.
            • O Offline
              olexs
              Hey,
              I just found this module today, and it’s awesome, exactly what I was looking for! Multiple destinations - almost perfect. However I was missing the option of calendar integration. So I went ahead and built it: https://github.com/jclarke0000/MMM-MyCommute/pull/1
              With it enabled, it shows extra destinations for upcoming events in all configured calendard that have a location (up to a maximum number). The destinations are configurable, same as normal ones - it only overwrites the location and title. Works perfectly for me so far. Any comments are welcome.
              • rudibaraniR Offline
                rudibarani Project Sponsor
                Very interesting module - thanks for the great work of putting it up!
                Is there a way to change the output to something like this
                (with the text in italics being user customizable)?
                • [walking icon] “Leave by 8:00h to arrive in time the next appointment.”
                • [train icon]“Leave in XX mins to catch the tram to school.”
                • [car icon]“Heavy traffic today! Leave by 8:00h to arrive in time for today.” (In case the trip duration is longer than usual).
                If found olexs calendar integration (https://github.com/jclarke0000/MMM-MyCommute/pull/1) regarding aspects of the first bulletpoint. Any ideas how to go on with the other?
                Thanks for help and suggestions!
                  j.e.f.f Project Sponsor Module Developer @rudibarani
                  @rudibarani Strangely, the Google API only allows arrival time estimates for transit mode, not any other mode. On top of that, because this is using the free API I need to keep the requests infrequent, so specifically your second ask “Leave in XX minutes to catch the next tram” won’t be timely.
                  I made another module for TTC (Toronto Transit) that gives you departure time for transit vehicles. It polls every minute, so it’s information is very timely! While it currently only works for Toronto transit, it’s based in the NextBus API, which supports many more transit systems in North America. Adapting that module for any of the NextBus supported agencies would be trivial.
                  Here’s the list of supported agencies:
                  http://webservices.nextbus.com/service/publicJSONFeed?command=agencyList
                  …and more info on the module here:
                  https://forum.magicmirror.builders/topic/2632/mmm-myttc-toronto-transit
                  Would that address your need?
                  rudibaraniR 1 Reply Last reply Reply Quote 0
                    j.e.f.f Project Sponsor Module Developer @olexs
                    @olexs this is a great addition! Give me a chance to review it to make sure there’s not going to be any adverse affects on the core purpose of this module, or if it will generate too many requests to the API. Using a free API token, we’re limited to 2500 requests per day. While this may seem like a lot, each destination requires its own request. It’s surprisingly easy to blow that limit – I did it once during development of this module!!
                    • O Offline
                      olexs @j.e.f.f
                      @j.e.f.f I am aware of the API problem, which is why I set the config option to “off” by default. On my own mirror, I have 2 default destinations + max 3 calendar entries shown. With 5 destinations refreshing every 10 minutes, this amounts to a total of 720 requests per 24 hours, well below the limit. Of course users can set the calendar entries number higher, or configure more “static” destinations. Maybe one could implement an explicit console warning when too many destinations (10 or more) are configured, and one comes close to the limit?
                        rudibarani Project Sponsor @j.e.f.f
                        @j.e.f.f Thanks for the quick reply!
                        I am looking for a solution that works in Germany as well. Therefore adapting your TTC module is a great idea, but unfortunately not supported here.
                        As it seems more complex than I thought, maybe boiling it down to a “leave by” would be great. If I could add a planned arrival time and google reports xx minutes, an output using the necessary departure time would be great. This could be based on a simple calculation and color coded depending on the percentage of a longer trip than usual.
                        Is the update-frequency of the google-prediction known? What is the current update-frequency you are using? Pulling the numbers more often than google woulds change them would not be necessary. I am having five queries running and an update every five minutes would be enough for me (~1500/queries day).
                          @rudibarani there is a cap of 2500 requests per day when using the free API. Therefore I’ve kept the poll frequency at a very conservative 10 minutes. Each destination requires its own request so it’s fairly easy to blow the limit if you’re not careful.
                          I could put a calculation in place where if you say you need to be at a certain place by 9:00, then I could put a “leave by” message. But as the data poll is not very frequent, you could see something that says “leave by 8:00,” but it’s already 8:05.
                          I can also make the polling frequency configurable so that you could mitigate this, and include an explicit warning in the reader of what the potential consequence is.
                            @j.e.f.f: I found that MMM-Traffic offers a leave by option and there is also a variant MMM-TrafficCal which integrates with a calendar to get the time based on the next and current location from a calendar. Maybe we can learn from them?
                            Regarding the cap:
                            • would it be feasible to have a hardcoded stop for new polls after 2500 request on a day (and notify the user, if to many polls are / will be made)?
                            • would it be possible to limit the time when polls are made? Leaving out 22h - 5h could already save a lot of capacity.
                            Regarding “leave by”:
                            To me, having an option to either take the arrival time from a variable (or even a calendar) would be great. There could be the case that the departure time has already passed, but that would be OK for me.
                            Thanks!
                              @rudibarani I’ve already included logic to keep the requests to a minimum based on the time windows you set. The entire module is governed by the startTime and endTime parameters. Outside of that window, not only is the module not visible, but it stops polling Google. Likewise, if you set a time window for a particular destination, Google will only be polled for that particular destination within that window.
                              I’m still considering how I might manage the Calendar integration… I’d want it to be smart about when it starts polling for travel times. For example, if my appointment is for sometime in the evening, I don’t really care what the drive will be like to get there in the morning, so I’d be wasting a request. So maybe there is a threshold, say, two hours before the appointment time, where it gets the initial estimate, and then based on that doesn’t poll again until, say 30 minutes before you need to leave.
                                @j.e.f.f Thanks for the clarification, that there are no polls while it is not visible.
                                One easy way would be to add a “smart timer” if you polled with increasing frequency depending on the start time. Also possible would be polling once after midnight to get an idea about the expected travel time without delays. This duration plus a buffer (e.g. three times the travel time; user customizable) could determine the dynamic start time when travel times will show up.
                                Different question: would it be possible to colours only in case of delays (=not show a “good” time in green but white)?
                                  @rudibarani sure. You can add a rule in your custom css file like this:
                                  .MMM-MyCommute .travel-time.status-good {
                                    color: #FFFFFF;
                                    @j.e.f.f Great! I keep learning about the way MM-modules work. Thanks a lot
                                      rudibarani Project Sponsor @rudibarani
                                      Hi @j.e.f.f,
                                      is there a way to localize the output of MMM-MyCommute? I noticed that MMM-MyWeather uses a translate folder that contains a file for each supported language. Maybe something similar would be possible here, too. I am happy to provide German translations if you like.
                                      Related to that would be adhering to the timeformat set in a users config.js. Currently, the module seems to only support the 12 hour am/pm-format. Having a 24h format as in my other modules would be great.
                                      Thanks for caring to think about this!
                                        @rudibarani This module doesn’t print out many literal strings, except for error messages in the console, and the two words “Error” (easily localized) and “min.” (e.g. 33 min). Everyting else is either configured text or data from the API response. Are you looking to translate the route summary? eg: The grey text below the title in the image below:
                                        If so, this is provided by Google in the response from the directions API. It is supposed to localize automatically based on where it determines your location to be, but I’m not sure if that’s just for returning otherwise ambiguous directions or if it’s supposed to give you the route in the localized language. That said, it request accepts an explicit region parameter. I could expose that and you could set it to see if that addresses this.
                                        As for the time format, the module is not presenting any time in 12 hour AM/PM format. It is calculating the total number of minutes to get to the destination and presenting it in a built string – calculatedTimeInMinutes + " min". This will ALWAYS be a sum of minutes (e.g.: 90 min, not 1 hr 30 min – this is to save space). I could expose a string format parameter that has a placeholder for the number of minutes, so you could specify something like timePredictionFormat: "%MINUTES% m" (module would replace %MINUTES% with calculatedTimeInMinutes, and would render as 33 m, for example). Would this work for what you’re trying to do?
                                          @j.e.f.f Thanks for the clarifications. Both of my questions seem to relate to grey text you referred to. In my case, it shows an english route summary including the departure times in the 12 hour format:
                                          Having this string in German with 24h time format would be great. Maybe the region parameter could be a solution.
                                            @rudibarani Ah I forgot about that part! Yeah that should be doable… The time in 12 hour format is provided by Google as-is, but I should be able to convert it. I can make this entire string a time format string. That way it can be translated in whatever context and order you need.
                                            something like nextTransitVehicleSummaryFormat: "[next at] HH:mm".
                                            That way you could translate it any way you like or change it any way you like.
                                            • 6
                                            • 14
                                            • 15
                                            • 4 / 15
