    Screen goes blank shortly after MM loaded (All modules hidden)
    4 Posts 2 Posters 2.5k Views 2 Watching
    • joela85J Offline
      joela85
      All my modules are hidden and I get a blank screen when MagicMirror loads up.
      Was working fine a while ago. Changed to sample config at it does the same thing.
      Any ideas?
      Thanks, Joel
        Mykle1 Project Sponsor Module Developer @joela85
        @joela85
        It loads and then goes blank or it is blank at launch? You could start the mirror using npm start dev in the MagicMirror directory and see if there are an errors being reported in the console. Are there any terminal errors? Have you installed a screensaver recently?
        • joela85J Offline
          joela85
          I think I found the problem to be a dodgy hdmi cable. I bought a new short hdmi cable so it would be easier to fit behind the mirror. Replaced with my original longer cable and seems to be ok. I will also try npm start dev to see if I get any errors.
          Thank you for your reply.
            @joela85
            You’re welcome. I’m glad you got it sorted out. Enjoy your mirror.
