    MagicMirror Servermode on Synology DS
    servermodesynologydiskstationwebserver
    14 Posts 6 Posters 12.8k Views 7 Watching
    • yawnsY Offline
      yawns Moderator
      according to the synology wiki:
      ipkg update; ipkg install nano
        AnyKey
        Ok, i managed to edit the config.js file to a full whitelist with nano. To install nano I had to do
        sudo apt-get update
        sudo apt-get install nano
        After that, I run “node serveronly” in the MagicMirror folder and I got the following log:
        root@synology_gitlab:/home/git/gitlab/MagicMirror# node serveronly
        Starting MagicMirror: v2.1.1
        Loading config ...
        Loading module helpers ...
        All module helpers loaded.
        Starting server op port 8080 ...
        You're using a full whitelist configuration to allow for all IPs
        Server started ...
        Starting module: newsfeed
        Ready to go! Please point your browser to: http://localhost:8080
        { Error: listen EADDRINUSE :::8080
            at Object.exports._errnoException (util.js:1033:11)
            at exports._exceptionWithHostPort (util.js:1056:20)
            at Server._listen2 (net.js:1270:14)
            at listen (net.js:1306:10)
            at Server.listen (net.js:1397:7)
            at new Server (/home/git/gitlab/MagicMirror/js/server.js:27:9)
            at /home/git/gitlab/MagicMirror/js/app.js:219:18
            at loadNextModule (/home/git/gitlab/MagicMirror/js/app.js:168:5)
            at /home/git/gitlab/MagicMirror/js/app.js:163:6
            at Class.loaded (/home/git/gitlab/MagicMirror/modules/node_modules/node_help
        er/index.js:19:3)
          code: 'EADDRINUSE',
          errno: 'EADDRINUSE',
          syscall: 'listen',
          address: '::',
          port: 8080 }
        MagicMirror will not quit, but it might be a good idea to check why this happene
        d. Maybe no internet connection?
        If you think this really is an issue, please open an issue on GitHub: https://gi
        thub.com/MichMich/MagicMirror/issues
        But I don’t get a connection when opening “http://localhost:8080”.
        At this point, I come to the conclusion, that it will be much easier and less stressful to run the MM Server on my Pi3 (managed to install and configure it at work in three hours less). Besides that, the ressources need for running a MM container seems to be very high, working with ne Synology while running MM is a pain in the ***.
        From my point of view this topic can be closed. I’d like to thank everybody who participated and wanted to help me! You guys rock :-)
        sincerely yours Andre
        bheplerB A 2 Replies Last reply Reply Quote 0
        • bheplerB Offline
          bhepler Module Developer @AnyKey
          @AnyKey said in MagicMirror Servermode on Synology DS:
          EADDRINUSE
          This usually means that you already have the MagicMirror running and you have attempted to start the server again. You’ll need to kill that process before starting it up.
          Try ps ax | grep node and if you see the line 9589 pts/1 Sl+ 0:03 node serveronly or something similar, then the Mirror is already running.
          sudo kill -9 9589 (or whatever the process number listed is) will stop it.
          I’m sorry this has been so frustrating. You’re almost there.
            andreas-becker @AnyKey
            @AnyKey try to change the port which is used by Magicmirror. The Diskstation seems to use port 8080 for something else.
