    Help! Probem using PIR Sensor on raspberry pi zero to turn on/off screen
    15 Posts 5 Posters 9.3k Views 5 Watching
    • P Offline
      Petal0u
      Hi all,
      i followed every step of this post :point_down:
      @randombullet said in How I got my Magic Mirror working on a Raspberry Pi 0 (zero):
      I’ve been working on this for a little bit and I’m sorry for all the incoming questions and posts on here.
      On sudo npm install, I get npm ERR! code EPEERINVALID.
      I’ve tried googling some answers but I’m not confident enough to figure this out. Also I’m writing the steps in a more linear way to make more sense of it this is what I have so far and I’d like some input so that I can help other people.
      Step 2
      My Jessie Lite didn’t allow me to create files for some reason. I posted on reddit here.
      Anyways the way of going around this is to put in a “wpa_supplicant.conf” file into your SD card and put the following in:
      network={
      ssid=”YOUR_WIFI”
      psk=”WIFI_PASSWORD”
      This is what I have so far. Please look over this. Thanks in advanced!
      1 sudo wget http://node-arm.herokuapp.com/node_latest_armhf.deb
      2 sudo dpkg -i node_latest_armhf.deb
      3 sudo apt-get install npm
      4 sudo apt-get install git
      5 cd /home/pi/
      6 git clone https://github.com/MichMich/MagicMirror
      7 cd MagicMirror
      8 sudo npm install #This will take a LONG time.
      9 sudo apt-get install midori
      10 sudo apt-get install unclutter
      11 sudo aptitude install xinit
      12 sudo apt-get install matchbox
      13 sudo raspi-config
      14 Boot Options -> B1 Desktop/CLI -> B2 Console Autologin
      15 sudo nano /home/pi/start.sh
      #! /bin/bash
      cd ~/MagicMirror
      node serveronly &
      sleep 45
      sudo xinit /home/pi/startMidori.sh
      16 Control + x > Y > Return
      17 sudo chmod a+x /home/pi/start.sh
      18 sudo mv /home/pi/start.sh /etc/init.d/startMagicMirror.sh
      19 sudo update-rc.d startMagicMirror.sh defaults 100
      20 sudo apt-get install x11-xserver-utils
      21 sudo nano /home/pi/startMidori.sh
      #!/bin/sh
      xset -dpms # disable DPMS (Energy Star) features.
      xset s off # disable screen saver
      xset s noblank # don’t blank the video device
      matchbox-window-manager &
      unclutter &
      midori -e Fullscreen -a http://localhost:8080
      22 Control + x > Y > Return
      23 sudo nano /boot/config.txt
      disable_overscan=1
      framebuffer_width=1050
      framebuffer_height=1680
      framebuffer_depth=32
      framebuffer_ignore_alpha=1
      hdmi_pixel_encoding=1
      hdmi_group=2
      display_rotate=1
      24 Control + x > Y > Return
      everything works fine exept the pir sensor. :smirk:
      I’ve a python script to test the pir sensor. Motions are detected but my mirror still turned off.
      does anybody have an idea ? :expressionless:
      • P Offline
        Petal0u @Petal0u
        Pir sensor module works fine. Screen wakes up.
        I stil have nothing on screen, no smart mirror.
        MikgaboM 1 Reply Last reply Reply Quote 0
        • MikgaboM Offline
          Mikgabo @Petal0u
          @Petal0u did u ever get to solve the problem? I’m currently in the same boat.
          Cheers,
          Mike
          • randomnoiseR Offline
            randomnoise
            Have you disabled screensaver? That can cause the screen to remain blank.
            Easiest way is to install xscreensaver then disable it from the desktop (yes this seems counterintuitive but it works)
            • MikgaboM Offline
              Mikgabo @randomnoise
              @randomnoise
              Hey! Thanks for getting back to me.
              My MM works pretty well, can’t get MMM stock to work though.
              My major problem is getting my PIR sensor to function properly. I have it working properly on a pi3 but not the zero.
              What code did u use for your PIR?
              Thanks,
              Mike
              Mykle1M N 2 Replies Last reply Reply Quote 0
                Mykle1 Project Sponsor Module Developer @Mikgabo
                @Mikgabo said in Help! Probem using PIR Sensor on raspberry pi zero to turn on/off screen:
                If I remember correctly, that module’s API is no longer working, thus, killing the module. :-(
                • MikgaboM Offline
                  Mikgabo @Mykle1
                  @Mykle1 Good day!
                  That’s interesting, I have MMM stock working on my Pi3. I am running an older version of Jessie though.
                  For you know of any stock ticker that would work on Pi Zero?
                  Thanks,
                  Mike
                    @Mikgabo
                    Obviously, I am mistaken then, and I apologize for an old man’s faulty memory. :-/
                    I don’t know if this is what you are looking for or if it works
                    on a Pi zero
                    https://github.com/alexyak/stocks
                    • MikgaboM Offline
                      Mikgabo @Mykle1
                      @Mykle1 Many thanks, I’ll give it a try!
                      I have a few more avenues to explore I respect to the PIR sensor and will report back if successful.
                      Cheers,
                      Mike
                      • N Offline
                        NoNameRo @Mikgabo
                        for the Pi Zero use the PIR script from @cruunnerr --> point 2.2 Using PIR script
                        maybe this is helpful
                        The very important thing is, that your monitor supports HDMI-CEC or ARC. Otherwise u will not be able to turn it on or off via HDMI.
                        To reassure you, most monitors do this ;)
                        To check if it works just go into terminal via ssh and type:
                        sudo tvservice -o to turn off
                        sudo tvservice -p to turn on
                        edit: for some monitors the following commands work better. Please use them if your monitor needs it:
                        vcgencmd display_power 0 to turn off
                        vcgencmd display_power 1 to turn on
                        MikgaboM 2 Replies Last reply Reply Quote 0
                        • MikgaboM Offline
                          Mikgabo @NoNameRo
                          @NoNameRo Hi!
                          Thanks for the reply :)
                          I’ll give it a try later when the kids are sleeping.
                          Cheers,
                          Mike
                          • MikgaboM Offline
                            Mikgabo @NoNameRo
                            @NoNameRo
                            Hi, So I placed this command sudo tvservice -o to turn offi in terminal and this is the result…any feedback?
                            pi@MagicMirror:~ $ sudo tvservice -o to turn off
                            [E] Unrecognized argument -- 'to'
                            Usage: tvservice [OPTION]...
                              -p, --preferred                   Power on HDMI with preferred settings
                              -e, --explicit="GROUP MODE DRIVE" Power on HDMI with explicit GROUP (CEA, DMT, CEA_3D_SBS, CEA_3D_TB, CEA_3D_FP, CEA_3D_FS)
        MODE (see --modes) and DRIVE (HDMI, DVI)
                              -t, --ntsc                        Use NTSC frequency for HDMI mode (e.g. 59.94Hz rather than 60Hz)
                              -c, --sdtvon="MODE ASPECT [P]"    Power on SDTV with MODE (PAL or NTSC) and ASPECT (4:3 14:9 or 16:9) Add P for progressive
                              -o, --off                         Power off the display
                              -m, --modes=GROUP                 Get supported modes for GROUP (CEA, DMT)
                              -M, --monitor                     Monitor HDMI events
                              -s, --status                      Get HDMI status
                              -a, --audio                       Get supported audio information
                              -d, --dumpedid          Dump EDID information to file
                              -j, --json                        Use JSON format for --modes output
                              -n, --name                        Print the device ID from EDID
                              -h, --help                        Print this information
                            FYI this is how i’m trying to configure my PIR https://www.magicmirrorcentral.com/pir-sensor-raspberry-pi-magic-mirror/
                            If you have a soluton that currently works on your Pi ZERO please pass it on.
                            Thanks,
                            Mike
                            • N Offline
                              NoNameRo @Mikgabo
                              @Mikgabo
                              To test if it works, you should enter it correctly
                              to turn off the screen
                              sudo tvservice -o
                              or
                              to turn on the screen
                              sudo tvservice -p
                              or
                              please follow the instructions under 2.2 Using PIR-Script, then your PIR will work too
                              • MikgaboM Offline
                                Mikgabo @NoNameRo
                                @NoNameRo Thanks! I’ll give it a try.
                                • MikgaboM Offline
                                  Mikgabo @NoNameRo
                                  @NoNameRo
                                  Thanks SOO much!!! Got er working now. I really appreciate your help in the matter!!!
                                  Cheers,
                                  Mike
