    Check Statuses via JSON API Calls (MMM-JSONStatusChecker)
    1 Posts 1 Posters 1.4k Views 1 Watching
      shbatm Module Developer
      Description:
      MMM-JSONStatusChecker will periodically call a URL and display a “true / false” (or “connected / disconnected”) status based on the results of a value in a JSON response from the API call.
      Multiple instances of the module can be used to call different URLs/APIs using the same background helper. Each instance has it’s own configuration and refresh time.
      See the config options on GitHub for full details, but everything can be customized; including: the key/value in the response being evaluated, the icon displayed, the CSS classes applied for true/false, the text for each status, and even whether or not to show an alert on status change.
      Screenshots:
      Download:
      [card:shbatm/MMM-JSONStatusChecker]
      Version 1.0.0
      • Initial Release;
      Please let me know if you find this useful. leave any comments or issues here or in the GitHub Repo Issues.
