Show/Hide my own module in combination with MMM-Facial-Recognition
Hello. I’ve written a module the hides itself when no data is currently available, otherwise it shows itself. I’m using the standard this.hide() / this.show() methods.
However things get messed up when I combine this with MMM-Facial-Recognition. I’ve read about using lockStrings to lock the module’s visibility, but as far as I understand it, I’d need the Facial Recognition module to supply a lock string upon sending the hide command as well as my own module to supply a lockString to itself upon hiding.
Essentially I want the following behaviour:
- My Module has no data, never show, even if called to be displayed by MMM-FR
- My module supplies a lockString to itself with its hide command
- module remains hidden regardless of what MMM-FR wants to do
- My module has data, but MMM-FR wants it hidden
- MMM-FR would need to supply a lock string with its hide command
- module remains hidden regardless of the fact that there is data
- My module has data AND MMM-FR wants it visible
- both call the show() method with their respective lockStrings, thereby removing both lockStrings from my module
- module is visible.
- Do I understand this correctly?
- Is there another way to get this behaviour without requiring a modification to MMM-Facial-Recognition? I can see myself running into this problem with some other show/hide modules, and I’d rather not have manage my own modified versions of others’ modules.
For more context on this, in fact my understanding above is correct. I modified both MMM-Facial-Recognition and my own module to use a
lockStringoption, and the module is showing and hiding as I expect / want now.However it doesn’t address my second question – could I have accomplished this without modifying MMM-Facial-Recognition?
