    AlexaPI and MagigMirror at same raspberry
    6 Posts 3 Posters 3.7k Views 3 Watching
    • E Offline
      ezarlive
      I have not been able to run AlexaPi with MagicMirror.
      I installed AlexaPi in the same RPi where MagicMirror is.
      The microphone is a webcam and the speaker output 3.5mm. I hear Hello on boot up, but I can not call Alexa. I say “Alexa” but there is no way!
      Can you help me? Somebody can share Alexa config?
      Alsa test:
      http://www.alsa-project.org/db/?f=c06c9e25569d46621bb6cb0c92c08edf318ea32c
      Regards,
        j.e.f.f Project Sponsor Module Developer @ezarlive
        @ezarlive my experience with using AlexaPi with a webcam was dismal. Are you also using the webcam for facial recognition? If so I think the video capture saturates the USB connection and leaves little left over for the microphone. I switched to using the Pi camera connected to the CSI header and a standalone USB microphone and my results are much better.
        • E Offline
          ezarlive
          I test using mic usb but doesn’t works too.
            @ezarlive Have you verified recording is working? If not, try this:
            https://zedic.com/raspberry-pi-usb-webcam-built-in-microphone/
            It helped me get my microphone working.
            Hope this helps!
            -Jeff
              d3r
              Do you really need alexapi? I use the code which was made available by amazon. [https://github.com/alexa/alexa-avs-sample-app](link url)
              Unless you need a specific alexapi module on MM2 you could try this one.
              • E Offline
                ezarlive @j.e.f.f
                @j.e.f.f thanks! arecord test.wav and aplay test.wav works fine.
                I install pulse too, but still not detect Alexa trigger…
