    Withings
    health
    26 Posts 14 Posters 26.7k Views 17 Watching
    • SnilleS Offline
      Snille Module Developer
      Hi @aluini, is your module still working correctly? I’m only getting the weight. :)
      I have an Body Cardio Scale, do I have to define this somewhere?
      Thanks!
      If you cant find it, make it and share it
      MMM-homeassistant-sensors,MMM-Modulebar,MMM-Profilepicture,MMM-Videoplayer,MMM-TautulliLatest
      • F Offline
        fox
        @aluini said in Withings:
        I corrected some things on the module :
        • correction of the @ih800a bug (I had the same)
        • add external CSS
        • add the loader
        • add translation
        I’ll review the design of the module
        [card:aluini/MM_Withings]
        Nice. I want to test it.
        My data from my withings steel also showable?
          Jayh391
          I can not get it to work. I only have the scale.
          • F Offline
            fabbr
            I looked at the module and it just need to be updated however, I can find a way to be able to get the JSON data to be displayed. All I get is a {“status”:342,“error”:“The signature (using Oauth) is invalid”}
            I tried almost everything already.
            If anyone can give it a try and make that work, I can update the module and even create new features.
              AgP42 Project Sponsor Module Developer
              Hello,
              I also try to make it work, but I didn’t succed. Probably I did some wrong behaviour during the oAuth process.
              At the end I can see on my MagicMirror logs an error 283, that correspond according to Nokia API website to : “283 : Token is invalid or doesn’t exist”.
              I considered it was OAuth version 1.0 because it look like it.
              Also it is written on Nokia website :
              “The Health Mate API is now fully functional with OAuth 2.0 authentication protocol.
              Therefore, the OAuth 1.0 process will no longer be supported beginning:
              November 30, 2018”
              Also I do not really want to fight to make it work if the service will be cut by Nokia/Withings on a few months.
              Does someone have the knowledge to update this module with OAuth 2.0 ?
              • I Offline
                iwaldrum
                Anybody get this working with the new OAuth 2.0?
