    Analog + Digital Clock module
    38 Posts 5 Posters 51.1k Views 5 Watching
    • K Offline
      Kevin
      Great work, is this published somewhere already?
      How do i get it?
      • K Offline
        KirAsh4 Moderator
        It’s checked into the develop branch. You can grab that and test it out.
        • K Offline
          Kevin @KirAsh4
          Sorry, im quite new here, develop branch? Cannot find it. :(
          • K Offline
            KirAsh4 Moderator
            I’m on the road at the moment so I can’t give you a detailed answer, but you can clone the develop branch instead of the master one:
            git clone - b develop http://github.com/MichMich/MagicMirror
            Warning: it will overwrite any changes you may have made to local files, just be aware of that.
            • MichMichM Offline
              MichMich
              It’s in the master branch now … :)
              • K Offline
                Kevin
                Thanks alot mate… :bow:
                • K Offline
                  KirAsh4 Moderator
                  @Kevin, as a side note, if there’s a particular clock face that you like me to create for you, let me know. If you have an example, that will greatly help.
                  • P Offline
                    pugsly
                    Works great, just one question. I want to put the analog clock in the top_center and don’t want to show the date because I have the digital clock in the top_right position. How do I turn off the date from showing on a 2nd clock module?
                    • K Offline
                      KirAsh4 Moderator
                      At the moment, it’s hard coded in. I’d have to add a config option so it can be turned off when used as a separate module.
                      • K Offline
                        KirAsh4 Moderator
                        Ok, I have it in my dev branch, but I won’t push it up just yet. I’ll wait a bit to see if there are other things that people will request or fixes. But if you must get rid of it now, you can manually edit the 'clock.js' file and delete line 173:
                        169:    } else if (this.config.displayType === 'analog') {
                        170:        // Display only an analog clock
                        171:        dateWrapper.style.textAlign = "center";
                        172:        dateWrapper.style.paddingBottom = "15px";
                        173:        wrapper.appendChild(dateWrapper);             <===== that line
                        174:        wrapper.appendChild(clockCircle);
                        175:    } else {
                        It will only affect the analog clock when used as a separate module as a single clock.
                        • K Offline
                          KirAsh4 Moderator
                          I should point out that this is just a temporary thing, so you can get rid of it. The updated code will give you a config option to disable it, show it above, or below the clock.
                          • K Offline
                            KirAsh4 Moderator
                            @pugsly, I forgot to mention this: new code has been added to the 'develop' branch that allows you to turn off the date display when using the module in analog mode only. Options are 'top' (default) to have it displayed at the top of the clock, 'bottom' to show it on the bottom, or 'false' to completely turn it off.
                            • T Offline
                              trividar
                              someone know why this happend to me after updating MM:
                              alt text
                              everything looks fine just the analag clock.
                              • N Offline
                                nagaculun @trividar
                                @trividar said in Analog + Digital Clock module:
                                alt text
                                Happened to me too. It was fine yesterday.
                                • N Offline
                                  nobita @nagaculun
                                  @nagaculun you can adjust resize analogSize: “200px”, to smaller ex 150px
                                  N T 2 Replies Last reply Reply Quote 0
                                  • N Offline
                                    nagaculun @nobita
                                    @nobita it works. Thanks
                                    • T Offline
                                      trividar @nobita
                                      @nobita with max. 300px it works, but before the update I had 550px and it works also but no more. Do someone know why?
                                      • MichMichM Offline
                                        MichMich
                                        Should be fixed in the develop branch now: https://github.com/MichMich/MagicMirror/issues/611#issuecomment-272714388
