    Email
    92 Posts 36 Posters 147.1k Views 39 Watching
    • R
      ronny3050 Module Developer
      Description
      Just made an email module for MagicMirror. It is my first module and I had a lot of fun making it.
      It pulls and displays all unread emails and listens for new incoming emails. It updates the mirror when a new email arrives.
      Features:
      • Uses IMAP protocol
      • Full customization - number of emails to display, search parameters, fade effect
      • Listens for new incoming emails
      Updated 06/10/2017:
      Now supports:
      • Multiple email accounts
      • Will not crash on too many unread email support
      • Better fetching of recent and unread emails
      Please let me know if there are any additional features or improvements that you need.
      Screenshots
      Download
      [card:ronny3050/email-mirror]
      A A 2 Replies Last reply Reply Quote 5
      • P
        Phate
        Thats awesome
        • R
          ronny3050 Module Developer @Phate
          @Phate Thank you so much! :)
          • P
            Phate
            As soon as I get a chance I’ll give it a go… :-)
            • R
              @Phate said in Email:
              Let me know how it goes. There are a lot of problems, but I’d like you to test it. IMAP causes a lot of problems and isn’t as straightforward as I thought it would be! :(
              • A
                amanzimdwini @ronny3050
                @ronny3050
                Looks interesting.
                Request: Multiple email accounts?
                OR - better still since I just need the ALERT: any way I can just get a NUMBER of emails I need to read:
                joeshmoe@gmail.com - 17 unread
                suzieQ@public.com - 5 unread
                UncleSam@gov.com - 0 unread
                I’ll have a look at your module once I sort one other problem on my MM2 out.
                • R
                  ronny3050 Module Developer @amanzimdwini
                  @amanzimdwini Thank you!
                  That seems very interesting. I will take a look at that and get back to you! It is definitely possible, however, I’d like to get an audio notification (on new incoming emails) working before I proceed.
                  • A
                    @ronny3050
                    Thx. In the meanwhile: I’d like to change the font size you use for display to small/tiny (I have about a zillion emails in 12+ different accounts)… so I have to fix my custom.css
                    Judging from previous problems (look at the bottom of
                    https://forum.magicmirror.builders/topic/254/sachin-s-mirror/21
                    ) I stink at finding the properties myself - any hints would be most welcome.
                    • R
                      @amanzimdwini
                      That’s a good idea. Note:
                      1. Number of emails to display is customizable and the default is 5.
                      2. Instead of enforcing people to play around with css, I can have a config property where you can set the font size as ‘big’, ‘medium’, ‘small’.
                      Please let me know when you get this module up and running, and whether the above helps.
                      • A
                        @ronny3050
                        Git pull was easy.
                        npm install yielded
                        pi@MagicMirror2:~/MagicMirror/modules $ npm install
                        npm WARN enoent ENOENT: no such file or directory, open
                        '/home/pi/MagicMirror/modules/package.json'
                        npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/packa        ge.json'
                        npm WARN modules No description
                        npm WARN modules No repository field.
                        npm WARN modules No README data
                        npm WARN modules No license field.
                        I’ll go ahead, but thought you might want to know.
                        Note from admin: Please use Markdown on code and shell snippets!
                        R E 2 Replies Last reply Reply Quote 0
                        • R
                          @amanzimdwini
                          I am sorry if my instructions weren’t clear, I’ll update the README. You need to run “npm install” inside the “email” folder.
                          • A
                            @ronny3050
                            npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
                            pi@MagicMirror2:~/MagicMirror/modules $ ^C
                            pi@MagicMirror2:~/MagicMirror/modules $ cd ..
                            pi@MagicMirror2:~/MagicMirror $ cd config/
                            pi@MagicMirror2:~/MagicMirror/config $ ls
                            config.1  config.2  config.5.keep  config.good  config.good.js  config.good.swap  config.js  config.js.sample  config.js.save  config.js.save.1
                            pi@MagicMirror2:~/MagicMirror/config $ sudo nano config.js
                            pi@MagicMirror2:~/MagicMirror/config $ cd ..
                            pi@MagicMirror2:~/MagicMirror $ cd modules/
                            pi@MagicMirror2:~/MagicMirror/modules $ ls
                            default  email  MMM-HTTPRequestDisplay  MMM-wordnik  MMM-WunderGround  MMM-Wunderlist  node_modules  README.md  TR_swap
                            pi@MagicMirror2:~/MagicMirror/modules $ cd email/
                            pi@MagicMirror2:~/MagicMirror/modules/email $ npm install
                            email@0.0.1 /home/pi/MagicMirror/modules/email
                            ├─┬ debug@2.2.0
                            │ └── ms@0.7.1
                            ├─┬ imap@0.8.17
                            │ ├─┬ readable-stream@1.1.14
                            │ │ ├── core-util-is@1.0.2
                            │ │ ├── inherits@2.0.1
                            │ │ ├── isarray@0.0.1
                            │ │ └── string_decoder@0.10.31
                            │ └── utf7@1.0.0
                            ├─┬ mailparser@0.4.9
                            │ ├─┬ encoding@0.1.12
                            │ │ └── iconv-lite@0.4.13
                            │ ├── mime@1.3.4
                            │ ├─┬ mimelib@0.2.19
                            │ │ └── addressparser@0.3.2
                            │ └── uue@1.0.0
                            └── underscore@1.8.3
                            npm WARN email@0.0.1 No repository field.
                            npm WARN email@0.0.1 No license field.
                            • R
                              @amanzimdwini Yes, you should be all set! Thanks for the updates. :D
                              • A
                                @ronny3050
                                Thx for updating the README.
                                Followed instructions (requested app-pwd since I have 2-factor authentication).
                                My config.js:
                                                        module: 'email',
                                                        position: 'bottom_left',
                                                        header: 'Email',
                                                        config:{
                                                        user: 'XXX@gmail.com',
                                                        password: '****************',
                                                        host: 'imap.gmail.com',
                                                        port: 993,
                                                        tls: true,
                                                        authTimeout: 10000,
                                                        numberOfEmails: 5,
                                                        fade: true
                                Restarted (NOT REBOOTED) Pi.
                                Got this:
                                0_1469426287738_upload-38a60756-5f8a-4933-b4f3-af564be8f683
                                Rebooted (just to be safe) - same result.
                                • R
                                  @amanzimdwini you are missing a ‘}’ which closes the config block. It should look like:
                                                          module: 'email',
                                                          header: 'Email',
                                                          config:{
                                                          port: 993,
                                                          tls: true,
                                                          authTimeout: 10000,
                                                          numberOfEmails: 5,
                                                          fade: true
                                  • A
                                    @ronny3050
                                    Sorry - pasted only partial copy; I had the trailing }.
                                    My Config.js was correct…
                                    Just to be on the safe side, I tested it as if config.js had been what I posted - and that failed with a “please create a config file”. As it should have.
                                    So - I think the problem is elsewhere. Sorry
                                    R 3 Replies Last reply Reply Quote 0
                                    • R
                                      @amanzimdwini Could you please report the logs?
                                      • R
                                        @amanzimdwini Also, if you’re using Gmail, you need to ‘set lower security for apps’ https://www.google.com/settings/security/lesssecureapps.
                                        • R
                                          @amanzimdwini It should be working now?
                                          • A
                                            @ronny3050
                                            Just did a clean install on a brand new pi in about 5 minutes flat. COOL MODULE.
                                            (still need to work on 2-auth, please. Plus I’ll want to change your config to make the display single line etc. I’ll look at the js file)
                                            • 1 / 5
