    • Search
    MagicMirror² v2.20.0 is available! For more information about this release, check out this topic.
    Custom 22" Magic Mirror
    Show your Mirror
    • W
      wwrgsww last edited by wwrgsww
      I just completed my first Mirror.
      I built this as a test for a larger project for down the road (two mirrors in the master bathroom.
      This is a 22" Samsung LED Screen completely disassembled and mounted into a custom made wood frame. I used a 1mm piece of acrylic but should of used 3mm (if not perfect you get a funhouse effect quickly).
      I’m a minimalist so my design is very simple same with my layout.
      Mirror mounted on the wall
      Flush Mount Bracket
      I installed a outlet w/ USB behind the mirror
      Green button is for LCD Power incase it turns off. the other two are vents.
      3_1497750797779_IMG_0080.jpg 2_1497750797779_IMG_0079.jpg 1_1497750797778_IMG_0078.jpg 0_1497750797778_IMG_0048.jpg
      I had heat issues, so I installed a heatsink and a fan
      PIR Sensor is getting installed tomorrow.
      Learned a lot from this forum and a coworker and I are helping each other out with some custom modules.
      Currently the Pi is running the server and client, I am going to move the server onto my QNAP which has some more processing power.
      Mykle1 1 Reply Last reply Reply Quote 5
      • Mykle1
        Mykle1 Project Sponsor Module Developer @wwrgsww last edited by
        @wwrgsww
        Well done, looks great!
