    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 874.7k Views 59 Watching
    • swvalentiS
      swvalenti Project Sponsor @swvalenti
      @swvalenti said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
      @sdetweil also how do you not install under mingw could that be the issue
      Ok I did that but I’ll try again
      S swvalentiS 2 Replies Last reply
        sdetweil @swvalenti
        others don’t show at all like MMM-PGA
        i don’t know what “don’t show” means
        did u edit the config.js
        only a vew modules don’t work on Windows (snowboy voice driven for example)
          sdetweil @swvalenti
          note that u have to run the extra install steps manually too
          • swvalentiS
            the position where the modules are supposed to show only a black black screen rest of modules work fine
              sdetweil @swvalenti
              maybe fonts or the nunjucks… (from vendor folder)
              swvalentiS 1 Reply Last reply
              • swvalentiS
                swvalenti Project Sponsor @sdetweil
                @sdetweil said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                I did the fonts but no clue what nunjucks is and how to fix it when I googled it I only got pictures of nunjucks
                  sdetweil @swvalenti
                  @swvalenti nunjuks is the web content templating code, which some of the modules use (it generates the web content from a ‘form’ like definition)
                  but that will not be installed if you do not npm install from the MagicMirror/vendor folder
                  • swvalentiS
                    Ok offially at a lost oh well it was worth a shot to try
                    swvalentiS S 2 Replies Last reply
                    • swvalentiS
                      @sdetweil as an example MMM-PGA shows this in dev
                      module.js:525 Uncaught TypeError: Cannot read properties of undefined (reading 'replace')
                          at cmpVersions (module.js:525)
                          at Function.Module.register (module.js:502)
                          at MMM-PGA.js:9
                        sdetweil @swvalenti
                        @swvalenti here are the windows instructions
                        https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/226?_=1647717794843
                          sdetweil @swvalenti
                          @swvalenti mmm-pga… looks like you didn’t complete the MM install process on windows
                          • swvalentiS
                            I followed the complete walkthrough but I can’t diagnose what I did wrong if you say that I did. Sorry to be a bother Sam
                              sdetweil @swvalenti
                              @swvalenti I just install the module on my Windows MM 2.18 instance without trouble…
                              it was missing a library , per the back screen link… once I fixed that the module came up without issues
                              • swvalentiS
                                Well doesn’t surprise me there! HA thanks for all your work nonetheless
                                  sdetweil @swvalenti
                                  @swvalenti the module is missing ‘request’
                                  • swvalentiS
                                    npm install request in the MM folder?
                                      sdetweil @swvalenti
                                      @swvalenti no,. read the 1st post of the link I posted for black screen
                                      • swvalentiS
                                        ok we are getting somewhere pga now works, openweather forecast still doesn’t work no error in console
                                          sdetweil @swvalenti
                                          sorry, no idea there
                                          • swvalentiS
                                            sam whatever you told me to not which step I got it all working. Only issue now is two modules are not centered correctly even when using top_center…how or if you can use css for that?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
