    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 874.7k Views 59 Watching
      sdetweil @swvalenti
      @swvalenti said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
      how or if you can use css for that
      maybe… depends on the module
      see https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1647717794860
      swvalentiS 1 Reply Last reply
      • swvalentiS
        swvalenti Project Sponsor @sdetweil
        @sdetweil any ideas on this one just showed up…It asked me that npm needed major update now it doesn’t work
        C:\Users\Svale\MagicMirror>npm start
        > magicmirror@2.18.0 start
        > ./node_modules/.bin/electron js/electron.js
        '.' is not recognized as an internal or external command,
        operable program or batch file.
        S 2 Replies Last reply
          sdetweil @swvalenti
          ./node_modules
          yes, you cannot have the ./ in front… windows doesn’t understand that …
          read the instructions again
            sdetweil @swvalenti
            @swvalenti you shouldn’t update things unless u know why you are doing it…
            we test with certain runtimes and release every 3 months
            • swvalentiS
              @sdetweil said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
              ./node_modules
              now I get this error…will never update again lesson learned
              > magicmirror@2.18.0 start C:\Users\Svale\MagicMirror
              'electron' is not recognized as an internal or external command,
              npm ERR! code ELIFECYCLE
              npm ERR! errno 1
              npm ERR! magicmirror@2.18.0 start: `electron js/electron.js`
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the magicmirror@2.18.0 start script.
              npm ERR!     C:\Users\Svale\AppData\Roaming\npm-cache\_logs\2022-03-21T21_48_27_176Z-debug.log
                sdetweil @swvalenti
                @swvalenti come on
                remove the display and the leading
                "start":"node_modules/.bin/electron js/electron.js",
                • swvalentiS
                  “start”:“node_modules/.bin/electron js/electron.js”,
                  I did that sam still doesn’t work sorry to be a bother
                    sdetweil @swvalenti
                    @swvalenti and what is the message?
                    what npm version are u running?
                    npm -v
                    • swvalentiS
                      npm -v
                      this is what i get and below is version
                      > electron js\electron.js
                      npm ERR! errno 1
                      npm ERR! magicmirror@2.18.0 start: `electron js\electron.js`
                      npm ERR!
                      npm ERR!     C:\Users\Svale\AppData\Roaming\npm-cache\_logs\2022-03-21T22_10_23_329Z-debug.log
                      C:\Users\Svale\MagicMirror>npm -v
                      6.14.0
                        sdetweil @swvalenti
                        u still have it wrong
                        “node_modules/.bin/electron electron.js”
                        electron is not in the path, so you have to give it the path to the executable
                        once again different versions of node and npm require slightly different solutions…
                        this is not an MM problem… they keep messing it up (in my opinion)
                        https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/141?_=1638708846564
                        • swvalentiS
                          @sdetweil oh well I give up I tried all the steps, thanks for all the help and patience
                          • swvalentiS
                            This post is deleted!
                            • swvalentiS
                              @sdetweil the only thing that isn’t working now is when I run npm init-y in each module folder the module in the dev window is still asking for replace instead of request
                              Reply Quote -1
                                sdetweil @swvalenti
                                @swvalenti you don’t run npm init unless u need to. only if u need to install a library that mm doesn’t reference anymore
                                  sdetweil @swvalenti
                                  what?
                                  words not clear
                                  • swvalentiS
                                    what?
                                    words not clear
                                    Uncaught TypeError: Cannot read properties of undefined (reading 'replace')
                                        at cmpVersions (module.js:525)
                                        at Function.Module.register (module.js:502)
                                        at MMM-OpenWeatherForecast.js:41
                                    I did what you said but still get this error for some reason
                                      sdetweil @swvalenti
                                      @swvalenti ok, sometimes this is because of a typo in the config position for the module
                                      • D
                                        DanClarkCBET3
                                        • D
                                          DanClarkCBET3
                                            sdetweil @DanClarkCBET3
                                            @DanClarkCBET3 see
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 14 / 17
