    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 772.5k Views 59 Watching
      sdetweil @Bobrae
      @Bobrae see
      https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/225?_=1659891805957
      • Cliff365C Offline
        Cliff365 @Mykle1
        @Mykle1 First off, thanks so much for a great guide. I’m having what is likely a simple issue, but I can’t figure out how to resolve it. I am getting the following error message with the npm start command. Not concerned about the warnings, but how do resolve the DISPLAY issue?
        $ npm start
        npm WARN config global `--global`, `--local` are deprecated. Use `--location=global` instead.
        > magicmirror@2.20.0 start
        'DISPLAY' is not recognized as an internal or external command,
        operable program or batch file.
        cliff@BNC-LAB01 MINGW64 ~/MagicMirror (master)
          sdetweil @Cliff365
          @Cliff365 see the end of the post I just linked to in the prior post
          also, do not run under mingw… just cmd.exe
          • Cliff365C Offline
            Cliff365 @Mykle1
            @Mykle1 Thanks for your help on the DISPLAY issue. I changed the line in packages.json file to:
            “start”: “node_modules/.bin/electron js/electron.js”,
            I get the following error message back:
            'node_modules' is not recognized as an internal or external command,
              sdetweil @Cliff365
              @Cliff365 you didn’t follow all of the last line of
              https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10/225?_=1660158299123
              ps, I’m not @Mykle1
              Cliff365C D 2 Replies Last reply Reply Quote 0
              • Cliff365C Offline
                Cliff365 @sdetweil
                @sdetweil Oops! Thanks sdetweil
                  dude31222 @sdetweil
                  Hey! @sdetweil i’ve spend more than 10 hours whit this because i didn’t read the entire thread. I’ve finally installed mm2 on a 32bit laptop whit w7 and node v16.6 but when i run npm start i just got a black screen. any ideas on how to find a solution? my cmd here:
                  [08.01.2023 06:58.14.001] [LOG]   Starting MagicMirror: v2.22.0
                  [08.01.2023 06:58.14.151] [LOG]   Loading config ...
                  [08.01.2023 06:58.14.201] [LOG]   Loading module helpers ...
                  [08.01.2023 06:58.14.231] [LOG]   No helper found for module: alert.
                  [08.01.2023 06:58.14.361] [LOG]   Initializing new module helper ...
                  [08.01.2023 06:58.14.371] [LOG]   Module helper loaded: updatenotification
                  [08.01.2023 06:58.14.395] [LOG]   No helper found for module: clock.
                  [08.01.2023 06:58.17.473] [LOG]   Initializing new module helper ...
                  [08.01.2023 06:58.17.477] [LOG]   Module helper loaded: calendar
                  [08.01.2023 06:58.17.497] [LOG]   No helper found for module: compliments.
                  [08.01.2023 06:58.17.497] [LOG]   No helper found for module: weather.
                  [08.01.2023 06:58.17.839] [LOG]   Initializing new module helper ...
                  [08.01.2023 06:58.17.839] [LOG]   Module helper loaded: newsfeed
                  [08.01.2023 06:58.17.849] [LOG]   No helper found for module: facts.
                  [08.01.2023 06:58.17.849] [LOG]   All module helpers loaded.
                  [08.01.2023 06:58.19.559] [LOG]   Starting server on port 8080 ...
                  [08.01.2023 06:58.23.451] [LOG]   Launching application.
                  [08.01.2023 06:58.29.838] [LOG]   Server started ...
                  [08.01.2023 06:58.29.848] [LOG]   Connecting socket for: updatenotification
                  [08.01.2023 06:58.29.848] [LOG]   Starting module helper: updatenotification
                  [08.01.2023 06:58.29.848] [LOG]   Connecting socket for: calendar
                  [08.01.2023 06:58.29.848] [LOG]   Starting node helper for: calendar
                  [08.01.2023 06:58.29.858] [LOG]   Connecting socket for: newsfeed
                  [08.01.2023 06:58.29.858] [LOG]   Starting node helper for: newsfeed
                  [08.01.2023 06:58.29.858] [LOG]   Sockets connected & modules started ...
                  [3460:0108/070022.937:ERROR:gpu_init.cc(523)] Passthrough is not supported, GL i
                  s disabled, ANGLE is
                    sdetweil @dude31222
                    @dude31222 never tried win7 myself… this topic was created a while ago…
                    you can TRY setting an environment variable in the cmd.exe window before executing npm start
                    cd MagicMirror
                    set ELECTRON_DISABLE_GPU=1
                    npm start
                      dude31222 @sdetweil
                      @sdetweil still having an empty screen but no more error messages in cmd
                        sdetweil @dude31222
                        @dude31222 that usually means u didn’t do the fonts install step or vendor install step
                        those are extra for windows install
                        • 28
                        • 29
                        • 30
                        • 31
                        • 32
                        • 33
                        • 30 / 33
