    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 764.9k Views 59 Watching
      dude31222 @sdetweil
      @sdetweil i did. Now i’ve upgraded to windows 8.1. still a black screen but a new error```
      [0110/062053.181:ERROR:_trace_logging_minimal.win.cc<78>] provider resistration failure
        sdetweil @dude31222
        @dude31222 I don’t know. those are so far out of service…
          Reila
          Heyo!
          I’ve done a fresh install of MM2 (on Win10), and now I’m struggling with the blank electron screen.
          I did the vendor and font install, changed the package.json to
          "start":"node_modules/.bin/electron js/electron.js",
          according to the guide on page 15, and now I’m getting
          bash: line 1: node_modules.binelectron: command not found
          on npm start, doesn’t start up MM.
            sdetweil @Reila
            @Reila you did not do the package.json edit correctly.
            windows uses slashes leaning left
            and u need 2 in each place
            node-modules\\.bin\\electron  js\\electron.js
              Reila @sdetweil
              Oh, I just copied as it was! It might have been a different guide, it was old after all… I see the backward slashes in a later post now.
              So now I tried
              "start": "node_modules\\.bin\\electron  js\\electron.js",
              (with both the double and single space, just in case) and it’s giving me the same error still.
              I tested changing the start-dev variant too.
              I must be missing another step still.
                sdetweil @Reila
                @Reila I am away from my system at the moment be back in an hour or so.
                what does npm -v say?
                  Reila @sdetweil
                  @sdetweil No problem! Browser version works fine for tinkering in the meantime :)
                  npm is 8.17.0
                    sdetweil @Reila
                    @Reila hm… this is what mine is set to
                    and I don’t get any errors, but electron starts full screen, black screen
                    but if I open edge and go to localhost:8080 it looks great and if I open electron
                    (the 1st part, node_modules\.bin\electron) and go to http://localhost:8080
                    it works…
                    • R Roadrunner451 referenced this topic on
                    • 1 Offline
                      1a2a3a
                      hi i need some help here. when i ran npm start, im getting this message.
                      Starting MagicMirror: v2.23.0
                      [28.06.2023 13:36.52.647] [LOG] Loading config …
                      [28.06.2023 13:36.52.648] [DEBUG] config template file not exists, no envsubst
                      [28.06.2023 13:36.52.650] [LOG] Loading module helpers …
                      [28.06.2023 13:36.52.650] [LOG] No helper found for module: alert.
                      [28.06.2023 13:36.52.655] [LOG] Initializing new module helper …
                      [28.06.2023 13:36.52.655] [LOG] Module helper loaded: updatenotification
                      [28.06.2023 13:36.52.656] [LOG] No helper found for module: clock.
                      [28.06.2023 13:36.52.717] [LOG] Initializing new module helper …
                      [28.06.2023 13:36.52.717] [LOG] Module helper loaded: calendar
                      [28.06.2023 13:36.52.718] [LOG] No helper found for module: compliments.
                      [28.06.2023 13:36.52.718] [LOG] No helper found for module: weather.
                      [28.06.2023 13:36.52.732] [LOG] Initializing new module helper …
                      [28.06.2023 13:36.52.733] [LOG] Module helper loaded: newsfeed
                      [28.06.2023 13:36.52.733] [LOG] All module helpers loaded.
                      [28.06.2023 13:36.52.737] [LOG] Starting server on port 8080 …
                      [28.06.2023 13:36.52.779] [LOG] Launching application.
                      [28.06.2023 13:36.52.812] [LOG] Server started …
                      [28.06.2023 13:36.52.818] [LOG] Connecting socket for: updatenotification
                      [28.06.2023 13:36.52.818] [LOG] Starting module helper: updatenotification
                      [28.06.2023 13:36.52.818] [LOG] Connecting socket for: calendar
                      [28.06.2023 13:36.52.819] [LOG] Starting node helper for: calendar
                      [28.06.2023 13:36.52.819] [LOG] Connecting socket for: newsfeed
                      [28.06.2023 13:36.52.819] [LOG] Starting node helper for: newsfeed
                      [28.06.2023 13:36.52.820] [LOG] Sockets connected & modules started …
                      am i supposed to do something next?
                        sdetweil @1a2a3a
                        @1a2a3a there is a big in the release on windows
                        https://github.com/MichMich/MagicMirror/issues/3083
                        you can follow the instructions to checkout the develop branch, or wait til July 1 for the next release with the fix
                        https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
                        1 1 Reply Last reply Reply Quote 0
                        • 29
                        • 30
                        • 31
                        • 32
                        • 33
                        • 31 / 33
