    MMM-ip
    19 Posts 9 Posters 16.0k Views 8 Watching
      shashank @strawberry 3.141
      @strawberry-3.141 Thanks a lot it’s working great
      0_1474209766039_upload-651af0b0-ae3b-4000-99c0-254258c6618e
      • strawberry 3.141S Offline
        [card:fewieden/MMM-ip]
        Changelog:
        Implemented voice commands to show ip and mac adress, so it can be hidden by default
        alt text
        • L Offline
          logen563
          Hello!
          Is it possible to update the IP periodically?
            Version 2.0.0
            Added
            • Nunjuck templates
            • Integrated MMM-Modal for modal handling
            Fixed
            • MMM-voice mode in notificationReceived (Thanks to https://github.com/MillerMedia)
            Changed
            • Config files
            Removed
            • Config options (voice, showFamily, showType, and startHidden). Check out the readme for replacements.
            • Internal modal handling (help, interfaces)
            • Stylelint and CSS files
            https://github.com/fewieden/MMM-ip
              meaple
              I’ve seen option with bottom_bar, it works, but I 'm already using bottom_bar for smth else and it gets shifted. Is there any other solution to place it in right bottom corner? I’ve tried refference it like that
              .MMM-ip{
              position: absolute;
              left : 100px;
              top : 50px;
              but it doesn’t move, module (in config.js is using bottom_right position ATM
                sdetweil @meaple
                @meaple absolute is absolute. u might want relative
                  meaple @sdetweil
                  @sdetweil I’ve tried with relative as well and it didn’t move either .MMM-ip{
                  position: relative;
                  left : 600px;
                  top : 600px;
                    meaple @meaple
                    @sdetweil got it, smbdy helped me a little on Discord, I’ve moved it to bottom_right (that I don’t) use and then in custom.css added
                    .region.bottom.right{
                    bottom : -15px;
                    right: -15px;
                      v2.1.0
                      MagicMirror² version >= 2.15.0 required.
                      Added
                      • Added config option updateInterval
                      • Github actions
                      Changed
                      • Node helper logs are now done through MagicMirror logger
                      • Github config files
                      Removed
                      • Travis-CI integration
                      Link to module https://github.com/fewieden/MMM-ip
