    MMM-ip
    19 Posts 9 Posters 18.6k Views 8 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @PointPubMedia
      @PointPubMedia in your case you can take this config
      	module: 'MMM-ip',
      	position: 'bottom_bar'
      combined with
      div.MMM-ip div.module-content {
      	text-align: right;
      in ~/MagicMirror/css/custom.css
      Reply Quote 2
      • A
        amanzimdwini @strawberry 3.141
        @strawberry-3.141
        PERFECT
        • A
          @strawberry-3.141
          Did you read this?
          https://forum.magicmirror.builders/topic/408/serverstatus-from-ip-list-up-or-down
            Phate @strawberry 3.141
            @strawberry-3.141
            Works perfectly…
            • K
              KirAsh4 Moderator
              Small note which probably doesn’t apply to the majority here … if anyone at all … other than me that is: my secondary rpi runs IPv6 exclusively (it’s a test platform), so your module would not work as it is specifically looking for the IPv4 field.
              Just something to think about …
              Reply Quote 3
              • K
                KirAsh4 Moderator
                Expanding on what I said above, it might be easier to have the module report both IPv4 and IPv6, then have config options to turn them off:
                    displayIPv4: true,
                    displayIPv6: false,
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @KirAsh4
                  @KirAsh4 done
                  • strawberry 3.141S
                    based on @shashank’s request there is a new version, where you can define which network interface (wireless, ethernet or both) you want to display
                    WARNING: one config attribute changed it’s name for those who update
                    [card:fewieden/MMM-ip]
                      shashank @strawberry 3.141
                      @strawberry-3.141 Thanks a lot it’s working great
                      0_1474209766039_upload-651af0b0-ae3b-4000-99c0-254258c6618e
                      • strawberry 3.141S
                        Changelog:
                        Implemented voice commands to show ip and mac adress, so it can be hidden by default
                        alt text
                        • L
                          logen563
                          Hello!
                          Is it possible to update the IP periodically?
                          • strawberry 3.141S
                            Version 2.0.0
                            Added
                            • Nunjuck templates
                            • Integrated MMM-Modal for modal handling
                            Fixed
                            • MMM-voice mode in notificationReceived (Thanks to https://github.com/MillerMedia)
                            Changed
                            • Config files
                            Removed
                            • Config options (voice, showFamily, showType, and startHidden). Check out the readme for replacements.
                            • Internal modal handling (help, interfaces)
                            • Stylelint and CSS files
                            https://github.com/fewieden/MMM-ip
                              meaple
                              I’ve seen option with bottom_bar, it works, but I 'm already using bottom_bar for smth else and it gets shifted. Is there any other solution to place it in right bottom corner? I’ve tried refference it like that
                              .MMM-ip{
                              position: absolute;
                              left : 100px;
                              top : 50px;
                              but it doesn’t move, module (in config.js is using bottom_right position ATM
                                sdetweil @meaple
                                @meaple absolute is absolute. u might want relative
                                M 1 Reply Last reply
                                  meaple @sdetweil
                                  @sdetweil I’ve tried with relative as well and it didn’t move either .MMM-ip{
                                  position: relative;
                                  left : 600px;
                                  top : 600px;
                                    meaple @meaple
                                    @sdetweil got it, smbdy helped me a little on Discord, I’ve moved it to bottom_right (that I don’t) use and then in custom.css added
                                    .region.bottom.right{
                                    bottom : -15px;
                                    right: -15px;
                                    • strawberry 3.141S
                                      v2.1.0
                                      MagicMirror² version >= 2.15.0 required.
                                      Added
                                      • Added config option updateInterval
                                      • Github actions
                                      Changed
                                      • Node helper logs are now done through MagicMirror logger
                                      • Github config files
                                      Removed
                                      • Travis-CI integration
                                      Link to module https://github.com/fewieden/MMM-ip
