    MMM-ip
    19 Posts 9 Posters 18.6k Views 8 Watching
    • strawberry 3.141S
      A module to show MagicMirror’s IPv4 Network Address
      [card:fewieden/MMM-ip]
      @PointPubMedia @amanzimdwini
      A P 3 Replies Last reply Reply Quote 2
        PointPubMedia
        Thanks Strawberry!
        I just installed it, works fine.
        Except, I can’t really place it at the real bottom right… 'cause I’m using bottom_bar , bottom_right is just on top of bottom_bar
        strawberry 3.141S 1 Reply Last reply Reply Quote 1
        • strawberry 3.141S
          strawberry 3.141 Project Sponsor Module Developer @PointPubMedia
          @PointPubMedia in your case you can take this config
          	module: 'MMM-ip',
          	position: 'bottom_bar'
          combined with
          div.MMM-ip div.module-content {
          	text-align: right;
          in ~/MagicMirror/css/custom.css
          • A
            amanzimdwini @strawberry 3.141
            @strawberry-3.141
            PERFECT
            • A
              @strawberry-3.141
              Did you read this?
              https://forum.magicmirror.builders/topic/408/serverstatus-from-ip-list-up-or-down
                Phate @strawberry 3.141
                @strawberry-3.141
                Works perfectly…
                • K
                  KirAsh4 Moderator
                  Small note which probably doesn’t apply to the majority here … if anyone at all … other than me that is: my secondary rpi runs IPv6 exclusively (it’s a test platform), so your module would not work as it is specifically looking for the IPv4 field.
                  Just something to think about …
                  • K
                    KirAsh4 Moderator
                    Expanding on what I said above, it might be easier to have the module report both IPv4 and IPv6, then have config options to turn them off:
                        displayIPv4: true,
                        displayIPv6: false,
                    • strawberry 3.141S
                      strawberry 3.141 Project Sponsor Module Developer @KirAsh4
                      @KirAsh4 done
                      • strawberry 3.141S
                        based on @shashank’s request there is a new version, where you can define which network interface (wireless, ethernet or both) you want to display
                        WARNING: one config attribute changed it’s name for those who update
                          shashank @strawberry 3.141
                          @strawberry-3.141 Thanks a lot it’s working great
                          0_1474209766039_upload-651af0b0-ae3b-4000-99c0-254258c6618e
                          • strawberry 3.141S
                            Changelog:
                            Implemented voice commands to show ip and mac adress, so it can be hidden by default
                            alt text
                            • L
                              logen563
                              Hello!
                              Is it possible to update the IP periodically?
                              • strawberry 3.141S
                                Version 2.0.0
                                Added
                                • Nunjuck templates
                                • Integrated MMM-Modal for modal handling
                                Fixed
                                • MMM-voice mode in notificationReceived (Thanks to https://github.com/MillerMedia)
                                Changed
                                • Config files
                                Removed
                                • Config options (voice, showFamily, showType, and startHidden). Check out the readme for replacements.
                                • Internal modal handling (help, interfaces)
                                • Stylelint and CSS files
                                https://github.com/fewieden/MMM-ip
                                  meaple
                                  I’ve seen option with bottom_bar, it works, but I 'm already using bottom_bar for smth else and it gets shifted. Is there any other solution to place it in right bottom corner? I’ve tried refference it like that
                                  .MMM-ip{
                                  position: absolute;
                                  left : 100px;
                                  top : 50px;
                                  but it doesn’t move, module (in config.js is using bottom_right position ATM
                                    sdetweil @meaple
                                    @meaple absolute is absolute. u might want relative
                                      meaple @sdetweil
                                      @sdetweil I’ve tried with relative as well and it didn’t move either .MMM-ip{
                                      position: relative;
                                      left : 600px;
                                      top : 600px;
                                        meaple @meaple
                                        @sdetweil got it, smbdy helped me a little on Discord, I’ve moved it to bottom_right (that I don’t) use and then in custom.css added
                                        .region.bottom.right{
                                        bottom : -15px;
                                        right: -15px;
                                        • strawberry 3.141S
                                          v2.1.0
                                          MagicMirror² version >= 2.15.0 required.
                                          Added
                                          • Added config option updateInterval
                                          • Github actions
                                          Changed
                                          • Node helper logs are now done through MagicMirror logger
                                          • Github config files
                                          Removed
                                          • Travis-CI integration
                                          Link to module https://github.com/fewieden/MMM-ip
