    MMM-ip
    19 Posts 9 Posters 16.6k Views 8 Watching
    • strawberry 3.141S Offline
      A module to show MagicMirror’s IPv4 Network Address
      [card:fewieden/MMM-ip]
      @PointPubMedia @amanzimdwini
      A P 3 Replies Last reply Reply Quote 2
      • PointPubMediaP Offline
        PointPubMedia
        Thanks Strawberry!
        I just installed it, works fine.
        Except, I can’t really place it at the real bottom right… 'cause I’m using bottom_bar , bottom_right is just on top of bottom_bar
        strawberry 3.141S 1 Reply Last reply Reply Quote 1
          strawberry 3.141 Project Sponsor Module Developer @PointPubMedia
          @PointPubMedia in your case you can take this config
          	module: 'MMM-ip',
          	position: 'bottom_bar'
          combined with
          div.MMM-ip div.module-content {
          	text-align: right;
          in ~/MagicMirror/css/custom.css
            amanzimdwini @strawberry 3.141
            @strawberry-3.141
            PERFECT
              @strawberry-3.141
              Did you read this?
              https://forum.magicmirror.builders/topic/408/serverstatus-from-ip-list-up-or-down
                Phate @strawberry 3.141
                @strawberry-3.141
                Works perfectly…
                • KirAsh4K Offline
                  KirAsh4 Moderator
                  Small note which probably doesn’t apply to the majority here … if anyone at all … other than me that is: my secondary rpi runs IPv6 exclusively (it’s a test platform), so your module would not work as it is specifically looking for the IPv4 field.
                  Just something to think about …
                  • KirAsh4K Offline
                    KirAsh4 Moderator
                    Expanding on what I said above, it might be easier to have the module report both IPv4 and IPv6, then have config options to turn them off:
                        displayIPv4: true,
                        displayIPv6: false,
                      strawberry 3.141 Project Sponsor Module Developer @KirAsh4
                      @KirAsh4 done
                        based on @shashank’s request there is a new version, where you can define which network interface (wireless, ethernet or both) you want to display
                        WARNING: one config attribute changed it’s name for those who update
